Help needed
Old Sep 8, 2011 | 08:33 AM
TMGard's Avatar
TMGard
Cruising
Default Help needed
Hi Its been a while since I logged in. I need some help!
I have not been able to drive my car very much this summer because the the 'Reduce Engine power' light come on when I least expect it.
I have been told that I need a Throttle something control sensor.
Well it was ordered from a local dealership in the middle of June, it still has not shown up.
Any one have any ideas on how I can get one?
By the way I have a 1997 coup.
Tree
Old Sep 8, 2011 | 08:48 AM
PY310L's Avatar
PY310L
Thats hapened to me several times. You need to run better gas. Premium 93 octane, but a reputable gas brand. Try that first, alo run a fuel addetive to an empty rank before you fill up.
Old Sep 8, 2011 | 09:43 AM
TMGard's Avatar
TMGard
Cruising
Hi, I do use Premium 93 octane. I have used additives for the gas. This has been a issue that has reared its ugly head a few time over the last few years. The last time it happened I was on 494 freeway around Minneapolis. Not a good feeling when your car engine drops down to 5MP when everyone else is doing 65.
Old Sep 8, 2011 | 10:19 AM
runner140*'s Avatar
runner140*
I'd bet a can of beer.....that you have a code or two or more. Have you accessed them yet? Please do and get back to us with the codes. If you don't know how, use the search feature on top the this site. They can be accessed from the dic.
Old Sep 8, 2011 | 11:28 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree...pull the codes.
Old Sep 8, 2011 | 01:00 PM
cdkcorvette7's Avatar
cdkcorvette7
+1
Courtesy of Bill Curlee:
Originally Posted by Bill Curlee
POST DTCS!!!
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
To answer your original question, contact Gene Culley at GM Parts House for OEM parts. He's got awesome prices and great service. But... Don't just go throwing parts at it. Post your codes...
Old Sep 8, 2011 | 04:18 PM
TMGard's Avatar
TMGard
Cruising
I will get the other codes.
To Help needed
