[Z06] Cam Install
Old Jan 16, 2012 | 04:46 PM
jake07Z06's Avatar
jake07Z06
Default Cam Install
Well, I finally gave in and decided to do a cam swap in my 02Z. After weeks of toying with the idea I ended up going with an MS4 and PRC double valve spring kit from TSP. Also throwing an ls2 timing chain at it while we're in there as well as a chain damper (really hope my block is drilled for it already). The tear down and install begins tonight so ill be updating with pics and vids as we go!
On a side note, how many of you are running a big cam with different engine/tranny mounts? If you are, which mounts did you go with and how do you like them? If I see that I've got a worn engine mount then this might be in my near future. If not, this still might be in my near future...
Heres the dyno vid
Old Jan 16, 2012 | 04:55 PM
Zeppelin654's Avatar
Zeppelin654
heck yea man. should be sick when your done
check out Pfadt Racing motor mounts (very nice quality piece):
http://www.pfadtracing.com/catalog/p...products_id/99
Old Jan 16, 2012 | 07:22 PM
michaelfrench's Avatar
michaelfrench
My cam swap starts on Sunday lol. I'm replacing my motor mounts with brand new gm Oem units. Where did you get the ls2 chain? It was discontinued and replaced with the thicker ls9 timing set
Old Jan 16, 2012 | 08:47 PM
jake07Z06's Avatar
jake07Z06
Texas speed has them! Which cam are you going with?
Old Jan 16, 2012 | 08:53 PM
michaelfrench
mine is a custom grind from antlantic motorsports/fabrication using comp xer lobes
234/244 .598/.612 114+4 lsa
Old Jan 16, 2012 | 09:35 PM
dmaleck's Avatar
dmaleck
Looking forward to the pics and vids, I will be doing cam sometime soon also. Goodluck!
also, Just curious as to why you went with the MS4?
Old Jan 17, 2012 | 10:07 AM
nullpointer's Avatar
nullpointer
I'm just wrapping up my 02 Z cam install and my block was drilled for the chain damper. Where did you get the chain damper from? Install is fun, take your time, use the right tools, and the car will be a beast
Old Jan 17, 2012 | 10:43 AM
jake07Z06's Avatar
jake07Z06
I like the idea of a top end cam, I wanted speed over low end grunt... and I love the sound of the idle!
I ordered mine from katech. Which cam did you go with? Let us know how you like it!
Old Jan 17, 2012 | 08:59 PM
nullpointer
I went with the SNL v4 cam, and should be starting up in a week or so (just got my powerbond balancer today).
Looking forward to watching this progress
Old Jan 17, 2012 | 11:32 PM
jake07Z06's Avatar
jake07Z06
Well the tear down went well, the cam came out easily and the ms4 is now in! I am waiting on my chain dampener and spring compressor to arrive so we are somewhat at a stand still for now... Still debating whether to do engine mounts or not, the cradle is loose from the mounts so we are half way there if I decide to. But my stockers appear to be fine. Also ordered a partition, cargo covers and trunk mat today. My hopes are that they cut down on some drone as I am running bullets and catless lt's. Here are a few pics as promised.
MY BLOCK HAS THE DAMPENER HOLES!!!
Ls1 vs ls2 chain.
Parts pile
Old Jan 18, 2012 | 07:28 AM
nullpointer
I was surprised with the difference between ls1 and ls2 chains when I had them next to each other. I see a black C5 Z wheel in the back of the picture, powercoated or painted? looks nice!
Old Jan 18, 2012 | 09:03 AM
Paul 75 L82's Avatar
Paul 75 L82
Jake, your going to be real happy with that combo. It's going to kick *** and sound really mean. I did my cam install last year and reading your thread makes me remember how much fun I had with the project. You have to have the dyno tune, that's the magic touch.
Old Jan 18, 2012 | 01:53 PM
jake07Z06's Avatar
jake07Z06
They are powdercoated matte black 18X10.5's front and rear. There are more pics of it in my garage link but here's a close up.
It has been a really fun project, Im really excited to see the results! I plan on getting a tune hopefully within the next few weeks. I dont have a good local tuner so Im going to have to take a road trip!
Old Jan 18, 2012 | 02:05 PM
jake07Z06's Avatar
jake07Z06
Almost forgot, the spring tool and dampener both came in today! Also ordered some Hinson short motor mounts today thinking we would be waiting longer for the other two items... Good thing I decided to overnight them(the mounts)! Hopefully they will be here tomorrow so we can button her up for the weekend!
Old Jan 18, 2012 | 07:19 PM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
New mounts are the right choice. I am thinking that engine is going to shake a bit!
Old Jan 18, 2012 | 08:33 PM
nullpointer
Nice choice, I believe a Fast 102 will fit under the cowl when using those mounts.
Old Jan 19, 2012 | 11:14 AM
jake07Z06's Avatar
jake07Z06
Last night the new valve springs went in with ease. The Proform LS valve spring tool is worth its weight in gold! We also used compressed air to hold the valves in place. Slid the new chromoly pushrods in then buttoned up the top end. Since the engine mounts get here today, we installed the dampener and oil pump then called it a night. The dampener really cuts down on the amount of play the timing chain is allowed to have Tonight we should be able to get everything else done and hopefully fire it up! Here are some more pics! Hopefully Ill have a video to post after tonight!
Ti retainers and seats
New Vs Old
Installed
The Dampener
To Cam Install
Old Jan 19, 2012 | 10:26 PM
nullpointer
Nice Update ! Can't wait for the video
Old Jan 20, 2012 | 04:02 AM
Bad95killer's Avatar
Bad95killer
great .... waiting the vid.
Old Jan 20, 2012 | 07:40 AM
pit-man's Avatar
pit-man
If I were you, I would replace that small round blue\oil pump gasket in your picture. There have been many people said they looked fine and then had to pull it apart again to replace that dang gasket because of real low oil pressure.
It also happened to me on my Silverado cam swap. A real pain. I pulled it off and inspected it. Looked to be in great shape...but it never sealed good. Well worth the $1.50 right now.
