HID install
Old Sep 22, 2011 | 02:30 PM
Sinister-Z's Avatar
Sinister-Z
Originally Posted by StealthFRC
the "right" way of doing this is to use the hi/lo bulbs. its a single bulb with both functions. if you just install another hid kit for your highs it will go bad really fast. the worst thing you can do with an hid is to turn it on/off. now if you can find someway to keep the bulb dim lite while the high beam is "off" then you may be able to get away with it... its something ive always wanted to try but could never figure out how.
the multi function bulb is really just a bulb that moves up/down to change the angle of the light.
So it would be a matter of changing out the bulb that comes with the kit to the Hi/lo bulbs found somewhere else? Or is it something that just isn't available yet for the C5 conversion?
Old Sep 22, 2011 | 02:32 PM
2slicks1vette's Avatar
2slicks1vette
That's because you don't understand how bixenon lights work.
The cutoff shield in the projector itself moves up when the high beam is activated. The bulb does nothing...
Old Sep 22, 2011 | 02:38 PM
StealthFRC's Avatar
StealthFRC
in order to try it you would need an adapter for the bulb socket and the bulb plug. some bulb types that can be ordered hi/lo are:
9007
9004
h13/9008
there are a few others but the bulb the c5 uses can not be ordered hi/lo
Old Sep 22, 2011 | 02:40 PM
StealthFRC's Avatar
StealthFRC
delete
Old Sep 22, 2011 | 02:42 PM
2slicks1vette
there are kits out there that move the bulb... my buddy has one for his car.
what you say is true for STOCK cars that have them.
I'm talking about the proper way to obtain bixenon capability, not some trash setup with an HID bulb in a halogen reflector setup. In a proper projector setup, the bulb does not move.
Old Sep 22, 2011 | 02:44 PM
StealthFRC's Avatar
StealthFRC
calm down buddy... you are correct, i did not realize the hi/lo bulbs just have a shield surrounding them that moves.
Old Sep 22, 2011 | 02:46 PM
2slicks1vette
calm down buddy...
I'm calm, just preventing you from spreading poor information on the forum.
Old Sep 22, 2011 | 02:48 PM
Sinister-Z's Avatar
Sinister-Z
9007
9004
h13/9008
What if I decided to go with the ACA projector setup? Would you still need to do this or add just another HID kit?
Old Sep 22, 2011 | 02:49 PM
StealthFRC's Avatar
StealthFRC
i think you mis understood my first post that you quoted... the last sentence had nothing to do with the first paragraph. i was talking about regular non hi/low bulbs.
Old Sep 22, 2011 | 02:51 PM
StealthFRC's Avatar
StealthFRC
the aca setup is what i have, it uses a h9 bulb for the projector housing in which you would need any adapter of some sort to be able to use a hi/lo bulb from the list above and even then im unsure if the hi/lo bulb would fit.
with my setup it utilizes a halogen bulb for high beam in-which is about 1/10th of the brightness of my low beam hid's. i never use high beam and you really shouldn't need to, however if you do decide to keep the halogen high beam bulb you should wire it so the low beam hid's DO NOT turn off when you use your highs.
Old Sep 22, 2011 | 03:02 PM
Sinister-Z's Avatar
Sinister-Z
Ok. So the aca setup has the HID's already installed for the low beams then?
The one's I found on that "auction site" do not say they are aca's but are the same correct?
Old Sep 22, 2011 | 03:03 PM
2slicks1vette
The best route is to get the ACA headlights, then remove the ACA projector and install a Morimoto bixenon projector. (Specifically Morimoto FX-R 2.0 Bixenon Projectors).
This is it. See the wires? They tap into your high beam. When you turn the high beams on, they move the light shield out of the way and you unleash the full light beam of the HID bulb. They are very easy to retrofit into the ACA housing. I will be posting my write-up on how to do this shortly. These Morimoto projectors blow the ACA projectors out of the water in terms of light performance.
  #33
StealthFRC's Avatar
StealthFRC
from what i gather they are the same... they do not come with hid's they come with the projector housing so hid's can be used. i recommend ddmtuning for hid kits.
Old Sep 22, 2011 | 03:07 PM
  #34
2slicks1vette
Here's another shot:
If you look inside of the bulb hole, you can see the reflective shield inside. That shield moves out of the way when the high beams are activated.
Like I said, even the low beam performance of the Morimoto projector is MUCH better than the ACA projector.
The retrofit is so easy. You just unscrew 4 bolts from the ACA projector, remove it, then pop the Morimotor projector in and you're done. Then you just splice the wire into the high beam circuit and you're ready to light up the road to kingdom come.
Old Sep 22, 2011 | 03:09 PM
  #35
Sinister-Z's Avatar
Sinister-Z
The kit I found include all the bulbs installed. They have the H9 for the projector and 9005 for the high beams.
Aren't the H9's HID? Or am I thinking of something else?
I would post a link to them but I'm not sure if that allowed. I don't want the CF gods to strike me down.
Old Sep 22, 2011 | 03:12 PM
  #36
Sinister-Z's Avatar
Sinister-Z
So with these you would only need a pair to install into the aca housings? And you wouldn't even need the high beam bulb installed...correct?
Look forward to seeing your write up on this.
Old Sep 22, 2011 | 03:21 PM
  #37
cdkcorvette7's Avatar
cdkcorvette7
Me too... I'm going to research this a little.
To HID install
Old Sep 22, 2011 | 03:24 PM
  #38
mtndv8's Avatar
mtndv8
Originally Posted by CBZZZC5
Just ordered the kit from Neal at Corvette mods. For those who have done the mod already. Is it really as easy as it looks. Are there any suprises a person like me with no experience should be prepaired for. Thanks in advance for any insight.
OP;
YES, it is as simple and as easy as it looks.
There dozens of threads that address all the "issues" brought forth here as well as all the documented installation threads.
Only a few of the posts here actually address your question.
Surprises in life are fun, except when damage or injury occur.
My simple, surprise avoidance advice is the following;
1) Wear latex (or similar) gloves when disassembling/reassembling the lights. This will help you to keep ahold of the smallish screws, nuts and bolts during the process. Also help to keep body oils or contaminants from getting on the HID bulbs themselves.
2) Ensure you DO NOT contaminate the HID bulbs. This drastically reduce their life. (See #1) Body oils from your fingers can be far worse for your HID bulbs than any amount of on/off cycling.
3) Take your time and thoroughly clean and/or prep the area where you intend to mount your ballast. Those have been known to end up rattling around the bottom of the body work, yanking on the harness/wiring. Nothing good comes of this.
4) Disconnect the battery...
Aside from the electrical hazard live wiring presents it's good to remember that the same timer that turns off your interior lights, etc also will drop the light buckets, usually about the time you have digits or appendages in compromising positions...
HTH and Welcome to the Light!!
Old Sep 22, 2011 | 03:33 PM
  #39
2slicks1vette
Correct, although the halogen high beams might as well be left in place to be used in Flash-To-Pass situations.
Old Sep 22, 2011 | 03:37 PM
  #40
mtndv8's Avatar
mtndv8
...then you should probably mention that there are more current or newer designs that have a (digitally, I believe) controlled wattage increase when the cutoff shield solenoid is activated, making the miramoto far from the top of the bi-xenon food chain.
Jus' sayin'...
