C5 trunk does not open
Old Jul 19, 2019 | 12:16 AM
  #41
USAZR1's Avatar
USAZR1
Originally Posted by 1989 Corvette
Did you ever get an answer to this question? I read through all the threads and did not find a solution to your problem. I am having the same issue with my 2002 convertible. Right after having an issue with my battery I had to replace. I cannot open my trunk using my key fob and button on dash. The key fob does not sound the horn anymore when I arm and disarm. I think it may have something to do with my factory alarm.
thoughts?
The OP hasn't been back to this site, for 8yrs.
Old Sep 11, 2022 | 09:58 PM
  #42
BWK60's Avatar
BWK60
1st Gear
Yep DeeGee was right! My issue turned out to be fuse #32. Thanks!
Last edited by BWK60; Sep 11, 2022 at 10:06 PM. Reason: Wanted to list specific contributor who pointed me it the right direction
Old Sep 12, 2022 | 05:06 AM
  #43
Beezr's Avatar
Beezr
I have a 1999 convertible and when I pop the trunk it doesn't open very far. I did a search on a trunk spring mod but nothing came up. Can someone point me in the right direction or explain it to me please?
Old Sep 12, 2022 | 07:33 AM
  #44
Vette-kid's Avatar
Vette-kid
it's a simple spring that mounts on one of the bolts for the catch on the deck lid. Several of the vendors have them.
Old Sep 12, 2022 | 08:12 AM
  #45
Beezr's Avatar
Beezr
Okay thank you. I have to search for a trunk lid spring.
Old Sep 12, 2022 | 10:10 AM
  #46
Fast one's Avatar
Fast one
It might help to clean out the 20 year old dirty, dried up grease from the latch assembly with solvent and then add new grease.
Old May 3, 2025 | 02:27 PM
  #47
3R1$C's Avatar
3R1$C
I had the same issue, looked at every fuse, relay, checked voltages... etc. etc. etc.
Problem was that I did not understand the lock-out function. When the key is not in the off position, i.e. when the key is turned to ignition on, the lock-out prevents the boot open function. So if you turn your ignition key, neither the remote nor the truck release button works. Turn the ignition key back and the functionality is there again.
I installed FOG lights on my Z06 and had the ignition key always on, only connecting / disconnecting the battery itself. There should be a message in the dash "locked out when ignition on".
Great way to waste half a day!
