spark plug change
Old Dec 26, 2011 | 05:12 PM
red89c4's Avatar
red89c4
Default spark plug change
what do you use for the spark plug threads, oil or anti seize lube?
03 LS1
Old Dec 26, 2011 | 05:15 PM
rbrumm's Avatar
rbrumm
Anti-seize.
Old Dec 26, 2011 | 05:17 PM
TOPCATHR's Avatar
TOPCATHR
Not required or recommended, but i use antiseize
Old Dec 26, 2011 | 05:57 PM
Jet-Jock's Avatar
Jet-Jock
aluminum anti-seize.
dielectric grease on the plug boots.
and torque the plugs!
work on cold engine, blow out plug area with air before removing each plug.
remove valve on drivers side, 2 10mm bolts and rotate out of way makes it much easier.
Old Dec 26, 2011 | 08:47 PM
ROJ#79's Avatar
ROJ#79
Originally Posted by rbrumm
Anti-seize.
Old Dec 26, 2011 | 08:55 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Anti-Seize, a light amount on the threads - use a old spark plug boot to start the plug in the hole and to handle it easily!
Thanks,Matt
Old Dec 26, 2011 | 09:28 PM
leebay's Avatar
leebay
Anti-seize.
Old Dec 26, 2011 | 11:10 PM
I use anti-seize on mine.
Old Dec 27, 2011 | 01:49 AM
itzza427's Avatar
itzza427
Another anti-seize and dielectric on the boot here as well!!
Old Dec 27, 2011 | 03:57 AM
Grim Reaper's Avatar
Grim Reaper
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19
Same here.
Old Dec 27, 2011 | 04:10 AM
DeeGee's Avatar
DeeGee
Another for anti seize
Old Dec 27, 2011 | 09:36 AM
Oldvetter's Avatar
Oldvetter
Anti-seize made for electrical sensors (overkill but makes me feel good).
Note that the Service Manual says to use nothing !
Old Dec 27, 2011 | 10:28 AM
striper's Avatar
striper
Anti-sieze again!
Old Dec 27, 2011 | 04:47 PM
m6 c5's Avatar
m6 c5
Small drop of oil on the threads to ease with the install and thats it for me.
Old Dec 27, 2011 | 07:05 PM
Autoworker's Avatar
Autoworker
The last plug change I used nothing. At 11nm torque, it's not like you're cranking them in there.
Old Dec 27, 2011 | 10:50 PM
robert miller's Avatar
robert miller
Old Dec 28, 2011 | 12:59 AM
ZedO6's Avatar
ZedO6
GM and NGK specifically recommends against anti-seize on the spark plugs with metal coated threads, which is the OE recommendation for our LS motors.
http://www.ngksparkplugs.com/pdf/TB-...1antisieze.pdf
Also, there is heat transfer between spark plug insulator and the cylinder head to keep the spark plug at a specific operating temp ..antiseize while great for removing the plugs, reduces the heat transfer, keeping the insulator at a higher operating temp.
Just put them in clean and dry. I personally would not keep them in for 100K miles, would never happen with as much screwing around I do on my engines.
To spark plug change
Old Dec 28, 2011 | 08:53 AM
rws.1's Avatar
rws.1
I took out the original plugs at 84 K miles.... no anti-seize on them...what a pain...
I put anti-seize on the news ones and when I took them out at 100 K miles to install AR headers, they came out easily....
Learning - use anti-seize
Old Dec 28, 2011 | 11:58 PM
hawkandersonjr's Avatar
hawkandersonjr
From: US-ARMY 1974-1996 Retired ; Oklahoma, City ; Atlanta, Ga: Hephzibah, Ga
I want to change my plugs myself. What size of socket and how difficult are they to remove. Thinking about spraying some WD-40 in the plug area before trying to removing them. What brand do you recommend? Do you recommend changing the wires at the same time? I have about 75,000 on a 2005. What tips do have to make the job a little easier?
Old Dec 29, 2011 | 12:22 AM
m6 c5's Avatar
m6 c5
Just make sure your engine is cold, like sitting over night cold not a few hours or not driving and you shouldnt have a problem. Make sure you buy new wires as you will destroy at least one of them and take your time as a couple of them are a pain to get to, much easier with headers on I might add. As for the socket size its just a standard spark plug socket which I would also recommend if you dont already have one as it has a rubber gasket on the inside to hold the spark plug in there which also ensures you dont damage the plug itself.
