I have a 2003 Z06 with 50K miles on it; I bought it new. On the Z06, or any other car that I've owned, have I ever had broken valve springs. In the shops, I have never seen a vehicle in there for broken valve springs...but that's my experience.
I just don't understand why people even debate the valve spring issue on the 02-03 ZO6's. I mean...why would you even take a chance when it's so easy and cheap to replace them?
GM itself even acknowledged the fact that it was a problem. They just chose to do nothing about it.
A dropped valve will cause a ton of damage if it hits the top of a piston. I have seen this first hand on a buddies LS1 F-Body. This was when Comp was putting out bad springs back in the day.
I'll be doing the CompCams spring/pushrod/rocker bearings kit this winter...and doing plugs and wires "while I'm in there". No issues, but the car has 70K miles and sees 6500 RPM regularly...so I figure it just makes sense.
Yes..
$250 for psi max life springs. Work with stock retainers, seals, seats, and locks. Cheap insurance.
By far, a Z06 offers the best performance / reliability per dollar bar none.
Viper? Expensive, hard to find parts.
Porsche? No room to work on anything yourself and parts that cost a fortune.
Ferrari? LOL
Lambo? Double LOL.
While vettes may have some nagging issues, the cost to correct them is a pittance compared to anything else. Even if you spend the money to make it "bulletproof" you'll be into the car for THOUSANDS less than anything that comes close to matching it in terms of performance and reliability.
I'm starting to doubt the over all quality of GM's halo car. Trans and clutch are crap and apparently the springs should be changed to prevent your engine from going out.
I hope the C6 gen was built a lot better than our cars where.
I guess it's time to budget in a spring change as well now.
Price the engine/clutch/trans work you'd need to do on any other car with comparable performance and get back to us.
I did the valve springs on my car myself, materials cost was, what, a couple hundred bucks. What will that cost on, say, a 911 Turbo? And I can guarantee it will need it by 50k miles.
Go out and price headers for an M5 or 911. If the number is under $5k I'll be shocked.
Not sure where the trans and clutch comments came from. My stock clutch looked very clean when it came out at 50K+ miles. It came out because I needed to hold over 550whp. I suspect you'd be in the same boat with anything exotic as well.
So every few weeks I read about a C5Z that breaks a valve spring. I know a few guys are replacing theirs as preventive maintenance. I am curious how common these fail, and is this something that really needs to be replaced in advance on a stock car? How commonly do these fail?
What are people's stance on this?
I have a 2002 Z06 and after reading all the posts concerning valve spring failure- I decided to replace mine at 32 K miles. Completed the job several months ago- used PAC 1218 springs and new seals and retainers. I opted for the "rope method" but compressed air would have been fine.
My take - I guess I feel better, but I really think this issue is way overblown and there are RISKS involved in performing this "simple" job. This would be an "easy" job that could be easily screwed up with $$$ consequences.
I ended up ordering a set of the springs. I am getting some other work done on the car next week and I am going to have them swap them out while the car is at the shop. I am hoping after this last trip, the Corvette gods will be happy and keep me from spending any more cash for maybe 2K miles?!? I think I will be at over $4K in maintenance in my first 2 months of owning the darn thing. Granted about $600 of that is due to me royally screwing something up when trying to do the work myself. That is why the professionals will be doing the springs.
Move on, nothing to see here...
No need for me to answer your post directly as it's apparent you didn't read my posts afterwards.
I'll be doing mine before next Spring (2003 Z06). I have >60K miles on the stock springs now. They're toast but they did outlast 2 clutches... Wouldn't have broke my heart to drop a larger motor in if I had a good excuse.
I already said what I am going to do. Read my posts.
I plan to do them in a month or two when I have the cash. I've spent WAY too much on this car and I've owned it less than 2 months.
This was your last post...sounded like you were on the fence to me:
I just asked this question of Rich ( richierichz06 on the forums ) who works at Able Chevrolet which is a shop that specializes in Corvettes. I drive 200 miles to get my car serviced by them. He is also a prior owner of a C5 Z06 and current owner of a C6 Z06. He said that in all of his years of working at Able and at another Chevrolet dealer, he has seen a single valve spring failure ever. He said he works on countless race cars, etc...and only one failed ever. He said he didn't want to tell me not to swap them out just in case they did fail, but his attitude is that the failure rate is maybe 1 on 2,500 cars.
Keep us posted, not sure if the shop can provide a view on what condition the original springs were in.
Ed
I just replaced my OEM yellow springs (2002 Z06). I looked at them with 10X magnification and didn't see any signs of cracking, etc. When they go, it's probably pretty quick, and doubt you'd ever see anything unless dye penetrate or similar process was used to investigate.
Yeah that's my assumption as well. I bet they go almost instantly.
got a call from the shop. looks like I got lucky and it's just the valve spring that's broken. i should have the car back just in time for next week's trackday!
