battery
Old Jan 20, 2012 | 05:37 AM
c-low's Avatar
c-low
Default battery
whats the best replacement battery got the dreaded column lock ...but it came unlocked gonna install the nypass and new battery hope the service column message goes away then
Old Jan 20, 2012 | 07:26 AM
runner140*'s Avatar
runner140*
Really funny.....33 reads and no replys. We have done this two-three
hundred times. Do a search. The results are there.
Old Jan 20, 2012 | 07:27 AM
Jims79's Avatar
Jims79
Oh no you just open a can of "do a search its been " replys. But for my money get a diehard. Pretty much all top battery's are just about the same. Just make sure its sealed. Glad you got the lock open.
Old Jan 20, 2012 | 09:04 AM
jrose7004's Avatar
jrose7004
I've had good luck with Red Tops.
Old Jan 20, 2012 | 09:46 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Sears DieHard Gold series is the best battery
Old Jan 20, 2012 | 10:13 AM
JohnnyDee's Avatar
JohnnyDee
2023 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (performance mods)
2017 C5 of the Year Finalist
78-6yr/700 CCA/120 RC
Old Jan 20, 2012 | 10:44 AM
dougbfresh's Avatar
dougbfresh
Agm
Old Jan 20, 2012 | 11:20 AM
J0KER's Avatar
J0KER
THIS ^
The 120RC (Reserve Capacity) is the key number here. There is a video floating around from a GM engineer who explains how a good battery without the 120RC can CAUSE the dreaded column lock issue.
Here is what I went with....
Old Jan 20, 2012 | 03:14 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
i've had great luck with the optima yellow top. it might be a bit of overkill (the redtop is probably just as good). have one in each of my vettes (78 and 04)
Old Jan 20, 2012 | 03:25 PM
2004c5blackcoupe's Avatar
2004c5blackcoupe
Optima Red Top from Costco. Regardless of type, keep charged with battery tender that shuts off when charged. Don't use float charger with AGM.
Old Jan 20, 2012 | 03:34 PM
FunCar11's Avatar
FunCar11
Default Battery
I use the red top gell battery, if your battery leaks it will eat up the wire harnes that is below the battery. You will have troubles the rest of your ownership.
Old Jan 20, 2012 | 04:31 PM
Ole Blaster's Avatar
Ole Blaster
Old Jan 20, 2012 | 04:32 PM
dougbfresh's Avatar
dougbfresh
There is a different float charger for an AGM
Old Jan 20, 2012 | 05:49 PM
Golf Man's Avatar
Golf Man
I'm not sure where you are located, but if you are in the midwest
check out Farm and Fleet. They have a rebadged Deka AGM /
120 RC / 785 CCA and much cheaper than the ones noted above.
I have had success with their batteries in all my vehicles.
Old Jan 20, 2012 | 05:52 PM
corvettepete's Avatar
corvettepete
Put a Diehard Gold in my '99 coupe a few weeks ago. The Vette jumps to life when I turn the key. Hasn't started this good since I bought the car in early 2009. The Interstate it came with must have been past its prime. Unfortunately, there was no purchase date marked on it. Did a lot of battery searching before buying. Unfortunately, no one battery is preferred. Folks are swearing by everything from a Walmart brand up through the Optimas. Think alot depends on how often you drive your Vette.
Old Jan 20, 2012 | 09:09 PM
When my Red Top died back in Oct 2010, I replaced it with a Sears Diehard Platinum battery. So far, so good. It is not cheap though.
Old Jan 20, 2012 | 10:32 PM
had2have-it's Avatar
had2have-it
^^^ conventional lead acid GM, the new ones don't leak and a lead acid battery is much less tempermental than a AGM.
To battery
