Brake caliper covers
Old Sep 20, 2011 | 09:46 AM
jjradtech's Avatar
jjradtech
Default Brake caliper covers
I have a 99 FRC. I have replaced the stock rotors with drilled and
slotted rotors and replaced the wagon wheels with chrome thin spke wheels (from JWMotoring, great to deal with). I would like to cover the
ugly calipers with a set of red caliper covers, but I am concerned with having enough clearance between caliper and wheel, I measured about
3/16" clearance is this enough? Or shouild I just paint them?
thanks jerry
Old Sep 20, 2011 | 10:03 AM
cdkcorvette7's Avatar
cdkcorvette7
I'd just paint them. Those caliper covers never look right to me...
Old Sep 20, 2011 | 10:17 AM
rebelheart's Avatar
rebelheart
They simply look cheap and odd.Seems they would trap brake heat also.
Old Sep 20, 2011 | 10:38 AM
charger21's Avatar
charger21
C5 of Year Finalist (track prepared) 2019
caliper covers--->
Old Sep 20, 2011 | 11:25 AM
WARD473's Avatar
WARD473
I just painted mine. It took about 1/2 day. Caliper paint dries very fast. It gives a nice detail to that area.
Old Sep 20, 2011 | 01:55 PM
jrose7004's Avatar
jrose7004
That's the way I feel.
Old Sep 20, 2011 | 03:36 PM
atmsrus1's Avatar
atmsrus1
I bought a set of powder coated calipers and they look good
Old Sep 20, 2011 | 04:39 PM
NorthEnco's Avatar
NorthEnco
Default powder coating
Powder Coating is the way to go.
When done right it's almost indestructible.
Bob
Old Sep 20, 2011 | 04:44 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Either paint your calipers, or, get a set of powder coated ones. Covers
Old Sep 20, 2011 | 04:46 PM
hotwheels57's Avatar
hotwheels57
You've made a serious new member mistake...asking people how to spend your money.
The DUPLICOLOR kits from AUTO ZONE, O'REILLY'S, etc work very well. The paint is silica based so it's very durable. You needn't remove the calipers, hoses, drain brake fluid, etc to do it. Some paint only the outside visible side, but it's so easy to paint the entire caliper with just minor masking. One can is more than enough. Colors are available. Very inexpensive and easy to do. It dries quickly.
You'll need a can or two of aerosol brake cleaner and a wire brush to prepare the calipers for the paint.
I would suggest you buy a better quality paint brush to apply the paint though. The brush that's provided looks like a cheap solder flux brush.
Old Sep 20, 2011 | 04:53 PM
cdkcorvette7
with all of that. I have done this on several cars and the results are great. Definitely get a good quality brush from a crafts store as suggested above. Also, I used a wire wheel attachment for my dremel to clean the calipers before painting. Make sure you get them VERY clean for best results.
Also, be sure to get the kit that comes with a can of paint not a rattle can. The spray on stuff doesn't come out as well...
Old Sep 20, 2011 | 05:26 PM
SFL_driver's Avatar
SFL_driver
Paint is the way to go
Old Sep 20, 2011 | 06:04 PM
m6 c5's Avatar
m6 c5
I wouldnt say that the spray on stuff doesnt do well as when I did it, it turned out great. I did spend a long time cleaning them as if they arent 100% clean the paint will run away from the spot that has oil on it. It took me about a week to do all of it because it was ~40 out and paint doesnt dry to well. I think I did 5 or 6 coats and used up about 2/3 of a can.
I would suggest pulling the calipers off the car as you can do a much better job cleaning them and painting them.
Old Sep 20, 2011 | 07:08 PM
chasboy's Avatar
chasboy
Oldtimer
According to the video the covers reduce the heat.
I used the Duplicolor kit on my Xterra and even one coat looks great and lasts. Kit comes with a cleaning solution and yes, the infamous flux brush-not sure which covers more, the paint or the bristles as they fall out of the brush.
I'm a bit of a cowboy since I have a fairly steady hand, so I didn't even remove the wheels. (had to roll the truck a few times tho'.
Old Sep 20, 2011 | 08:31 PM
SFL_driver's Avatar
SFL_driver
At least unbolt them from the bracket and hang them from the wheel well with a wire hanger. This way you don't have to mess with the brake lines.
EDIT:
I always also suggest to people that they do a two tone paint job; red caliper and black caliper bracket. Makes it look cleaner in my opinion.
Old Sep 20, 2011 | 09:56 PM
I would agree with everyone else here - painting them looks better. Not hard to do - they key is in the prep work.
Old Sep 20, 2011 | 11:36 PM
m6 c5's Avatar
m6 c5
Originally Posted by SFL_driver
EDIT:
Thats exactly what I did, I even painted the hat on the rotor black. I did something a little different than most, I actually polished the corvette lettering on the calipers. It gets quite a bit of attention just because of that, all things considered of course.
To Brake caliper covers
Old Sep 21, 2011 | 12:21 AM
cdkcorvette7
Just did my dad's vette in blue with polished letters. It really made them pop. I'm going to re-do my red caliper paint job this winter with polished letters. Looks very clean that way...
Old Sep 21, 2011 | 12:56 AM
JETZ's Avatar
JETZ
Caliper Covers?
Is a 'Wheelskin' in the wings too?
Powder coat, or paint!
Old Sep 21, 2011 | 06:56 AM
chasboy's Avatar
chasboy
Oldtimer
Powder coat, or paint! [/QUOTE]
There was a Corvette with what looked like Wheelskins at our show this past sunday. Did not like the look nor the fact that I've been reading for years that they cause heat build up.
