Rotor installation problem
Old Sep 9, 2011 | 07:07 PM
ramez75's Avatar
ramez75
Default Rotor installation problem
Hi,
I have been having my new slotted black rotors and pads on the floor for 2 months now.
I decided today to install them on my 2001......I did some reading and seemed straight forward.
Raised the rear, took the wheel off, loosened the caliper of the rotor, then yanked the old rotor out. Now I have been trying to put the new rotor in but with no luck, there is a ring like thing that I believe need to go inside the back gut of the rotor. It seems it was under compression and when i yanked the old rotor it expanded and now cant get the new rotor on.
Did I break something, any help will be greatly appreciated. Hope my explanation is not confusing.
I took pictures. The wire that looks like the V came out from inside the ring. I dont know how this should go back in and how to compress the ring to put in the rotor.
Old Sep 9, 2011 | 08:56 PM
egrand333's Avatar
egrand333
I think that has to do with the parking brake. Can't remember how it goes back in but it was a little tricky. Someone will chime in soon. I also remember pictures posted showing an easier way to do it. Maybe a search will help.
Old Sep 9, 2011 | 09:20 PM
ramez75's Avatar
ramez75
Ok so since I am still trying to figure out the V shape wire and the metal loop. I was loosening the Caliper from the Caliper bracket. One of the screws broke. So is there a place/website were i can buy the bolt that holds the caliper to the bracket and I will also need the hollow rod that goes into the bracket and the bolt goes into it. Or will I need to buy a the whole caliper set.
This is not what I expected..........I should have gone and watched a movie
Old Sep 9, 2011 | 09:28 PM
CHJ In Virginia's Avatar
CHJ In Virginia
The parts you show are the parking brake shoe and retention spring. Unfortunately you have pulled them off and they are a PITA to get them back on. Start the reinstall by moving the star wheel to it's fully retracted position. Center the shoe on the backing plate and insert the spring with the top of the V pointing up and the bent notches pointing badk to the backing plate. The spring goes inside the brake shoe. You will see three retianer clips on the rear of the backing plate. These clips hold the spring in place and center the shoe. Start by hooking it at the top and then on either side. The bottom of the spring must be inside of the shoe metal ring. It would help getting a brake spring install tool at the local auto parts store or you could modify a screw driver to help position the spring. Once you have it properly together, trial fit the rotor. Move the star wheel adjustor out till the shoe is just touching the inside of the rotor drum. It will take you several tires. ---- the bolt and slider pin are available at almost all auto perts stores. Bolt and pin are < $10.00 just take it in and tell them what car, usually in stock.
Old Sep 9, 2011 | 09:34 PM
egrand333's Avatar
egrand333
I just did a quick search "parking brakes" and saw a diagram of the whole assembly. Give it a try.
Old Sep 9, 2011 | 09:48 PM
ramez75's Avatar
ramez75
Thank you for the write up....I will see if what I did matches with what you said. The groves on the V shaped wire I hooked them to the hook shaped things on the backing plate. They looked to me that they are there for a reason, to hold something. So what i did is i put the V shaped wire behind the loop and used a thin screw driver and pushed the 2 grooves on the V shaped wire into the hooks and then put the rotor and used a rubber mallet to force it in. I only saw 2 retainer clips of hooks as I call them.
Also small chips came of the parking brake show when I was prying the old rotor out.
What is the Star Wheel adjuster??? Let me see if I can find a picture or drawing
Is that still safe???
ramez75's Avatar
ramez75
I tried thats, let me try again
Old Sep 9, 2011 | 10:02 PM
tbrowne's Avatar
tbrowne
Try the link below - it should help!
http://forums.corvetteforum.com/c5-t...y-49-95-a.html
Old Sep 9, 2011 | 10:25 PM
egrand333's Avatar
egrand333
Thats the link I was looking at. One tip, make sure you adjust the parking brake shoes out as far as possible and still be able to get the hub on or your parking brake may not hold when you apply them. ( I mean so far out that you can barely get the hub on) We didn't do that when reassembling my friends rear brakes and the parking brake didn't hold at all but he was so frustrated by then he no longer cared.
Old Sep 10, 2011 | 10:15 PM
ramez75's Avatar
ramez75
I found this helpful...........now i have an idea how the thing should look like. Now i will have to make mine look like that.....
Ofcourse i found out that i had my parking brake on.........stupid me...I guess that a kesson learned when i do the other 3 rotors.
Old Sep 10, 2011 | 10:23 PM
Aerovette's Avatar
Aerovette
No just the other side. One not three.
Old Sep 11, 2011 | 08:58 AM
ramez75's Avatar
ramez75
Old Sep 11, 2011 | 09:04 AM
ramez75's Avatar
ramez75
Is there a proper sequence for putting back everything, should I connect the caliper to the bracket while free then attach the bracket&caliper, or attach the bracket first then pads then caliper.
brake caliper mounting bracket bolts to 125 lb ft
brake caliper guide pin bolts to 23 lb ft
Old Sep 11, 2011 | 09:26 AM
Z06ster's Avatar
Z06ster
...Of course i found out that i had my parking brake on...........I guess that a lesson learned when i do the other 3 rotors.
As I started reading the thread, I was asking myself how this happened. Then I saw your comment above. Your lesson was not in vain...by sharing this, you prevented me and potentially others from forgetting to release the e-brake. I hope the repair goes well.
Old Sep 11, 2011 | 12:40 PM
ramez75's Avatar
ramez75
Another question.
Do I need to use Locktite (Red or Blue?) on the bolts to the caliper and the bolts to the bracket.
Thank you
Old Sep 11, 2011 | 02:37 PM
vetteman741's Avatar
vetteman741
From: Motorsports Capital of the World..Indianapolis Indiana
I always clean old loctite off bracket bolt threads (class 10.9 hardness bolts) and use Blue loctite works every time, no Loctite on calipers slide bolts (I dont think), maybe a drop of blue
Never red, it is supposed to require heat to remove bolts, and you don't want that on calipers.
Old Sep 11, 2011 | 02:42 PM
vetteman741
Yes,
bracket, then pads, then caliper, put a dab of caliper lube where the pads sit in clips
Make sure the rubbers on the caliper pins are good (with caliper lube inside boot) or water will get in there and caliper will stop sliding which will kill one pad, overheat caliper and then caliper piston rubber will rot out and sieze causing locked up caliper. Ask me how I know
Live and learn
To Rotor installation problem
Old Sep 11, 2011 | 03:18 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
if you have an automatic and you are free of a steep driveway and hilly terrain you can do what I did. I freakin' removed all the parking brake garbage from both sides...it's a contraption required by law, but not necessarily by reality, and it gets the lowest cost design on most cars. When I take the car to the dealer I just warn them with a sticker on the gearshift, "no P Brake".
Old Sep 11, 2011 | 03:56 PM
ramez75's Avatar
ramez75
I like your idea .......
Old Sep 11, 2011 | 08:05 PM
RonJ's Avatar
RonJ
If worse comes to worse, it's not that much more of a job to remove the splined hub. With the hub out of the way, getting the spring back is a breeze. Good time to lube the splines and get rid of a click too!!
RonJ ...
