Convertible Question
Old Aug 26, 2011 | 10:18 PM
K9Leader's Avatar
K9Leader
Default Convertible Question
I have a '99 convertible. The flap of fabric attached to the top that covers the tonneau cover when the top is up was annoying me - it would flap around when I was driving with the top up but the windows down. I also didn't like that it covered up a nice splash of color in the cockpit so I removed it. The straps were anchored with screws so that removal was easy. However it was riveted to the back edge bottom of the top. I went all in and drilled out the rivets.
I did this several months ago and much prefer it. Anyone else out there done anything similar? Also, I wonder if that cloth served as any sort of protection for the top or the glass when folded. Thoughts?
Old Aug 26, 2011 | 10:37 PM
92GA's Avatar
92GA
Oldtimer
I've been thinking about doing that too. Could it be put back in if you wanted to? I looked at mine briefly, and saw that the elastic straps aren't elastic anymore. Thought about trying to install some new elastic pieces to keep it tight. I've been wondering what the purpose of it was too.
Old Aug 27, 2011 | 02:27 AM
DeeGee's Avatar
DeeGee
Thats exactly what it does; it protects the back window from scratches when it's lowered. I have a trunk partition which also protects the top but I've never considered removing the cover. Come to think of it, I never drive top up/windows down. If it's not raining the top comes down even when it's cold.
Old Aug 27, 2011 | 03:44 AM
memmer's Avatar
memmer
DeeGee I agree with you. I had a new black top put on in Feb. and haven't seen it since
Old Aug 27, 2011 | 09:25 AM
rws.1's Avatar
rws.1
The convertible top is only to keep storage dust and rain out of the cockpit it was never intended to be used while driving.
Old Aug 27, 2011 | 09:28 AM
DeeGee's Avatar
DeeGee
Old Aug 27, 2011 | 12:02 PM
cdnguyred88's Avatar
cdnguyred88
Old Aug 27, 2011 | 01:07 PM
K9Leader's Avatar
K9Leader
Yes, it should be possible to put it back. The elastic straps would just reattach with the screws at the anchor points. The bottom strip would have to be reattached to the rivet points somehow, with screws or expandable button/pins or something.
Old Aug 27, 2011 | 01:17 PM
Vettmann17's Avatar
Vettmann17
I hate driving with the top up. When I have to I usually don't have the windows all the way down so the flapping isn't an issue for me. Deegee is right, the cover is meant to prevent the window from scratching when the top is down and I believe also to reduce sun glare off the paint reflecting off the glass when looking in your rearview with the top up.
Old Aug 27, 2011 | 01:47 PM
Jet-Jock's Avatar
Jet-Jock
I was going to remove mine and re-dye it black cause it's been fading from being in the sun.
Old Jul 6, 2020 | 08:14 PM
Blac Avy's Avatar
Blac Avy
Don't remove it! It's good for 5 extra hp.
To Convertible Question
