What Plugs do you run?
Old Jul 4, 2011 | 06:54 PM
Mrgogo's Avatar
Mrgogo
Default What Plugs do you run?
I'm thinking of changing the plugs and wires on my 99 convertible. Shes all stock with 67k on it. I bought her two years ago she runs just fine. I've got a little extra bonus money and thought I'd flip for some hi-tech plugs. Whats the latest? Is it worth the extra $$? Let me know what your experiences are. Thanks!
Old Jul 4, 2011 | 07:26 PM
baxsom's Avatar
baxsom
you already have the best plugs ever made already on it. stock plugs are good for 100K miles easy. You can also go with the NGK TR55s which are really good for like 5 bucks each, or you can go back with the stock iridium for like 7 each. Go with the GMPP wires. They fit perfectly and allow you to reuse the heatshields with no problems. The LS ignition is supposedly pretty near perfect as is.
Old Jul 4, 2011 | 08:10 PM
JuicedZ's Avatar
JuicedZ
Ngk-tr55
Old Jul 4, 2011 | 08:38 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
When I replace mine they will be the stock iridium plugs.
Old Jul 4, 2011 | 10:27 PM
When I replaced the plugs in my '00 (only car I've had to do that to so far), I went with a set of AC Delco Iridiums from gmpartshouse.
Old Jul 4, 2011 | 10:31 PM
Qwik01's Avatar
Qwik01
NGK TR55's here.
Old Jul 4, 2011 | 10:50 PM
Grim Reaper's Avatar
Grim Reaper
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19
Originally Posted by Qwik01
NGK TR55's here.
Same here.
Old Jul 4, 2011 | 10:52 PM
Jet-Jock's Avatar
Jet-Jock
AC-Delco Iridium plugs
Also add the GM Performance red wires in as well. Most likely you will destroy one or more wires removing them. Might as well not worry about it and install a new set.
Old Jul 4, 2011 | 10:55 PM
egrand333's Avatar
egrand333
I used the iridium Delco plugs on mine at about 70,000 mi. Don't forget to use the anti-seize stuff on the threads in case you have the car long enough to need changing again. I also put new delco wires on at the same time. You may break the old ones when you remove them.
Old Jul 4, 2011 | 10:57 PM
mchicia1's Avatar
mchicia1
Tr5's are more like 2 and some change per plug, not 5.
Old Jul 4, 2011 | 11:05 PM
egrand333's Avatar
egrand333
Do the GM Performance wires come in black or only red. No offense to anyone but I just do not like the color red. Maybe something red traumatized me as a child.
Old Jul 4, 2011 | 11:06 PM
wascapsfan's Avatar
wascapsfan
NGK Iradium
Old Jul 5, 2011 | 12:46 AM
Jistari's Avatar
Jistari
I've only seen them in red.
Old Jul 5, 2011 | 03:22 AM
DeeGee's Avatar
DeeGee
Another vote for NGK TR-55s
Old Jul 5, 2011 | 07:07 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I run NGK - BR7EF's in my Vette since I am Supercharged!
But what you need to get is NGK TR-55's and gap them at .055 and you will be set
Thanks,Matt
Old Jul 5, 2011 | 10:40 AM
rkboz's Avatar
rkboz
At 70,000 I had a wire burn in two. Make sure you put your new wire as far away from the manifolds as possible. I use NGK TR-55's because I like changing my plugs every year. It lets you know if there is a bad cylinder developing......sometimes. Yeah and they were $2. My old plugs had worn to 60 thousandths and that is too much. I gapped the new plugs at just over 50.
Old Jul 5, 2011 | 11:05 AM
BTAL's Avatar
BTAL
St. Jude Donor '09
Wouldn't just pulling and examining the plugs tell you the same thing?
To What Plugs do you run?
Old Jul 5, 2011 | 12:05 PM
C5Longhorn's Avatar
C5Longhorn
NGK TR55's here.
Old Jul 5, 2011 | 12:27 PM
Jet-Jock's Avatar
Jet-Jock
Only red as far as I know.
Things to consider:
- Work on a cold engine.
- Use aluminum anti-seize on the plug threads.
- Use dielectric grease on the plug boots.
- Torque the plugs.
- On the driver's side, remove the AIR value, two 10mm bolts and rotate it out of the way. Makes the driver's side a piece of cake to do.
Old Jul 5, 2011 | 03:22 PM
Mrgogo's Avatar
Mrgogo
Ok guys. Thanks a lot. Very good info here. I'll make my plug choice. And throw in a set of wires. I know its a straight deal but does anybody have a step by step with pics? If not maybe that'll be my contribution for the help.
