[Z06] HELP! Reverse light fuse keeps blowing!
Old Feb 21, 2014 | 10:15 PM
TraviZ06's Avatar
TraviZ06
Thanks bill. Good idea probing the fuse socket! I'm sure it's te switch as it's a common issue but I like diagnosing issues.
Is the reverse lights supposed to work with the key to on and the shifter in reverse? Car doesn't have to be running, correct?
Old Feb 21, 2014 | 11:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yes... The reverse lights will come on with the ignition ON / eng off / trans in Reverse..
The switch on the trans usually fails OPEN
Bill
Old Feb 22, 2014 | 04:42 AM
TraviZ06's Avatar
TraviZ06
Well I just got home from work and have not tested for 12volts at the fuse yet however I don't think I need to anymore. I noticed on my drive home the little green light on my mirror is lit up now as well as a functional auto-dim feature now. I also noticed an orange glow from the mirror down upon my shifter. None of this ever existed before.
I am going to go ahead and order a backup switch as everything except the lights are working now.
I did notice however that my keyfob is still not flashing the backup lights.
I know the bulbs are good because I just put two new ones in.
