TPMS Sensor
Old Jun 20, 2011 | 02:42 PM
jortiz5952's Avatar
jortiz5952
7th Gear
Default TPMS Sensor
I just found out this morning that I am in need of a TPMS sensor for my 2000 Vette. The drivers side rear sensor is out and I am told they are around $185.00 a piece to replace. (2001-2004 years are half the price) Does anyone know if there is a fuse in this vehicle that I can remove to de-activate the whole TPMS system? I really dont need it and hate to spend $185 plus labor to get this fixed.
Old Jun 20, 2011 | 02:46 PM
roscoe118's Avatar
roscoe118
I don't believe there is a fuse. Only way I know of, is to get them programmed out...
Old Jun 20, 2011 | 02:47 PM
jrose7004's Avatar
jrose7004
Try Tire Rack for the sensors, I think it's important to have.
Old Jun 20, 2011 | 03:06 PM
BigRobDsp's Avatar
BigRobDsp
if you search on the forum there are quite a few threads on how to rebuild them. It is not nearly as dificult as I was afraid it would be. With a 2000, you are doing your first, but you will be doing the other three within a couple of years. I rebuilt all 4 on my 97 in an afternoon.
Old Jun 20, 2011 | 03:39 PM
jortiz5952's Avatar
jortiz5952
7th Gear
Alright sounds good. Thanks for your help. I appreciate it.
Old Jun 20, 2011 | 05:23 PM
baxsom's Avatar
baxsom
i am just going to switch all of my 00 stuff to 01+. 4 sensors, receivers, and key fob is cheaper than 4 2000 sensors.
Old Jun 20, 2011 | 09:30 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
$63 dollars fo OEM Shrader valves at Tire Rack. Replace as needed.
Old Jun 20, 2011 | 10:16 PM
rrichar2591's Avatar
rrichar2591
Good luck on finding the receiver for the later C5s. I think they are still on backorder and have been for more than a year.
Old Jun 20, 2011 | 10:37 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I am sorry, But you have a Corvette, Fix it the right way. You can find them for a lot less than 185 each. Don,t mickey mouse your car. There is a right way and a wrong way to doing things.
Just my opinion.
Mr.Bill
Old Jun 20, 2011 | 10:54 PM
jortiz5952's Avatar
jortiz5952
7th Gear
So I did go up to Discount Tire this afternoon. Found out they can order me two new sensors for the rear for $98 a pop.the guys says I'm looking at $205 installed. I did make sure to tell him that they are different from the 01-04 Vettes.He said they are for the 00' Vette so I guess I will find out Thursday if they fit. A lot better of a price then I was originally thinking.
Old Jun 21, 2011 | 06:25 AM
baxsom's Avatar
baxsom
Just my opinion.
Mr.Bill
Are you a politician because that is one of the most vague statements I have ever read on this board.
Old Jun 21, 2011 | 07:48 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I happen to agree with him on this. The car is designed to work with these systems all working together not only for the car itself but to help keep the driver safe. Not trying to be onry or anything but trying to disable or remove active systems is not the best idea in my opinion plus any possible following owner will have issues too.
Old Jun 21, 2011 | 07:51 AM
Mr.Bill's Avatar
Mr.Bill
Sorry that statment was over your head.
Old Jun 21, 2011 | 10:48 AM
jortiz5952's Avatar
jortiz5952
7th Gear
I think I bought the curse of the Vette's. I bought this car last December with 53,000 original miles on it. Beautiful car I cannot complain. So far I have already replaced the oil pressure sensor, the whole stereo unit with an aftermarket, the AC/climate control because the lighting went bad, the turn signal switch because that went bad, my hazard switch is starting to go out on me now and I have 2 rear tire sensors that just went out. Cant win
Old Jun 21, 2011 | 10:59 AM
Redeasysport
Told you $63 each at tire rack, your money to waste I guess wanna send me $35 I could use it
killain's Avatar
killain
Oldtimer
Default Another view !
Just my opinion.
Mr.Bill
I just in the last few months bought new tires, (Michelin's & a complete new set set of TPSM), I did so because the old ones were original equipment, 8 years old and I didn't want to have to break the bead of the new tires anytime soon in the future. I bought Michelin Pilot Sport ZP's and I'm hoping the the sidewall of the tires holds really well, which is the case as my digital readout on my DIC is steady every morning for the last two months. Now on my 03 the TPSM are not as expensive as yours, but I remember someone who rebuilds them for the 97 to 2000 or 2001. I'd look around and see if you can't find them cheaper. It's a Major PITA when your DIC keeps sending you error messages despite your knowing about the problem already. Good luck !
Old Jun 21, 2011 | 11:10 AM
jortiz5952's Avatar
jortiz5952
7th Gear
I tried tire rack and couldnt find anything online?? Do you have a part # or something?
To TPMS Sensor
Old Jun 21, 2011 | 11:22 AM
dgrant3830's Avatar
dgrant3830
53k miles on the clock is strange to be having problems unless the car has been sitting for long periods of time. What many people need to know too is that nothing lasts forever and we're driving computers on rolling chassis. Things will fail. You wouldn't like the list of things I've replaced on my '99 as its long but not that bad except for the transmission which was a nightmare on my car, but the rest of failures were normal wear and tear .... and some cheap stuff GM put in it. Plastic gears where it should have been metal or something stronger and so on. Electrical switch's contacts that aren't up to par and etc...BTW, I'm way over 300k miles on mine
Old Jun 21, 2011 | 11:32 AM
Redeasysport
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
Click on the TPMS tab at the bottom. Looks like their prices went up a little now $66 each.
Their phones work
Old Jun 21, 2011 | 12:05 PM
boy at heart's Avatar
boy at heart
http://www.alltiresupply.com/p-SB-28006.html
