Techron concentrate
Old Dec 18, 2011 | 08:19 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Default Techron concentrate
OK people...just a reminder to stock up on Techron concentrate at Advance Auto...buy one large bottle at $12.99 and get one free
I got mine
Old Dec 18, 2011 | 08:23 PM
Dave68's Avatar
Dave68
Now THAT'S a good deal.
Old Dec 18, 2011 | 08:36 PM
WvCorvette's Avatar
WvCorvette
Old Dec 18, 2011 | 08:40 PM
chasboy's Avatar
chasboy
Oldtimer
Why do we need it?
Old Dec 18, 2011 | 08:50 PM
02HREBlue's Avatar
02HREBlue
Costco now sells boxes of Chevron Techron. Just picked one up
Old Dec 18, 2011 | 09:07 PM
Thanks for the reminder - I need to get down there and pick up a couple of bottles.
Old Dec 18, 2011 | 09:21 PM
jrose7004's Avatar
jrose7004
O'rielly has that deal most all the time here.
Old Dec 19, 2011 | 07:33 AM
D&A'sDad's Avatar
D&A'sDad
Is it not easier/wiser to just use Chevron 93 w/techron in the blend??
Old Dec 19, 2011 | 07:43 AM
94centennial's Avatar
94centennial
Default No Chevron
don't have a Chevron station in my area.
Old Dec 19, 2011 | 09:31 AM
jrose7004's Avatar
jrose7004
Originally Posted by chasboy
Why do we need it?
To help with keeping you gas gauge functioning properly.
Old Dec 19, 2011 | 10:07 AM
76 VETTE's Avatar
76 VETTE
Old Dec 19, 2011 | 03:03 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Why do we need it?
Nice try noob...search is your friend...anyhoo..........
Of course it would be easier...if they still sold Chevron or Texaco in Virginia...but they don't...
To the rest of you cool guys....
Old Dec 19, 2011 | 03:57 PM
SCM_Crash's Avatar
SCM_Crash
I only fill up with Chevron and Shell (Chevron 90% of the time).
When I bought my car current I used 1 bottle of Techron just to be safe. Aside from that I haven't needed it. I used it all the time in my 02 Z, though, but I was just being paranoid.
Old Dec 19, 2011 | 04:04 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
You lucky left coast paranoid bastich...may a heavy coat of sulfur build up on your *********
You haven't needed it?...Look...sulfur has encapsulated your entire car...
Old Dec 19, 2011 | 04:11 PM
SCM_Crash's Avatar
SCM_Crash
Lmao!
Old Dec 19, 2011 | 04:12 PM
chasboy's Avatar
chasboy
Oldtimer
What is with some of you people? I responded to your post with a question, and you can't answer it? Instead you 'default' to 'newbie go to search' so you don't have to type too much? I DID a search after your kind 'recommendation' and found nothing to explain why Techron is needed. The only answer I got was from JMRose.
Old Dec 19, 2011 | 04:17 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
OK, I have a question on this. It just so happens yesterday I got the Low Fuel Warning and the gauge went to zero. I need to change the oil so I pickup the buy one get one free. These bottles are 20 oz and it says to pour the entire bottle in to a near empty 20 gal tank and then fill up. Well I had a bout 3/4 of a tank before I went out yesterday and the trip most likely got me close to a 1/2 tank. Should I only use half a bottle and see if that clears it or the whole bottle?
To Techron concentrate
Old Dec 19, 2011 | 04:21 PM
SCM_Crash's Avatar
SCM_Crash
If you have half a tank, pour all of the bottle in and fill the tank completely. It will mix.
Don't start separating parts based on how much gas is in your tank. The reason they tell you to pour it in first THEN fill up is so that people don't over fill their tanks.
If you're half down, empty the bottle into the tank and fill up. it's that simple.
Old Dec 19, 2011 | 04:25 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
"Some of YOU people"? and thats supposed to mean what?...some day grasshopper you will learn that since you have been here a measley 4+ months and you have asked a question/topic that has been discussed thousands of times previously...a search on "Techron/additive, etc. will lead you to dozens of threads telling you why you should use Techron...Even GM recommends and sells Techron with their name on the bottle...practice on more searching before you get your panties in a bunch
Old Dec 19, 2011 | 04:31 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
...and also never let your tank/s run below 1/4 or you will burn up your fuel pump eventually...the gas keeps the pump cool...you can put in Techron anytime...so if you use the large bottle put it in first or closer to last(easier to put it in first rather than last)...it all gets constantly mixed from tank to tank...
and what SMC said in red...
