Downshifting Question
Old Jun 27, 2011 | 12:49 PM
Stephen_a_'s Avatar
Stephen_a_
Default Downshifting Question
I was flipping through my owners manual the other day and on the page that explains what the maximum speeds you can downsift into the paticular gears I noticed it also comments that you should NEVER drop more than one gear when you downshift.
I have definitely on occasion dropped more than one gear in a downshift and now I'm curious if this is actually an issue because I would hate to damage the apple of my eye in any way.
I would think as long as you're below redline in the gear you downshift into (below the recommended speeds in the manual) you should be fine.
Thoughts? Comments?
Old Jun 27, 2011 | 12:55 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I would think that maybe a chance of over reving the engine in the downshift. Remember they put a lot on warning information in the manuals to cover their butts.
I have never downshifter more than one gear at a time, but I have upshifted past a gear. Like second to forth and third to fifth at times.
Old Jun 27, 2011 | 01:06 PM
TorchRedRocket's Avatar
TorchRedRocket
This is exactly why they put it in there. They're just basically saying, "Shift at your own risk, but we warned you." The reason they're warning you is because you can mechanically over-rev the engine if you select the wrong gear. The rev-limiter will not save you. I downshift from 6th to 3rd at 60 mph all the time. No problems. Just be certain that you have the right gear you want!
Old Jun 27, 2011 | 01:57 PM
SaberD's Avatar
SaberD
if i ever skip a gear downshifting, i usually just rev match for the gear im skipping, and briefly kiss the synchro. then i rev match to the gear im going into. it makes the rev matching process a little easier and exact for me. its a little bit more difficult to rev match fully skipping a gear, but still doable. fully skipping the gear isnt something i typically practice though, because you shouldnt ever need to do it on a road course. plus it sounds pretty cool when i punch the gas twice really fast when downshifting.
Old Jun 27, 2011 | 04:03 PM
dba4life's Avatar
dba4life
I go from 4th to 2nd quite often trying to rev match
Old Jun 27, 2011 | 05:18 PM
TorchRedRocket
Even though it's implied, I guess I should have mentioned like everyone else has that you should always be rev-matching for any downshifts!
Old Jun 27, 2011 | 05:54 PM
Rob04C5LM's Avatar
Rob04C5LM
That's just CYA language in the manual. Just in case you drop from 6 to 1 at 90MPH and your transmission and/or motor breaks - they don't want to be sued because you didn't know how to operate the vehicle.
Old Jun 27, 2011 | 06:18 PM
spdislife's Avatar
spdislife
..just got to blip a bit harder if skipping a gear
Old Jun 27, 2011 | 07:12 PM
SFL_driver's Avatar
SFL_driver
I don't know if this really pertains to your question but I thought I would throw it in for anyone else whom it might help.
I would just go through and check your max speeds per gear. That way when you go to down shift you know what gear you should select and what RPMs you'll be at once in that gear.
Old Jun 27, 2011 | 07:54 PM
65GGvert's Avatar
65GGvert
It is refreshing to see a question because someone read the owner's manual, instead of because they didn't.
Old Jun 27, 2011 | 09:07 PM
TorchRedRocket
Very good advice here too. Definitely know your redline in each gear.
Old Jun 27, 2011 | 09:35 PM
billymz28's Avatar
billymz28
my buddy shifted 3rd to second somehow at the track and kissed all eight intake valves. On a week old car for him with something like 17k miles. so he decided to heads and cam after.
Old Jun 27, 2011 | 09:44 PM
laurelboy's Avatar
laurelboy
St. Jude Donor '11
I put it in drive and it upshifts and downshifts all by itself.
Old Jun 27, 2011 | 10:58 PM
Stephen_a_'s Avatar
Stephen_a_
Ouch. That hurts.
Old Jun 27, 2011 | 11:07 PM
Stephen_a_'s Avatar
Stephen_a_
Thanks for all the responses in such a short amount of time everyone. Lots of useful info as per usual. God I love this forum.
As I was searching for the answer to this question before I posted it I came across a lot of posts regarding "knocking" and troubleshooting them. I'm wondering how you can tell if your car is knocking as I've never knowingly been around a car that was knocking. Just for interest's sake.
Old Jun 27, 2011 | 11:10 PM
Kuzma823's Avatar
Kuzma823
Like others have suggested, all you need to do is watch your rpms when you shift. It is a much bigger difference when skipping gears, so if you get it wrong it may cause a little more wear on the clutch and a bit more discomfort from the lurching. Personally I drive mine everyday (30K+ miles in my last 2 years) and I am almost always skipping gears, shifting up and down.
I even go from 1st to 5th if I floor it on an on ramp Just watch the rpms/max speed for the gear you are shifting to and you should be fine. Also might help to learn to 'double clutch' as it helps reducing the wear on the clutch and syncros... plus its just something to add to the enjoyment of driving
Old Jun 28, 2011 | 12:02 AM
Kind of unusual anymore.
To Downshifting Question
Old Jun 28, 2011 | 12:10 AM
spdislife's Avatar
spdislife
Redline is the same every gear...6500 RPM....need to know top speed of every gear at redline.
Old Jun 28, 2011 | 08:20 AM
TorchRedRocket
Whoops, brain fart. I meant to say know your speed at redline in each gear. I believe fuel cutoff is at 6250 rpm, correct? No reason to really rev over 6000 rpm.
Old Jun 28, 2011 | 09:51 AM
m6 c5's Avatar
m6 c5
The fuel cutoff is at 6250 for coupes and convertibles I think it may be 6750 for the z06 however.
Now onto the op's other question one way you can see if you are pulling timing due to knock is to data log your engine with Hp tuners or EFI Live other than that I would imagine unless it is a very slight knock you would be able to hear it and possibly feel it.
