slideing seat repair
well ive been trying to fix my seat an there is no way of getting the t40 bolt undone to get the threaded rod out to fix it i dont know what kinda magic was used by the person who had posted the repair thread but ive been beating on this seat for 2days now an no luck
Received 2,688 Likes
2018 C5 of Year Finalist
You can purchase a repair kit for the C5 sliding seat problem. About $25.00 per seat. You can get the kits from corvette central, mid-america corvettes and vendors here on the forum. A tool comes with the kits for taking that T40 bolt off but sometimes it takes a pair of small vise grips to get it off.
Resident moron
As for the T40 bolt, not sure what to tell you, mine came right out with a 3/8" ratchet and T40 socket. It might be loctited, maybe a little heat or some PB blaster might help?
Dope
Thanks for the clarification on the kit. I purchased a similar set of nylon square plugs from The RadioFlyer instead of using nylon washers. Hit kit did not come with the Torx head wrench, however per my other thread on the Rocking Seat Fix, GM changed the torx bolts between 2001 and 2004. I own a 2004, and I need a female torx socket to remove them. Since I will probably only have to use these sockets one time, I found a set from Harbor Freight for less than $8.
