Techron concentrate
Old Dec 19, 2011 | 04:42 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Originally Posted by chasboy
What is with some of you people? I responded to your post with a question, and you can't answer it? Instead you 'default' to 'newbie go to search' so you don't have to type too much? I DID a search after your kind 'recommendation' and found nothing to explain why Techron is needed. The only answer I got was from JMRose.
Here Charlie...http://forums.corvetteforum.com/c5-g...post1579487890
post #16 in particular
Old Dec 19, 2011 | 05:16 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Originally Posted by SCM_Crash
If you have half a tank, pour all of the bottle in and fill the tank completely. It will mix.
Don't start separating parts based on how much gas is in your tank. The reason they tell you to pour it in first THEN fill up is so that people don't over fill their tanks.
If you're half down, empty the bottle into the tank and fill up. it's that simple.
That was the way I was thinking about going, just want to see what others had to say. Thanks
Originally Posted by Yello95
...and also never let your tank/s run below 1/4 or you will burn up your fuel pump eventually...the gas keeps the pump cool...you can put in Techron anytime...so if you use the large bottle put it in first or closer to last(easier to put it in first rather than last)...it all gets constantly mixed from tank to tank...
and what SMC said in red...
I normally fill up around the 1/2 tank.
Old Dec 20, 2011 | 12:01 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Me too(with 93 octane)
oh.btw...I bought 6 more bottles(and got 6 more free bottles) of Techron today
Old Dec 20, 2011 | 05:48 AM
4SFED Z's Avatar
4SFED Z
Originally Posted by D&A'sDad
Is it not easier/wiser to just use Chevron 93 w/techron in the blend??
Use BOTH.
CHEVRON FOR THE WIN!
Old Dec 20, 2011 | 05:52 AM
chasboy's Avatar
chasboy
Oldtimer
Not much Chevron around here.
Old Dec 20, 2011 | 07:02 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
None here...the only time I get to use Chevron/Texaco is when traveling up the Eastern Shore and further through Yankee States above Va
Old Dec 20, 2011 | 09:38 AM
Vettmann17's Avatar
Vettmann17
What's Techron?
Only kidding, thanks for the heads up, I've been meaning to get a few bottles. Merry Christmas!
Old Dec 20, 2011 | 10:26 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Originally Posted by Vettmann17
What's Techron?
heheMC back atcha
here grasshopper...Techron at its best
http://www.funnyordie.com/topic/techron
Old Dec 20, 2011 | 10:56 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
It does the trick in the fuel sensor. I was out with a group on Saturday and the gauge went to empty and I got the Low Fuel warning. Went out to do last minute shopping and stopped at the Shel I always go to, added a bottle topped off the tank and as soon as I started the car up the sensor was clear and all is good again.
Old Dec 20, 2011 | 11:03 AM
VETJAZZ's Avatar
VETJAZZ
Added a bottle to all 3 cars last week.
Old Dec 20, 2011 | 11:50 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Its a Christmas miracle...no, seriously
Old Dec 20, 2011 | 01:52 PM
chasboy's Avatar
chasboy
Oldtimer
I LIVE in Yankee states, and can't find Chevron.(btw, underline is to mimic Yankee Pinstripes)
BTW, I checked Costco today. They have Chevron 'Pro Gard" "WITH' Techron. Didn't seem like the same product you all have discussed.
Old Dec 20, 2011 | 02:20 PM
  #33
Evil Oil Apologist's Avatar
Evil Oil Apologist
I'm just posting up here and waiting for an ethanol fight to break out.
Wait! That's in another thread? Sorry. My bad. Peace. Out!
Old Dec 20, 2011 | 02:50 PM
  #34
RAM1953's Avatar
RAM1953
4th Gear
It is the same product - I used to work fro Chevron and have used in every car since the day I purchased them, especially in my 2002
Old Dec 20, 2011 | 03:04 PM
  #35
jesse99's Avatar
jesse99
3rd Gear
Default why do we need techron in the fuel
The fuel level sensor in the fuel tank gets a layer of varnish /corrosion build up on it. This comes from the fuel additives, or fuel that has poor additives and is poor quality. One way to fix or prevent this condition is to put 20 ounces of TECH RON fuel additive in the tank at least every other fill up which will help to clean the build up off the fuel level sensor.
Old Dec 20, 2011 | 03:06 PM
  #36
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
Does Evil Twin use this stuff
Old Dec 20, 2011 | 03:07 PM
  #37
chasboy's Avatar
chasboy
Oldtimer
Originally Posted by RAM1953
It is the same product - I used to work for Chevron and have used in every car since the day I purchased them, especially in my 2002
I'm not trying to doubt you, but I found 2 links that state otherwise....confusion is my friend.
http://forums.corvetteforum.com/c5-g...ncentrate.html
http://www.nissanforums.com/truck-su...ntrations.html
how often do you use it?
To Techron concentrate
Old Dec 20, 2011 | 03:35 PM
  #38
mfile2000's Avatar
mfile2000
Originally Posted by 94centennial
don't have a Chevron station in my area.
Old Dec 20, 2011 | 03:39 PM
  #39
mfile2000's Avatar
mfile2000
"Some of YOU people"? and thats supposed to mean what?...some day grasshopper you will learn that since you have been here a measley 4+ months and you have asked a question/topic that has been discussed thousands of times previously...a search on "Techron/additive, etc. will lead you to dozens of threads telling you why you should use Techron...Even GM recommends and sells Techron with their name on the bottle...practice on more searching before you get your panties in a bunch
I disagree. Forums are for discussions and exchanges of ideas. Databases are for searches. Wiser people than me told me this.
Old Dec 20, 2011 | 07:14 PM
  #40
Yello95's Avatar
Yello95
St. Jude Donor '11
oh goodie goodie gumdrops..its your right to disagree...now go back to doing what you do best...analyizing(Occupation, Analyst) ....
