I'm using 6th much less lately
Old Sep 22, 2011 | 10:41 AM
mx597turbo's Avatar
mx597turbo
Default I'm using 6th much less lately
I've noticed I've been driving in 5th much more than usual lately. I recently got a sportbike, and my brother put 4.10s in his Stang. Both have great acceleration, even in top gear at 60mph. But the Vette feels dead below 80mph in 6th. Unfortunately, my mpg has gone down some. Then again, I notice I'm driving at about 2000rpm minimum lately.
Does anyone else reserve 6th for the open interstates?
Old Sep 22, 2011 | 10:56 AM
Grim Reaper's Avatar
Grim Reaper
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19
I don't use it either unless I'm on a road where the speed limit is above 70. In west Texas where it jumps to 80mph is when 6th really helps.
Old Sep 22, 2011 | 10:57 AM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Pretty sure that is what 6th gear is for
Old Sep 22, 2011 | 11:25 AM
BeanCntr's Avatar
BeanCntr
Default 6th
While I have an A4 ( wish I had the manual) I think the most fun is the abililty with a manual to be able to select a gear and downshift to the most appropriate gear for the situation. Also compared to the A4 you get immediate response/gratification of the cars abilities
Old Sep 22, 2011 | 11:37 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Maybe you need an automatic if you are having trouble shifting.
Old Sep 22, 2011 | 11:48 AM
Papas02C5's Avatar
Papas02C5
The only time mine gets into 6th is when I'm on the Interstate above 70mph
Old Sep 22, 2011 | 11:56 AM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Old Sep 22, 2011 | 12:29 PM
mx597turbo's Avatar
mx597turbo
I have no trouble shifting. What I'm saying is that I've been shifting a lot more lately, to keep the rpm > 1800. I've basically been treating the car like a 5 speed, only going into 6th above 75-80 mph.
When I first bought the car, I was fine putting around at 1500 rpm. But now that I've been in/on much more responsive vehicles (mainly due to gearing), 1500 just feels lethargic in the vette.
Just an aside, my brother is averaging about 9mpg with 4.10s in the stang.
Old Sep 22, 2011 | 12:41 PM
ronssito's Avatar
ronssito
I always go right up into 6th when on the freeway.
Old Sep 22, 2011 | 01:27 PM
TorchRedRocket's Avatar
TorchRedRocket
^ Wow, that is absolutely brutal.
I pretty much don't shift into 6th unless I'm > 60 mph, knowing that I will be cruising steadily for at least a couple of miles.
Old Sep 22, 2011 | 02:39 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Originally Posted by 8VETTE7
I drive mine in 6th any time I am above 45. But then us old geezers value the higher mpg's more than the lack of acceleration in 6th. If I need acceleration I down shift to the gear necessary for the situation.
here, here!! (actually i use mine above 50, but the intent is the same. i can get all the acceleration i need with a downshift to second gear and push on the gas pedal!!
Old Sep 22, 2011 | 02:45 PM
Dope's Avatar
Dope
Resident moron
Get 4.10s and 6th becomes a lot more fun. You'll still get about 3x as what the stang gets too.
Dope
Old Sep 22, 2011 | 02:49 PM
Dave68's Avatar
Dave68
It looks like you had/have an MX5. I think its final drive ratio is something like 4.56 - hugely different from that of a C5. With an MX5, winding the tach past 5000 rpm is far easier to do in the city. But that's why that car is so much fun in the city - not so much on the highway.
I shift into 6th at 70 MPH unless I have to "scoot" past someone.
Old Sep 22, 2011 | 03:37 PM
Tom/99's Avatar
Tom/99
I actually bought mine with the six speed manual, for the fuel economy.
Old Sep 22, 2011 | 06:21 PM
Cybermind's Avatar
Cybermind
I rarely use 6th gear. I find it's only useful on very long highway trips where you can maintain a constant 70 mph. But, that is what it was meant for. It also allows these cars to reach over 170 mph. But, for everyday driving, I find 6th gear not very useful.
Old Sep 22, 2011 | 06:29 PM
Kale's Avatar
Kale
6th has a bit of drone on my corsas, so I stay out of it... unless I'm flat/going downhill.
Pretty sure top speed is in 5th.
Old Sep 22, 2011 | 06:39 PM
TorchRedRocket
To I'm using 6th much less lately
red97vette's Avatar
red97vette
If you have a Z with the MN12 6th is a lot more useful. I can easily, and safely use 6th at 55 mph. On the coupe I had before, with the regular 6 speed, 6th was useless until you were at 70 at least...
Old Sep 22, 2011 | 06:45 PM
b.lee's Avatar
b.lee
I wait until at least 60mph for 6th.
Old Sep 22, 2011 | 06:53 PM
PRE-Z06's Avatar
PRE-Z06
4.10s will make 6th more usable and with the vette's double overdrive of .50 it doesn't kill mpg but ~2mpg on the highway. You'll just cruise in a higher gear around town and won't have to drop as many gears to pass someone.
