Getting used to Skip shift
Old Oct 20, 2011 | 11:37 PM
chasboy's Avatar
chasboy
Oldtimer
Default Getting used to Skip shift
The previous owner of my Z gave me a new CAGS eliminator with the car. I thought for sure I would use it, but now, as I'm getting used to the car, I don't think I want to bother installing it. Anyone feel similar??
Old Oct 20, 2011 | 11:51 PM
striper's Avatar
striper
NO! Get stuck one day on Rt.10 going west in rush hour and you'll wish you installed it. It's very easy and only takes a few minutes, surprised the original owner didn't out it in. If you get a tune they can tune it out instead and get rid of the shift light too.
Old Oct 20, 2011 | 11:53 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
You got it, Install it.
Old Oct 21, 2011 | 12:17 AM
jsbzoh6's Avatar
jsbzoh6
Install it. Trust me.
Old Oct 21, 2011 | 12:21 AM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
Yep, it's an easy install and will just eliminate ANY need to ever even think about when YOU want to shift regardless of RPMs or speed.
DO IT!!!
Old Oct 21, 2011 | 12:32 AM
chasboy's Avatar
chasboy
Oldtimer
Ok ok! Is the module located towards the rear of the car?
Old Oct 21, 2011 | 01:26 AM
woodman300's Avatar
woodman300
St. Jude Donor '15
it was easy. 2. To gain access to the CAGS solenoid, raise your Corvette as directed by the GM Shop/Owners Manual. Be sure to follow all safety precautions and use jack stands to support the vehicle.
3. The CAGS solenoid is located on the drivers' side of the transmission towards the top and rear of the transmission. The wiring harness connector is white and blue in color.
4. Gently lift the locking clip and unplug the connector from the solenoid. Make sure the connector and solenoid are clean. Plug the long grey end of the CAGS Eliminator into the wiring harness. You should hear a snap/click sound when the wiring harness is completely seated. Plug the short blue/grey end of the CAGS Eliminator into the CAGS solenoid. You should hear a snap/click sound when the connector is completely seated.
got that from the website that sells them. it took just a moment to put it in. i already had the car up to change out the transmission fluid. it is really nice to shift when i want to.
Old Oct 21, 2011 | 07:52 AM
chasboy's Avatar
chasboy
Oldtimer
Originally Posted by woodman300
it was easy.
I already have one, I just need to raise the car. Time for ramps I guess....
Old Oct 21, 2011 | 08:43 AM
Highpower500's Avatar
Highpower500
Very glad that I installed mine. It was very easy to do.
Old Oct 21, 2011 | 09:07 AM
DarkBlueC5's Avatar
DarkBlueC5
install it, you will be happy. Use ramps or just jack it up, takes 3 minutes.
Old Oct 21, 2011 | 09:10 AM
4 KRUSIN's Avatar
4 KRUSIN
Don't leave home without it.
Old Oct 21, 2011 | 09:17 AM
hammerdwn's Avatar
hammerdwn
You don't need ramps. Jack the rear of the car. Make sure to chock the the front wheels and use jack stands. It will only take a minute to install and is worth it. It was the first mod i did on my vette.
Let us know how you like it!!
Old Oct 21, 2011 | 11:54 AM
justanotherdoe's Avatar
justanotherdoe
I took mine out about a year ago while troubleshooting a short circuit/fuse blow issue. I've never put it back, and don't miss it.
btw, the cags was not the source of my problem. Worn insulation on the harness going to the reverse lock-out solenoid was my cause.
Old Oct 21, 2011 | 12:33 PM
johnson-rod's Avatar
johnson-rod
The first time you get stuck in snow or ice and you NEED to shift smoothly at low RPM you will wish you had it.
Old Oct 21, 2011 | 12:49 PM
Cybermind's Avatar
Cybermind
It's one of the most useful mods (besides a CLB) that I've installed. I still can't believe how stupid the whole CAGS thing is.
Old Oct 21, 2011 | 12:59 PM
poppyboy's Avatar
poppyboy
I haven't installed one. I just rev a little higher and the light goes out-simple shift into 2nd.
Old Oct 21, 2011 | 01:13 PM
Papas02C5's Avatar
Papas02C5
The CAGS Eliminator was the very first mod I installed on my car. Best $20 and 10 minutes to install I ever spent
To Getting used to Skip shift
Old Oct 21, 2011 | 02:17 PM
oh1vette's Avatar
oh1vette
Had mine tuned out
Now I decide if I wanna skip a gear....
Old Oct 21, 2011 | 02:21 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
YES, I feel the same as you. it was the first thing I bought for my car but I figured out how to shift around the CAGS within hours of owning the car. I still installed the eliminator (since I'd already paid for it) and have since had the cags tuned out but it was not needed. I really think there is far too much negative attention for a really minor annoyance on this car. enjoy the Z
Old Oct 21, 2011 | 05:01 PM
Highpower500
A lot of guys say you don't need the eliminator because all you have to do is increase the RPMs. This is true, and it is what I did on open roads before I installed mine. However, the CAGS was a real PITA at times in trafffic. This is where I found the most value for the eliminator.
