Can't Program key fob
Old Aug 19, 2011 | 02:47 PM
NVR_L8's Avatar
NVR_L8
Default Can't Program key fob
I have changed the batteries in all three key fobs and the car fob program will not recognize any of the remotes. I went to the key fob program when tells me to press and hold lock and unlock on first key fob nothing happens. I can hold the buttons for up to 2 minutes on any remote and it wont recognize any of them.
Old Aug 19, 2011 | 03:09 PM
DeeGee's Avatar
DeeGee
Are the TPSs working? If so, its a fob problem and not the RF receiver.
Old Aug 19, 2011 | 04:01 PM
kris6868's Avatar
kris6868
FOB's have been known to quit working..
There is a write up on soldering the FOB back to working order..
I’m not good with electronics so I bought new FOB's when my factory’s stopped working..
Hope you get yours working...
Old Aug 19, 2011 | 05:35 PM
HG's Avatar
HG
Try this, it's in the owners manual
turn on the ignition to ON
press the options button on the DIC several times until the blank page is displayed. THEN PRESS AND HOLD THE RESET BUTTON FOR TWO SECONDS
when the message FOB TRAINING is displayed, press the Reset button once. the message HOLD LK & UNLK will be displayed.
Press and hold the lock and unlock buttons on the first transmitter for five seconds
when a transmitter is learned, the DIC will display FOB LEARNED
If this works, do the others the same way.
Old Aug 19, 2011 | 05:36 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Pull your codes and see if the RFA is working. Clear the codes and try the programming again.
Old Aug 19, 2011 | 05:51 PM
HG's Avatar
HG
If you don't know how to clear the codes
http://www.stengel.net/diccodes.htm
Old Aug 26, 2011 | 07:42 PM
NVR_L8's Avatar
NVR_L8
Default codes reported
I had several codes that are reoccurring in the BO-RFA Section C 2115 H (Left rear TPM Sensor Malfunction), U1016 H (Loss of Communication with PCM), U1064 H (Loss of Communication with BCM), U1096 H (Loss of Communication with IPC, and U1255 H C Serial Data Line Malfunction. I understand that an H after the code means history and C is current. When I clear the codes and try to reprogram the three key FOBS none of them are recognized again. The dash sits there at "Press the lock and unlock button on 1st fob" I will not learn. I will then recheck then codes and the same codes will come up.
Old Sep 3, 2011 | 02:10 PM
NVR_L8's Avatar
NVR_L8
Default any other sugestions
help
Old Sep 3, 2011 | 02:53 PM
TAFMAN618's Avatar
TAFMAN618
I recently had the same problem on both of my remotes. I replaced both batteries and couldn’t get either remote to program. I took the batteries out and used an alcohol swab to clean the batteries contacts that touch the circuit board. I then used a small file to “clean” the contacts on the circuit board. This fixed one of the remotes. After looking at the other remote, I noted the battery contact was in the wrong position; it didn’t align with the contacts on the circuit board. I moved it and successfully programmed the second remote.
Old Sep 3, 2011 | 06:57 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Originally Posted by NVR_L8
help
Did you respond to DeeGee's question? Are the TPS's working?
If so, have you checked the car battery? If the battery is low it can interfere with the programming procedure.
Old Sep 9, 2011 | 11:19 PM
NVR_L8's Avatar
NVR_L8
Default Key Fob programing failed
Yes the tsp's are working 3 Tire Pressure Sensors are working left rear currently has a spare rim without a tsp on it.
Old Sep 10, 2011 | 12:28 AM
007KING's Avatar
007KING
if all u did was change the battery all u have to do is stand next to the car, PRESS and HOLD the LOCK and UnLock Buttons on the Key Fob AT THE SAME TIME for about 7 seconds. When Resynchronization is Achieved, THe Horn Will Beep.
Repeat for the other Key Fobs. Tell me if that worked??!!
To Can't Program key fob
