2001 ac problem blowing hot
Old Jan 20, 2012 | 07:51 PM
stockishz06's Avatar
stockishz06
Default 2001 ac problem blowing hot
ok my wife has a 2001 corvette, the ac comes on the clutch engages the lines get cold but out the vents is warm arm with the ac on the lowest setting, the passenger side is maybe 5 degrees cooler than the driver side but its like it stuck on vent
you can run the temp up on the car and the air does get hot just like it should on both sides being the same temp on a dual climate control
it seems to me like a door that switches from hot air to cold air to vent is broke or something i have no clue and it gives me a headache trying to figure it out,
any help would be great summer is coming quick and i would like to have it fixed
thanks
__________________
Old Jan 20, 2012 | 08:51 PM
jrose7004's Avatar
jrose7004
Check your freon level.
Old Jan 20, 2012 | 09:04 PM
Jeff in Den's Avatar
Jeff in Den
Check your codes first...there are some for the actuators ...
Old Jan 20, 2012 | 10:25 PM
stockishz06
freon level good
how do i pull up the codes again i know its some crazy button pushing and where do i find out what the codes are
Old Jan 21, 2012 | 12:33 AM
stockishz06
found the code guide no hvac codes at all it did throw
loss of communication with bcm
loss of communication undertermined
door lock mirror heater fit
tach signal circuit malfunction
i didnt clear them and see what came up again but im not sure about the first and second if someone could help
Old Jan 22, 2012 | 11:26 PM
stockishz06
anyone?
Old Jan 22, 2012 | 11:29 PM
LMFD296's Avatar
LMFD296
How did you check your r134A level? try a full drain and then refill.
Old Jan 22, 2012 | 11:45 PM
homewrecker's Avatar
homewrecker
Listen to my fellow Jake here. I bet you a buffalo nickel (I don't have one) that it just needs a can of R-134a. Just pick a can up at your friendly auto parts store and just refill it.
Old Jan 23, 2012 | 08:32 AM
stockishz06
A buddy of mine has a mechanic shop, and Im an a/c tech by profession, we.recovered all the freon out of.it and recharged it to full, the lines are sweating just like they shoukd everything is working just no cokd air, I wish it was that simple,
Old Jan 23, 2012 | 08:53 AM
stockishz06
Its almost like the doors inside the blower assembly are stuck or broke, but it does.go to heat just like it should i wish i was an obvious broken piece or somethn, I kinda took apart the lower part of the dash and a cover off the blower assembly and I could see one actuator for.the.door.im guessing and I coukd.switch it from heat to.cool and feel the actutor move and I coukd see the bars turning but inside the box is a differant story
Old Jan 24, 2012 | 03:11 PM
stockishz06
I know the dual climate controls displays are bad about going out, well this one was out wheb we got the car air worked perfect.so around september is when the problem start so I found the thread on how to repair the display so I did and it works flawless, everything lights up just like it shoukd,
Could this still be the problem if the display went out whats not to say something else inside there isnt messed up also to not allow the ac to come on
Just trying to think of anything
Old Jan 24, 2012 | 06:57 PM
billmiller8's Avatar
billmiller8
You never said where you live. I'm not a mechanic, and this may or may not be a dumb answer in your case, but if your just trying to get it ready for summer and just checking everything, the manual says the AC will not work if temp is between 35 and 40 degree's outside.
Old Jan 24, 2012 | 08:50 PM
stockishz06
it went out at the end of summer, well i live in gulfport mississippi so summer is 11 months out of the year, i need to get it fixed before it gets misserable hot and uncomfortable to even drive the car with the windows down
anyone ever hear of the actual flaps or doors that controls where the air comes from breaking or something
Old Jan 24, 2012 | 08:55 PM
LMFD296's Avatar
LMFD296
I personally have never seen this is a c5 but i have seen it in a few vw's where the motors for the flaps failed.
Old Jan 25, 2012 | 10:58 AM
stockishz06
Ok a member told me about bad actuator door so I looked up the part number and the actuator is actually interchangable with alot of vehicles, a buddy of mine with a mechanic shop has a s10 goin to scrap with the same part number actuator and since the driver side can be changed without removing the dash im gona swap them over, and if it works then ill order new ones and pull the dash and.change both ill keep yall posted what happens
Old Jan 25, 2012 | 08:48 PM
bj454ss's Avatar
bj454ss
Some older threads talk about the battery leaking and corroding a vaccum iine thats underneath the battery tray. When mine had same issue it was low on freon. I had a friend check it and he said it was not low. When I brought it to the dealer they said it was low and the compressor was leaking. Had them charge it last May and its still blowing cold.
Old Jan 25, 2012 | 11:29 PM
AntonioZ06's Avatar
AntonioZ06
I think if my memory serves right, the flap or actuator is actually controlled by vacuum. I'd take a look at some of your vac lines like bj454ss said.
To 2001 ac problem blowing hot
Old Jan 26, 2012 | 10:03 AM
stockishz06
Yea I heard about that also the line under the battery, and it was good I did the brake cleaner test, I know I shouldnt do it but I did, take brake cleaner and kinda mist it iver the engine in various locations wheb the engine is running and the motor should rev if you hit a vacuum leak and I didnt find anythung ive checked everything ive heard about the last thing is to replace the actuators unless someone else.comes up with somethn I havnt tried yet
Old Jan 26, 2012 | 10:05 AM
stockishz06
And I recovered my freon pulled a vacuum on the hole system it held.for several hours and I recharged it back to the ounce of what alldata program calls for and it was with a $3000 digital ac machine at my buddys shop
Old Jan 26, 2012 | 10:24 AM
mikesvette1's Avatar
mikesvette1
On my 2001 my vacuum line on the back on the manifold was was blocked from glue from the previous try to fix. i replaced the line and it seemed to work better but still not right. It was blowing cold but not very hard out of the drivers side. I bought the modulator and removed the glove box and all the underneat stuff and removed the manifold and tested for vacuum leaks, I had none, before replacing the modulator i starting plugging up line on the manifold and found out that the red tube being plugged boosted the air pressure out of the cold air coming out of the drivers side vent, like it supposed to be. The only drawback was when the vents are suppose to be the floor only i get the dash too. Everything else works fine and i could live with that since i live in Arkansas so i plugged the red line and everything works for me, best of luck and hope this helps.
