[Z06] clutch help
Old Jun 28, 2011 | 02:35 PM
michaelfrench's Avatar
michaelfrench
Default clutch help
So my transmission went out in my 2002 zo6. I have a replacement transmission. I was thinking about changing out my stock clutch while I'm up there. I'm wanting a spec. Do I need to change flywheels? Can I use my original
Old Jun 28, 2011 | 03:48 PM
MStrahan's Avatar
MStrahan
I've heard it's a good idea to change the flywheel when changing the clutch. You might be able to get away with a resurface if you were staying with a stock clutch, but you said you wanted a Spec. Get the l/w flywheel and enjoy the quick revs.
Old Jun 28, 2011 | 04:37 PM
skyavonee's Avatar
skyavonee
It's a good idea to replace it while you're already in there working on the trans and clutch. Only a couple hundred more in parts, and no additional labor. Also be sure to replace the pilot and throwout bearings.
Old Jun 28, 2011 | 05:44 PM
Edmond's Avatar
Edmond
Don't do the work twice.
While you're at it, get the factory shop manual from Gene, it will save you a lot of money after this first project. You will also get the exact torque specs and pattern to tighten the flywheel/pressure plate bolts to.
Get ARP bolts.
Do not forget to align the shifter after you're done. I did not align the shifter and was popping out of first until a member helped me figure out the problem.
Old Jun 30, 2011 | 07:39 PM
PRE-Z06's Avatar
PRE-Z06
It is not a good idea to run aggressive friction materials with cast iron flywheels as they can explode. That is why our kits include Billet Steel SFI certified flywheels. They also include a new pilot bearing along with release bearing and the instructions to guide you through proper installation. Feel free to call me with any questions.
To clutch help
