[Z06] Valve Springs Preventive Replacement?
I am now a believer in just replacing them as PM. All appears good, but just one spring broke (1st cyliner on right second lifter in). see my post running now
Thanks for any help
Changing the valve springs is pretty easy.
1. Disconnect battery
2. Remove Fuel Rail Covers (FRC's)
3. Remove plug wires and plugs.
4. Remove coil packs and brackets.
5. Remove valve cover.
6. Remove rocker arms and push rods. (keep them in order and put them back exactly where they came from)
7. Thread air holding tool into spark plug hole of the cylinder of the first two valve springs you wish to remove.
8. Attach air compressor line to air holding tool at which time the cylinder will immediatley pressurize with air.
9. With a rubber or plastic mallet, give a couple light taps to the top of each valve spring your removing. This helps break the valve keepers free.
10. Using the valve compressor tool (depeding on which one you have), begin compressing the valve spring down over the valve stem.
11. Have a good magnet ready to catch the valve keepers from falling as the spring compresses down.
12. Once the keepers are removed and in a safe place, start decompressing the valve spring and remove it off of the valve.
13. Remove the retainer off of the old spring and put it on top of the new spring.
14. Put the new spring over the valve and reattach your valve spring compressor and begin compressing the new valve spring.
15 Once the spring is compressed, reinstall the valve keepers. Be very careful not to drop the keepers. It helps to use vasoline to help hold the keepers into the groove in the valve stem.
16. Once the keepers are in place, you can slowly start decompressing the valve spring. Make sure that the keepers stay in place and once the spring is fully decompressed, remove your tool.
17. Give the top of your valve springs a couple of light taps to ensure the valve springs are properly installed and the keepers are secure.
18. Repeat the process (one cylinder at a time) until you have replaced all 16 valve springs or you have completed one side of the engine...however you want to do it. I did it one side at a time.
19. Reinstall your pushrods and rocker arms and torque to 22 ft/lbs.
20. Check everything over and recheck...and recheck.
21. Pour a small amount of motor oil over all the new valve springs and rockers. This will help with lubrication on intial start up.
22. Reinstall valve cover, coil pack bracket and coild packs.
23. Reinstall plugs and wires. (good time to install new ones if needed).
I bought the comp 918 springs and the average install is $300. $500 total. Not only do I not worry anymore but the valvetrain noise at idle is much quieter.
I also have the Proform tool #67605 on the way.
http://www.jegs.com/i/Proform/778/67...ductId=1631816
I have read that many have used and liked the Proform spring compressor. You shouldn't have any problems.
Thanks for your help,
Sid
http://forums.corvetteforum.com/c5-t...reinstall.html
You guys doing the valve spring replacement ... use the search function, as there are about 20 threads that talk about how to do the swap-out.
I tend to think that people get so paranoid when working on their own engine because it's a "Corvette". It's pretty much the same old LS engine that GM put's in about every vehicle that has a V8 option. Just different configurations and HP levels. All LS engine family.
Maybe it's just me... but swapping out some valve springs on a C5 ZO6 is easier that swapping spark plugs on a 4th get F-Body any day of the week.
Don't over think it and just do it.
The question I have is, will GM performance parts #12499224 for $60 fix the problem just as well as $190 PAC 1218 springs will?
If I understand correctly, the problem was caused by a bad batch of springs from the supplier in the 2002 ~ 2003 time frame. So new GMPP springs should ensure I don't have one of the bad springs.
I'm not looking to install a higher lift cam, and I don't race the car, so what benefit would the PAC springs give me for the extra $130?
I'm not adverse to spending the extra money if there is any tangible benefit, but if new GM parts will solve the problem, that extra $130 will pay for the spring compressor, new valve seals, and beer.
Here's some PAC 1218s for $165 to your door (free shipping over $100).
http://www.speedinc.com/cont.cfm?cid=C0000794
I went for the PAC 1518s ... a few extra bucks is worth the insurance that they will be reliable and long lived for me.
http://www.carshopinc.com/index.php
$147.00 to the door and ordered at 4:50 pm and got the next day
Sid
I have done it several times and I have never had an issue with the rocker arms with just torquing them down on one pass. I use red lock tight on them and torq them to 22 foot pounds and enjoy the car with a better feeling, because I am confident that my new springs will not snap.
