Old Mar 11, 2015, 01:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
Print Wikipost
Convertible top hatch strut installation.
Old Oct 18, 2018 | 09:56 AM
  #61
MAX1VET's Avatar
MAX1VET
Cruising
Look under the side of the trunk hatch. I thought the covers had to be removed but they don't. The front of the strut is easier to reach from the by opening the cover for the top.
Old Oct 18, 2018 | 09:59 AM
  #62
gowenfast's Avatar
gowenfast
Finalist 2022 C1 of the Year - Unmodified
2021 C1 of the Year Finalist - Unmodified
2020 C1 of the Year - Unmodified
2018 C1 of Year Finalist
St. Jude Donor '21
Originally Posted by Ultimate ride
My vert top hatch struts needed replaced as the hatch would no longer stay up by itself. I did a search on changing them, but wasn't satisfied with the results I got. So, here is how I changed them.
1. Open the trunk. Look under the sides and you will see the struts.
2. Pry off both the spring clips with a screwdriver or scratch awl.
3. Close the trunk.
4. Open the top hatch and prop it up in the fully raised position. The strut is now in the fully extended position and not under pressure.
5. Reach down and pull the strut off the ball joints.
6. Close the top hatch.
7. Open the trunk and snap the new strut on the aftermost ball joint, making sure that the rod end is positioned toward the front of the car.
8. Close the trunk.
9. Open the top hatch and snap the rod end on the forward ball joint.
The hatch will now stand up by itself.
10. Repeat for the other side.
Once I figured this method out, it took less than 5 minutes to complete the job. I didn't take any pictures, but when you look under the sides of the trunk, it is all pretty obvious.
Thanks for this post. My 50th Anniversary just developed this problem.
Old Feb 2, 2020 | 03:15 PM
  #63
Joe_G's Avatar
Joe_G
St. Jude Donor '08
3. Close the trunk.
8. Close the trunk.
Thanks for the tip! I tried getting to the back one first, and that was a bust. Doing it your way was the hot tip, thanks. It still was a bit of a bear to get the ends snapped on but finally got it.
Appreciate your post. This forum is great for helping.
Old Feb 2, 2020 | 04:46 PM
  #64
Yello95's Avatar
Yello95
St. Jude Donor '11
Appreciate your post. This forum is great fir helping.
wow a 10-year old post still going strong that's great I didn't even see it before I did mine and I did mine yesterday and took a total of 10 minutes
Old Feb 2, 2020 | 08:16 PM
  #65
Ron222's Avatar
Ron222
Glad you found it helpful. Gotta do my trunk now, 10 years later. LOL
Old Feb 3, 2020 | 07:23 PM
  #66
Yello95's Avatar
Yello95
St. Jude Donor '11
It would have been helpful, but i had them on in 10 minutes and then found your post later on in the day...
Old Feb 17, 2020 | 11:21 AM
  #67
rfc123's Avatar
rfc123
8th Gear
Excellent instructions. I just did mine, it took me a bit to get the old ones off in the trunk because I had to get into the trunk to do it.. Getting in the trunk is easy for a contortionist but not for a guy 72 years old. So happy it is done and over with. Anyone with a younger more flexible body should be able to do it in less than ten minutes.
Old Feb 17, 2020 | 11:23 AM
  #68
rfc123's Avatar
rfc123
8th Gear
You don't have to remove those black plastic covers.
Old Jun 19, 2020 | 09:21 PM
  #69
David Hayden's Avatar
David Hayden
1st Gear
Thanks for the advice. Worked just like you said it would. I have a 98 also.
Old Jun 19, 2020 | 10:25 PM
  #70
o2bnkc's Avatar
o2bnkc
Did mine a few months back on my '04 vert, used the same procedure as outlilned above and didn't have a problem. Ordered the struts from this link ( http://stores.ebay.com/Lift-Supports...id=p4340.l2563 ). I ordered the ones manufactured by STABILUS (when you remove yours you'll notice STABILUS is the manufacturer that supplied them to GM (at least on my '04, their name is right on the strut) the only difference between the two is that the stabilus has a black cylinder and black plunger, same as OEM, the Strong Arm ones have a black cylinder and a chrome plunger. I received my order in a few days...no problems at all....and the best part is they have a
Lifetime Warranty and I got 2 for $25.00.
They fit perfectly. Hope this helps
That's where I've purchased all my struts over the years. www.liftsuportsdepot.com
Old Jun 19, 2020 | 10:28 PM
  #71
o2bnkc's Avatar
o2bnkc
I was trying to figure out what he was talking about.
Old Jul 6, 2020 | 10:45 AM
  #72
gowenfast's Avatar
gowenfast
St. Jude Donor '21
The thread lives on. I just did the struts on my 2003 50th Anniversary convertible. The struts lasted 17 years. Excellent instructions. Thanks to the OP!!...
