[Z06] Help!
Old Jun 19, 2011 | 12:00 AM
nate1121's Avatar
nate1121
Default Help!
Car just spazzed out and won't start up now... showing these codes,
Mass or volume air circuit input ( P0102 )
Cam shaft position sensor A circuit high input ( 0343 )
hi low neutral drive fault ( 1514 )
No clue what's going in. 03 zo6... diablo tune is the only mod to car. just cruising down highway when codes went crazy. thanks for any input....
Old Jun 19, 2011 | 12:23 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Can you clear any of the DTCs???? Please post the entire DTC P-0102 H or C
BC
Old Jun 19, 2011 | 08:09 AM
nate1121's Avatar
nate1121
goin out to see if I can clear them. I'll post the full codes when i get back. The car ran rough right before it died... and now the ignition is just spinning. doesn't sound like the engine is sparking at all.
Old Jun 19, 2011 | 08:59 AM
DARRYLZO6's Avatar
DARRYLZO6
Did you download the Diablo performance tune alone or did you also alter the tune?
Old Jun 19, 2011 | 09:01 AM
nate1121's Avatar
nate1121
all the codes are P's... my scanner doesnt give me any other letters tho. I cleared them. Nothing changed. is there some sort of safe mode for the car that would keep me from starting it??
Old Jun 19, 2011 | 07:08 PM
nate1121's Avatar
nate1121
Canned tune... no mods. Not even skip shift elim.
I checked all the sensors today on the intake tract. It all seems fine. All I know is I just drove it about 300 miles on friday without an issue... Saturday I took it out for dinner and on the way home, this happened. Engine started sounding rough, went to pull off the road and it completely shut down throwing the 3 codes I mentioned in the OP... and now, not so much as a burp when I turn the key. The starter simple spins freely... No spark, nothing.
Old Jun 19, 2011 | 08:53 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Po343 is your issue"
DTC P0343 Camshaft Position (CMP) Sensor Circuit High Voltage
Circuit Description
The Camshaft Position (CMP) sensor is mounted through the top of the engine block at the rear of the valley cover. The CMP sensor works in conjunction with a 1X reluctor wheel on the camshaft. The reluctor wheel is inside the engine immediately in front of the rear cam bearing. The PCM provides a 12 volt power supply to the CMP sensor as well as a ground and a signal circuit.
The CMP sensor determines whether a cylinder is on a firing stroke or on an exhaust stroke. As the camshaft rotates, the reluctor wheel interrupts a magnetic field produced by a magnet within the sensor. The sensor's internal circuitry detects this and produces a signal which the PCM reads. The PCM uses this 1X signal in combination with the Crankshaft Position (CKP) sensor 24X signal in order to determine crankshaft position and stroke. The PCM monitors for a loss of the CMP sensor signal.
Observe that as long as the PCM receives the Crankshaft Position sensor 24X signal, the engine will start. The PCM can determine top dead center for all cylinders by using the Crankshaft Position sensor 24X signal alone. The Camshaft Position sensor 1X signal is used by the PCM to determine if the cylinder at top dead center is on the firing stroke, or the exhaust stroke. The system attempts synchronization and looks for an increase in engine speed indicating the engine started. If the PCM does not detect an increase in engine speed, the PCM assumes it incorrectly synchronized to the exhaust stroke and re-syncs to the opposite cam position. A slightly longer cranking time may be a symptom of this condition.
Conditions for Running the DTC
Engine speed is less than 4000 RPM.
Conditions for Setting the DTC
The PCM detects the Cam signal is stuck high when the signal should be low for 1.5 seconds.
Action Taken When the DTC Sets
The PCM illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The PCM records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the PCM stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the PCM records the operating conditions at the time of the failure. The PCM writes the conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
The PCM turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A last test failed, or current DTC, clears when the diagnostic runs and does not fail.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
Use a scan tool in order to clear the MIL and the DTC.
Diagnostic Aids
Important
Remove any debris from the PCM\TAC module connector surfaces before servicing the PCM\TAC module. Inspect the PCM\TAC module connector gaskets when diagnosing/replacing the modules. Ensure that the gaskets are installed correctly. The gaskets prevent contaminate intrusion into the PCM\TAC modules.
For any test that requires probing the PCM or a component harness connector, use the Connector Test Adapter Kit J 35616-A . Using this kit prevents damage to the harness/component terminals. Refer to Using Connector Test Adapters in Wiring Systems.
The following conditions may cause this DTC to set:
Poor connections; Refer to Intermittents and Poor Connections Diagnosis in Wiring Systems.
Camshaft reluctor wheel damage
The sensor coming in contact with the reluctor wheel
Using Freeze Frame and/or Failure Records data may aid in locating an intermittent condition. If you cannot duplicate the DTC, the information included in the Freeze Frame and/or Failure Records data can aid in determining how many miles since the DTC set. The Fail Counter and Pass Counter can also aid determining how many ignition cycles the diagnostic reported a pass and/or a fail. Operate the vehicle within the same freeze frame conditions (RPM, load, vehicle speed, temperature etc.) that you observed. This will isolate when the DTC failed.
For an intermittent, refer to Symptoms .
Test Description
The numbers below refer to the step numbers on the diagnostic table.
This step verifies that the fault is present.
If the duty cycle is present at the PCM connector, the Camshaft Position sensor B+ reference and ground circuits are OK.
This step tests the Camshaft Position sensor B+ reference circuit.
