Battery saver
Old Jul 27, 2011 | 11:40 AM
G.Rossman's Avatar
G.Rossman
St. Jude Donor '13, '15, ‘18, '21
Default Battery saver
I have trouble keeping my batteries alive. My cars can sit for a couple of weeks or months just depending on weather and my schedule. I have gone through some optimas so I finally returned the last one and I am now trying a sealed battery from Duracell.
I have seen products that hook onto the battery and disconnect them to keep them from being run down and causing damage.
Is anyone else using one of these devices?
Old Jul 27, 2011 | 01:10 PM
FKING1's Avatar
FKING1
Get a Deltron Battery Tender and no more batt probs.
Old Jul 27, 2011 | 03:16 PM
DeeGee's Avatar
DeeGee
Most guys go the other way and fit a battery tender to keep it topped off.
If you're constantly running down the battery you need to find out why.
Identifying Battery Problems
The C5 eats batteries unless you take some regular precautions. If your battery continually dies its either the battery which is on its last legs or something on the car.
You also need to look at how you use the car. Is it a daily driver? If so the battery should be getting a good top up every day so you may have a problem.
Is it a DD but you do short trips? If so you'll be taking a lot out of the battery every time you start. For a short trip, say less than about 20 mins, you won’t top it off properly. Eventually it'll drain.
Is it a weekend car. If so, this takes a lot out of your battery. There’s a 20MA drain even dormant. If you don’t drive the car for a reasonable time every week or so, it'll kill the battery. In this case you really do need a battery tender.
You’ll know when your battery is bad. As it gets low you may get strange electrical indications (random warnings and U fault codes). As it gets lower it may drop the memory settings or defaults such as HUD settings. Eventually you’ll get the dreaded chattering relays in the footwell and eventually the lights on the IPC will disappear.
Most batteries can be recharged quite successfully, although AGMs are harder. Start by checking the charge on the battery. Don’t read the DIC when the car is off. The value you see on the DIC is alternator output when the car is running. It will always measure an inaccurately low voltage on the battery when the ignition is off and figures of 11.0V to 11.9V is normal in this case. With the engine on, the voltmeter should show between 13V and 14.5V. You need to measure voltage across the battery terminals using a digital multi meter if possible. A fully charged battery measures 12.7V and a fully discharged battery measures 11.9V. Partially discharged batteries will give a reading somewhere in between.
If the battery is low give it an overnight charge (or put it on a battery tender until you get a fully charged indication) and retest it. A true test is under load and Autozone will do that test for free.
If you have an AGM battery like the Red Top and it has been deeply discharged it's harder to recover it. This might help:
http://www.youtube.com/watch?v=dIoaL3DWWEg
If you’ve recharged it and it still runs down, then you need to start looking for excessive drains. Bill Curlee posted a good method for checking:
http://forums.corvetteforum.com/1567522286-post590.html
There are some common faults which are well known for causing problems:
First to check is the interior lighting rotary switch on the drivers panel. It’s possible for that to be turned on as there’s a setting (fully clockwise) which bypasses the auto off function. Turn it fully counter clockwise and check after about 30 minutes (preferably in the dark) that the interior lights have gone off.
If it’s not the lights something has failed or is badly installed.
Have you fitted an after-market device which draws current? Typically it’s a cellphone charger, radar warner or a similar device that’s the problem.
If still no joy, you need to start pulling fuses to identify the problem.
The power seat switches on the side of both seats are notoriously unreliable. The switch becomes sticky with use and can stick in the “on” position. You shouldn’t damage the motors as they are thermally protected. The fuse may blow so worth checking (Fuse 36 20A in footwell).
The driver’s lumbar motor can also cause issues so check this too (mini fuse 3 15A in footwell). The seat controls connect under the seat. Pull the connector and if the drain stops that’s your problem.
Less common but not unheard of are failures of the headlight motor control module the alternator and the Bose Amplifier under the dash on the driver’s side.
Old Jul 27, 2011 | 03:29 PM
Been using one for years and it works great.
