Head light aim
Old Oct 27, 2011 | 12:28 AM
chasboy's Avatar
chasboy
Oldtimer
Default Head light aim
I just replaced my headlight bulbs, but the left seems to be aimed very low and I have no idea where the right one is aimed. Anyone with an idea??
Old Oct 27, 2011 | 01:19 AM
Jistari's Avatar
Jistari
http://forums.corvetteforum.com/c5-g...djustment.html
Might want to investigate that link at the top of the page....the search one, click on it...select advanced search...and type in what you need to know )"headlight adjust").
Many questions come up over and over and search may help ya get the answer without waiting for someone to reply.
Just a thought.
The link above has what you're looking for.
Enjoy
Old Oct 27, 2011 | 01:42 AM
DeeGee's Avatar
DeeGee
Assuming you have stock lights, it's probably either the bulb that's unseated or the headlight unit incorrectly mounted in the cradle. Are both lights out of true? If so, its probably the latter. If its only low beam thats out, concentrate on the bulb for starters.
Here's a How To I put out a while ago which might help.
Aiming Stock Headlights
Preparation
Chose a white wall to project the lights onto
Mark a vertical centreline on the screen in line with the center of the car (black tape?)
(look over the roof of the car to get the line)
Measure the height from the floor to the center of the headlight capsule
Mark a horizontal aiming line on the screen
Measure the distance between the centreline of the right headlight module and the center of the left headlight module.
Position the vertical tapes this distance to the right and left of the screen centreline
Lubricate the adjustment screws before adjusting See Note
Adjustments
Raise the hood
Raise the headlights
Remove the headlamp adjustment screw plug
Turn on the low beam headlights and block the light from projecting onto the screen from the passenger headlight
Check the horizontal aim
Adjust the horizontal aim adjusting screw to align the left edge of the high intensity zone with the headlight vertical centreline
The left edge of the beam should lie within 4” to the left and 4” to the right
of the vertical centreline.
Check the vertical aim
Adjust the vertical aim adjusting screw to align the top edge of the high intensity zone with the headlight horizontal centreline
The left edge of the beam should lie within 2” above and 2.5” below the lamp horizontal centreline.
Reinstall the headlamp adjustment screw plug
Repeat for the other headlight
Turn off the lights and close the hood
This is the pattern you're looking for
Advice Frome LonestarFRC:
Lubrication may not be enough. The problem is that the spray can't actually penetrate to where it's needed. There's a little internal gear-drive mechanism involved.
Important! If you attempt to make any adjustments, especially one involving the up/down adjuster and it doesn't move, or you meet a lot of resistance, stop right there. Do NOT attempt to force things. You will ABSOLUTELY break the long "goldenrod' (gold colored rod about 3" long). This is not an "if" or "maybe". Do NOT force it by twisting your wrench/nut-driver harder and harder. Once broken, these pieces are NOT available as a separate repair piece from GM. They will only sell you the entire headlight assembly.
If yours are frozen up, do a search on this issue. Many many posts about it. "Goldenrods" is one if the terms that may be helpful when doing a search. There IS a way to unfreeze the gear-drive mechanism but it involves removal of the headlight assembly to get access.
You can see how the bulbs fit into the headlight unit in this picture (thanks to Junkman for the pic)
Old Oct 27, 2011 | 02:14 AM
chasboy's Avatar
chasboy
Oldtimer
I need to see if they are unseated. I don't remember the original bulbs being so out of whack. I have very little distance view. The left bulb is focused on 15 feet in front of the car and I have no idea where the right one is 'aimed'.
Old Oct 27, 2011 | 02:17 AM
DeeGee's Avatar
DeeGee
There are 3 bolts that hold the headlight unit into the cradle. While you're in there, check that they are tight.
If both lights are out it may just be that they are badly adjusted. 15 feet is still way too close. It'll be obvious where they're aimed when you point them at the garage door (or whatever you use).
Make sure you lubricate the adjusting rods before playing with them.
Old Oct 27, 2011 | 10:02 AM
Great information - saved this for future use.
Old Oct 27, 2011 | 10:12 AM
chasboy's Avatar
chasboy
Oldtimer
I only replaced the low beams-the highs are fine, which made me suspicious of my installation. It's a bit dicey for a first timer, especially the hysterical warnings: DON'T TOUCH THE BULB!!. I think I will remove the unit so I can see what I'm doing.
Old Oct 27, 2011 | 12:52 PM
chasboy's Avatar
chasboy
Oldtimer
Just rechecked in the rain. They were both seated improperly. I am glad they did not move around. I don't have a garage door, so I pointed them towards the rear bumper of my white car and they line up much better.
Old Oct 27, 2011 | 01:00 PM
DeeGee's Avatar
DeeGee
Good that you fixed it
Old Oct 27, 2011 | 05:10 PM
chasboy's Avatar
chasboy
Oldtimer
I hope!!! Where did you get that cool avatar??
Old Oct 28, 2011 | 01:34 PM
DeeGee's Avatar
DeeGee
He'll do your car if you wish. PM me and I'll dig out the link
Old Oct 28, 2011 | 08:20 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
What is the distance of the screen to the car( headlights)?
Old Oct 28, 2011 | 08:42 PM
chasboy's Avatar
chasboy
Oldtimer
dunno, you didn't tell me!
Old Oct 28, 2011 | 08:43 PM
chasboy's Avatar
chasboy
Oldtimer
Actually, I'm interested in those dotted lines....
Old Oct 28, 2011 | 09:00 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
I would bet money one of your bulbs are not seated right, It is a pain to get them installed right, It took me a few trys before I got mine mounted right.
Bill
Old Oct 28, 2011 | 09:32 PM
chasboy's Avatar
chasboy
Oldtimer
Originally Posted by Mr.Bill
I would bet money one of your bulbs are not seated right, It is a pain to get them installed right, It took me a few trys before I cot mine mounted right.
Bill
I'll back your money!!!
Old Oct 29, 2011 | 12:47 AM
Jistari's Avatar
Jistari
I bent the crap outta the little metal fingers that surround the mounting hole on the last halogen swap I did before I went to the HID projectors. I didnt even know it until I disassembled it all to do the swap, I never would have understood what was bent by feeling around in there.
Come to think of it, when I first got the car the lights were aimed rediculously low and they werent aimed alike, so maybe some of the bending was prior to my ownership.
Anyway, its not really a lot of work to take the carriers out or to disassemble enough to actually see what your doing in there. Might as well get it straightened out now so future bulb replacement wont aggravate ya.
Good luck
Old Oct 29, 2011 | 07:48 AM
chasboy's Avatar
chasboy
Oldtimer
Thanks, now if Mother Nature would do me a favor, I might find out for sure...
Old Nov 6, 2011 | 05:16 PM
chasboy's Avatar
chasboy
Oldtimer
My left low beam is still not correct. A long backroad ride last nite confirmed it. It's aimed way down in front/middle of the car, while re-installing the right beam corrected the aim. I will try AGAIN to reinstall the left, but if not, should I just re-aim the light? At this point I don't remember WTH the original aim was like.
I reinstalled the left low beam, used mirror and gooseneck light to be sure it was seated properly. THEN I aimed that light. It was way off according to DG's directions. Took a ride this evening and much better now, tho' I still don't think the lights are the greatest after all.
To Head light aim