This step tests the Camshaft Position sensor ground circuit.
This step tests for a short to B+ on the Camshaft Position sensor signal circuit.
This step tests for a short to ground on the Camshaft Position sensor signal circuit.
Step
Action
Value(s)
Yes
No
1
Did you perform the Powertrain On-Board Diagnostic (OBD) System Check?
Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check
2
Install a scan tool.
Idle the engine.
Monitor the CAM signal input - High to Low transition in the Engine Data List 1 using the scan tool.
Does the scan tool parameter increment?
Go to Step 3
Go to Step 4
3
Turn ON the ignition leaving the engine OFF.
Review the Freeze Frame and/or Failure Records data for this DTC and observe the parameters.
Turn OFF the ignition for 15 seconds.
Idle the engine.
Operate the vehicle within the conditions required for this diagnostic to run, and as close to the conditions recorded in Freeze Frame/Failure Records as possible. Special operating conditions that you need to meet before the PCM will run this diagnostic, where applicable, are listed in Conditions for Setting the DTC.
Select the Diagnostic Trouble Code (DTC) option, the Specific DTC option, then enter the DTC number using the scan tool.
Does the scan tool indicate that this diagnostic failed this ignition?
Go to Step 4
Go to Diagnostic Aids
4
Disconnect both PCM connectors. Refer to PCM/TAC Module Replacement .
Jumper the Camshaft Position sensor ground circuit at the PCM connector C1 (sensor side) to a known good ground.
Jumper the Camshaft Position sensor ignition feed circuit at the PCM connector C2 (sensor side) to B+ using a fused jumper wire. Refer to Using Fused Jumper Wires in Wiring Systems.
Probe the Camshaft Position sensor signal circuit with one lead of the DMM J 39200 and connect the other lead to a ground.
Select the duty cycle option on the DMM J 39200 .
Crank the engine.
Does the DMM display a duty cycle within the specified range?
45-55%
Go to Step 17
Go to Step 5
5
Turn OFF the ignition.
Reconnect the PCM connectors. Refer to PCM/TAC Module Replacement .
Remove the intake manifold in order to gain access to the Camshaft Position sensor. Refer to Intake Manifold Replacement in Engine Mechanical-5.7L.
Disconnect the Camshaft Position sensor electrical connector.
Measure the voltage from the Camshaft Position sensor B+ supply circuit to the battery ground using the DMM J 39200 .
Does the DMM display the specified voltage?
B+
Go to Step 6
Go to Step 8
6
Measure the voltage from the Camshaft Position sensor B+ supply circuit to the Camshaft Position sensor ground circuit using the DMM J 39200 .
B+
Go to Step 9
Go to Step 7
7
Test for an open in the Camshaft Position sensor ground circuit. Refer to Testing for Continuity in Wiring Systems.
Did you find an open ground circuit?
Go to Step 13
Go to Step 17
8
Test for an open or a short to ground in the Camshaft Position sensor B+ reference circuit. Refer to Testing for Continuity in Wiring Systems.
Did you find the circuit open or shorted to a ground?
Go to Step 12
Go to Step 17
9
Measure the voltage at the Camshaft Position sensor signal circuit to ground using the DMM J 39200 .
Is the voltage less than the specified value?
1V
Go to Step 10
Go to Step 14
10
Probe the CMP signal circuit using the test light J 34142-B connected to battery voltage.
Does the test lamp illuminate?
Go to Step 15
Go to Step 11
11
Disconnect the PCM connector C1 located on the same side as the manufacturer's logo. Refer to PCM/TAC Module Replacement .
Test the continuity of the signal circuit from the sensor harness connector to the PCM using the DMM J 39200 . Refer to Testing for Continuity in Wiring Systems.
Is the resistance less than the specified value?
2ohms
Go to Step 18
Go to Step 16
12
Repair the open or short to ground in the Camshaft Position sensor B+ reference circuit. Refer to Wiring Repairs in Wiring Systems.
Is the action complete?
Go to Step 20
13
Repair the open in the Camshaft Position sensor ground circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 20
14
Repair the short to voltage in the Camshaft Position sensor signal circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 20
15
Repair the short to ground in the Camshaft Position sensor signal circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 20
16
Repair the open in the Camshaft Position sensor signal circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 20
17
Inspect for poor connections at the PCM. Refer to Testing for Intermittent and Poor Connections in Wiring Systems.
If you find a poor connection, repair as necessary. Refer to Repairing Connector Terminals in Wiring Systems.
Did you find and correct the condition?
Go to Step 20
Go to Step 19
18
Replace the Camshaft Position sensor. Refer to Camshaft Position (CMP) Sensor Replacement .
Go to Step 20
19
Important
Program the replacement PCM. Refer to PCM/TAC Module Replacement .
Replace the PCM.
Go to Step 20
20
Select the Diagnostic Trouble Code (DTC) option and the Clear DTC Information option using the scan tool.
Idle the engine at the normal operating temperature.
Select the Diagnostic Trouble Code (DTC) option and the Specific DTC option, then enter the DTC number using the scan tool.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text, if applicable.
Does the scan tool indicate that this test ran and passed?
Go to Step 21
Go to Step 2
21
Select the Capture Info option and the Review Info option using the scan tool.
Does the scan tool display any DTCs that you have not diagnosed?
Go to applicable DTC Table
System OK
Document ID# 316788
1999 Chevrolet/Geo Corvette
To Help!
