Overrevving engine
Old Oct 29, 2011 | 11:03 PM
Nick_D's Avatar
Nick_D
Default Overrevving engine
Funny question... What would happen to your engine if you accidentally shifted into second gear instead of fourth at about 100 mph? I have a 2000 corvette and I made that mistake. The engine is making a bad clicking sound now. It gets worse the higher RPMs you go.
Old Oct 29, 2011 | 11:06 PM
Trios's Avatar
Trios
8500 RPM assuming a coupe with stock tires.
Old Oct 29, 2011 | 11:07 PM
alankb's Avatar
alankb
Default Ouch
You probably broke a valve spring or bent a pushrod. Hopefully it is something in the top end.
Old Oct 29, 2011 | 11:09 PM
Nick_D's Avatar
Nick_D
How much would it cost to repair a valve spring or pushrod? Thanks for the help!
Old Oct 29, 2011 | 11:10 PM
rebelheart's Avatar
rebelheart
Old Oct 29, 2011 | 11:16 PM
ZeeOSix's Avatar
ZeeOSix
Someone needs to remove the valve covers, then remove the rocker arms and pushrods for inspection before it's ran anymore.
It would probably cost about $800~$900 to replace all the pushrods and valve springs, including parts and labor.
PS - when shifting from 3rd to 4th, DO NOT pull the shifter to the left!
Old Oct 29, 2011 | 11:20 PM
Nick_D's Avatar
Nick_D
Haha oh yeah I learned my lesson! Thank you so much for your help!!!!! I have some work to do now.
Old Oct 29, 2011 | 11:23 PM
Trios's Avatar
Trios
http://www.shortshifter.com/techniques2.htm
Old Oct 30, 2011 | 12:11 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
As others have said, Pull the valve covers and take a look, Don't drive the car anymore. If you are lucky all you did is broke a spring/Push rod.
Good luck with the repairs, Keep us posted on what you find.
Mr.Bill
Old Oct 30, 2011 | 12:23 AM
Z06ster's Avatar
Z06ster
I wish the OP good luck with the repairs. I thought however that the rev limiter was supposed to protect against stuff like this. I guess it can't help in all cases.
Old Oct 30, 2011 | 12:27 AM
Mr.Bill's Avatar
Mr.Bill
The limiter will work on a throttle rev, But not on a mechanical rev.
Old Oct 30, 2011 | 12:29 AM
Tastee Twirl's Avatar
Tastee Twirl
LIFE IS SHORT HAVE FUN
St. Jude Donor '12-'13-'14-'15-'16-'17-'18
Glad no BOOM LOL
Old Oct 30, 2011 | 01:49 AM
alankb's Avatar
alankb
Default Rev limiter
It can't help in this situation. It would have to disengage the trans or something. Not possible.
Old Oct 30, 2011 | 08:52 AM
killain's Avatar
killain
Oldtimer
Default Over the top. . .
Mr.Bill
100% but I'll add one thing, label the push-rods so they go back in the lifters in the right order. Block is pretty tough, I would doubt if the lower end is damaged, but like others have said, Do Not Use It Till it Can Be looked Over By a GM Master technician !
And you'll want to drain the oil and replace the drain plug with a magnetic one. Hope all turns out well for you.
Old Oct 30, 2011 | 09:46 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
You will be very lucky if it's not bent valves
Old Oct 30, 2011 | 10:00 AM
Vato's Avatar
Vato
I did that at about 80 soon after I got the car new in 2000. No problems, but a little embarrassed. No weird noises either, so I bet you bent a push rod or broke a spring. Good time to upgrade to hardened push rods and springs. I did this years later on when I had a spring break on me. Not that expensive.
Good Luck!
Old Oct 30, 2011 | 12:21 PM
printmanjackson
if you bent a pushrod, the valve had to hit something! They don't just bend
To Overrevving engine
Old Oct 30, 2011 | 01:44 PM
ZeeOSix's Avatar
ZeeOSix
Originally Posted by Trios
They have some of their wording backwards in some of the examples.
Old Oct 30, 2011 | 02:33 PM
Vato's Avatar
Vato
Good Point.
Old Oct 30, 2011 | 03:06 PM
Nick_D's Avatar
Nick_D
My car is actually at the dealer right now. I was definitely not going to drive it with that sound in the background. So far they still don't know the issue but one of the guys thinks its bad lifters. Tomorrow I should know exactly whats wrong with it. Thank you all for the help, I've been pricing pushrods, springs, and lifters.
