[Z06] 315s wheel hop know!
Old Dec 3, 2011 | 09:59 AM
magnoman's Avatar
magnoman
Default 315s wheel hop know!
I went to 315 s Pilot Sports and wheel hop is horrible .. I had 295 Vredestein tires and had no wheel hop and better grip than the 315s.
also the 315s seem to jerk me around more on uneven road surface ?
Could the additional tire width cause this? or the Tire brand it self ?
Think I am going back to the Vredestein's!!
Old Dec 3, 2011 | 01:58 PM
zeevette's Avatar
zeevette
I don't know if I can help with those specific brands, but just as a general rule; the better the traction, the less the wheel hop.
Old Dec 3, 2011 | 03:15 PM
MTPZ06's Avatar
MTPZ06
Have 295 PS's...they grip good and they don't wander on me. 315 might have been a bit too wide for your rim and is allowing more side wall flex? How much air pressure are you running? You may be over inflated. Try to be somewhere between 28-30 psi cold and see if that makes a difference.
Old Dec 5, 2011 | 02:15 PM
PRE-Z06's Avatar
PRE-Z06
You have a little less sidewall now to absorb harmonices...same tire psi, air temperature and road surface?
Old Dec 5, 2011 | 07:41 PM
Paul 75 L82's Avatar
Paul 75 L82
I have the 315 PS2's and have no wheel hop what so ever. They are hooked up all of the time.
To 315s wheel hop know!