These cars do put a draw on the battery even when sitting still. A good battery should last at least a few weeks, perhaps longer, without any worry of being discharged. But if you are going through a lot of batteries, I agree with DeeGee - maybe a check of the car's electrical system is in order.
Old Jul 27, 2011 | 05:15 PM
hotwheels57's Avatar
hotwheels57
I've used a BATTERY TENDER PLUS (DELTRAN CORP. @ 1.25amp) for several years now. The battery is always charged during six months of hibernation.
Recently, DELTRAN introduced a version that is solar powered...
http://batterytender.com/
Old Jul 29, 2011 | 10:54 AM
G.Rossman's Avatar
G.Rossman
I had a batery tender on mine and it still went dead. When I treid to charged it back up with my big unit the battery got warm, so it may have just been shot to begin with.
Old Jul 29, 2011 | 10:57 AM
DarkBlueC5's Avatar
DarkBlueC5
I recommend the CTEK 3300 with cigarette lighter adapter. quick and easy. works for short term inactivity, and also I use it for 4 months of continuous winter storage.
Old Jul 29, 2011 | 11:07 AM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
CTEK 3300 here. I used it on my C-5 for many yrs now. Since moving to the midwest I also have one for my daily driver. (winter months).
Old Jul 29, 2011 | 11:20 AM
carpe dm's Avatar
carpe dm
Get, and use a Battery Tender! I hook mine up if I don't intend to use it for a couple of days, and they have been fine.
Old Jul 29, 2011 | 12:24 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
CTEK 3300 is what I use, Great little item, Worth checking out.
Old Jul 29, 2011 | 01:20 PM
2004c5blackcoupe's Avatar
2004c5blackcoupe
Harbor Freight 1.5 amp 3 stage onboard battery charger/maintainer item #99857 on sale $20.00 Works great. Automatic shutoff when charged.
http://www.harborfreight.com/automot...html?hftref=cj
Old Jul 29, 2011 | 01:31 PM
der451b's Avatar
der451b
I used CTEK 7000, selected Recondition Mode and charge via cigarette lighter for 5 years, no battery issue.
Old Jul 29, 2011 | 02:54 PM
Mr.Bill's Avatar
Mr.Bill
I believe the 20 buck chargers are lacking on having a good protection circut.
Old Jul 29, 2011 | 03:16 PM
hdkeno's Avatar
hdkeno
Old Jul 29, 2011 | 03:26 PM
G.Rossman's Avatar
G.Rossman
This is the one I have now.
Old Jul 29, 2011 | 08:14 PM
killain's Avatar
killain
Oldtimer
Default Optima's and battery float chargers.
An Optima battery like a Red Top, if allowed to discharge below 10.5 volts will need to be charged via a Vampire charge. If you don't know, ask me. I've use a few chargers over the years and I use one called "BatteryMinder" which is a top rated float charger (It will never overcharge your battery) but once charged up, the charger switches over to a pulse de-sulfation/conditioner It removes the plaque that builds up on the plates walls in the battery. Costs $39.95 To me it's cheap considering all that it does.
Old Jul 29, 2011 | 10:06 PM
fun01's Avatar
fun01
Love my CTEK 3300.
To Battery saver
Old Jul 29, 2011 | 10:17 PM
vettedude521's Avatar
vettedude521
My Optima red top went dead after a couple years even after buying a "battery Tender". I found out too late that the gel cel batteries do not charge properly with these battery tenders and they will actually damage them. My newest Optima (about a year old now) is doing fine but I now start the car and let it run for 20+ minutes every 10 days or so. I tossed the battery tender.
Old Jul 29, 2011 | 10:25 PM
Baldfart's Avatar
Baldfart
I have had my Battery Tender Plus for 10 years now. Works great!
Old Jul 30, 2011 | 01:43 AM
spankdxm's Avatar
spankdxm
Wow my car must be doing good.. I work 28 on 14 off and I rarely drive it because of rain. I never had a problem. Sounds like yall have battery drain. I know on my previous vehicles my alarm systems drained my batteries. I used to use a remote disconnect on my positive cable to stop the drain also saving my battery life. I would go around 3-6 months without starting them up. Yeah yeah i used to have 6 vehicles so my toys rarely got played with.
