Shocks bad?
First thing, I have the Michelin Pilot Sport Run Flats, I am think this has something to do with it. Anyway, the roads around McAlester are crap, pure crap, thats one reason I cant lower the car. As I am driving in tour mode and hit a rough spot, it sounds as though the shock is botteming out. Its a loud thud. When I switch the control over to sport, it is definitly stiffens up as it should, but on a good rough spot I will still get that thud. Is this because of the stiff run flats? Theres no certain tire that does, it just depends on which one hits the worst part of the rough spot.
Any ideas would be great, this is worring the crap out of me that I might have been riding on bad shocks for awhile.
Many members report that the packing was never removed.
Look at your shocks to see if the shipping packing is still in them
Peace
Chip
BTW, thanks 8Vette, I am glad I read that last thread a little closer.
You can look on the inside of the glove box door and look for RPO code F55. If you have that RPO then it is Magnetic Ride Control. From a dealer you are probably looking at a cost of $3600 or more. Each shock lists at about $900. From Gene Culley (GMPARTSHOUSE.COM) you can buy them for about $600 each. Significant savings but for my money STILL WAY WAY too much for shocks no matter how good they are claimed to be.
If you can find some one with a TECH II you can bypass the F55 option in the car and then run C6Z06 shocks which you can buy from Gene at $240 FOR ALL four shocks.
Here is the information about bypassing the F55 option with a Tech II:
1. Hook up your Tech II (Driver's footwell), turn the car ON, make sure the module in the left rear storage compartment (pull back the velcro lining on the front of the compartment) is plugged in. DO NOT UNPLUG THIS MODULE.
2. Now use the Tech II to delete the F45 option (F55 option does not appear on the Tech II menu screen - SO - DELETE THE F45 OPTION.
(use the screen captures - steps 2-14)
3. Save the new configuration
4. DO NOT TURN THE CAR OFF AND DO NOT REMOVE THE TECH II. Go to the module in the rear of the car, unplug the GRAY connector - IT IS THE WIDEST ONE - leave the other 1 (F/45) or 2 (F/55) plugged in.
5. Turn off the car but LEAVE THE TECH II PLUGGED IN.
6. Remove remaining plugs from module in the rear of the car - Never plug them back in again, if you do the F/45 turns on automatically.
7. Now the moment of TRUTH - Turn the car on and verify that the dreaded - MAX SPEED 80 MPH - is gone. This message was only present if you had already disconnected the shock sensors. Some people have had to disconnect their battery to allow the computer to reset to remove this message, but I would confirm with the Tech II that the F/45 was actually deleted first and if not reconnect everything and start again with step 1.
8. Unplug the Tech II - Get in the car and take it for a ride. Smile as you pass the DREADED 80 MPH.
With these instructions in their hands even the most inexperienced technician can do this. It took mine five minutes and they charged me $25. I would have spent much more time and effort getting and installing resistors.
If you haven't already changed your shocks drive home carefully as the shocks become very soft, not dangerous but as GM advises keep it under 80MPH.
You may get some posters that will tell you can use "simulators or resistors to fool the system. These work on the earlier F45 suspension for the 2002 and earlier cars. It does not work for the F55 suspension.
If you want to replace the shocks you've got a couple options. You can either replace the factory Mag Ride shocks which are pretty expensive, or disable the Mag Ride system and go with a fixed shock or coilover setup. If you don't plan on lowering or tracking the car a fixed shock replacement like our Johnny O'Connell setup would work extremely well for you and is a whole lot cheaper than replacing the Mag Ride system with new OEM units. The Johnny O'Connell package was designed as a non adjustable shock replacement for folks looking to increase their handling ability without effecting ride quality too harshly and are a perfect replacement for OEM shocks and sway bars.
Check out this video of some of the On Track testing we did with factory GM racer Johnny O'Connell to develop a perfectly matched set of shocks and sway bars:
Great advice above! I have a buddy that went the C6Z06 shocks and the disable path. He is very happy. I have a Z51 coupe running the C606 shocks and I love ride and better handling they have given my coupe. Metal endlinks on the sway bars helped too!
jussayn,,,,
I did check for anything loose or broken and nothing jumped out at me. All bolts were tight. I did notice wear marks on the shocks, but that really doesnt mean anything I wouldn't think. I just don't know how to tell for sure if a shock is bad.
I have Hankooks, so I don't think the tires are part of the issue. Also, if the stuffers are in, you can't tell a difference in the two ride modes. Mine were in there is how I know.
Here is a lenghty but informative write up on lowering the C5.
http://forums.corvetteforum.com/c5-t...ng-the-c5.html
I suspect that an owner before you may have attempted to lower the car. Read the info at the link above. It talks about pros and cons of lowering.
I think friday morning before I head out to do this, I am going to go over that thread again!
Thanks OneFast1 for the info!
As an owner for almost seven years now, I can attest to how tough the shock itself is. I got hit by a passenger/ City bus on my passengers side back in 2007, matter a fact it was 7/07/2007, and the bus hit me dead zero in my passengers door and my right rear wheel. I should say the bus was only going 5 MPH when he hit me. Of course the bus weights 37.458 pounds, but the wheel and the control arms as well as the caliber and the tire and wheel, which actually proved to more of a problem for www.countycorevtte.com who repaired my 2003 50th. Anniversary coupe and finding a rear 18 inch painted in the Champlain color.But I also could see the damage but the two parts not affected were the leaf spring and the shocks. So I can assure you you'd see the leaking magnetic dark fluid if you parked on clean concrete. But once I went up and looked at the car, and one of the owners Jim S. who is just a fantastic friend and a walking Corvette encyclopedia.
They had the work done in three or four weeks and you could see the steel frame and the shocks and the differential and the spring were spotless. which is why I can tell you that a C5 frame are one tough characters. And the shock look like it was hit at all it didn't even have a scrap on it. So the RPOF55 option is a great system. I've only had to replace the module which was a little expensive, but having the Mag ride is well worth it.
So I think your shocks are OK, to boot, A lot of C5 Corvettes are pretty tough items. Good look and wave if you see me !
