spark plug change
That's interesting about the heat transfer changes; I honestly never heard about that.
Use dielectric grease on the new wire boots, use a q-tip to swipe the inside of the boot, the heat shield transfers to the new plug wire.
A standard 3/8 drive with GM spark plug socket and one extension and one swivel.
To get to the driver's side, remove the AIR valve there are two 10 mm bolts attaching it. Disconnect the hoses and then rotate the valve out of the way.
Blow out the plug area with compressed air first then remove the plug. No, on the WD 40.
You will need a 3/8 torque wrench generally a micro torque is good. Torque the plugs (15Nm).
I prefer to use aluminum anti seize on the plugs, some have different opinions.
Some say use a piece fuel hose on the tip to start the plug, but I prefer to use my fingers and start it, that way I have immediate feedback of how the plug is treading. Start it gently and let it thread, don't force it.
Generally the plugs coming out may be stiff, but the new plug going in should hand thread easily.
Wires are all the same. When installing them on the plug be sure you hear a definitive snap or click.
When removing the wires, don't worry about them a good pair of channel grip pliers will help remove the wire from the plug. It rotates 45°s and pull. Same on the could side. But they won't be the problem. Like I said don't worry about the wires when removing them, you have a new set to install. Never had any luck with those wire puller pliers, and I have two sets. Channel grip pliers work great. Be careful what you pivot against.
You may come across one or two that you swear are not coming off, all I can suggest is trying less brute force and concentrate on the procedure, rotate while pulling. And one time it will pop free.
It's a good time to clean things up as well, while you have the FRC off, compressed air works great to remove the built up material around the intake manifold.
Fender covers are nice, protect you from leaning and scratching them.
There's a power plant engineering paper floating about on this subject about torque and plugs, proper torque ensures the designed heat transfer. I also think the plug shank is steel and its threading into aluminum, so proper torque is important there too.
True there is a wet torque and dry torque, but I think at these torque values (15Nm) it probably doesn't vary much.
Just making an assumption, either you tried with the shield already on and did not get a good seat hence the misfire or it wasn't a good seat to begin with and when the shield is pressed on the wire is still not fully engaged.
That snap is obvious when it fully seats.
Also, there is copper anti-seize and aluminum anti-seize. I would recommend aluminum anti-seize.
plus I use a 4" piece of vacuum hose to start the plugs, fender covers and drive on ramps to reduce the back bend. Good luck.Okie
Glen
