6 point harness mounting
Old Feb 7, 2012 | 10:03 PM
rtpassini's Avatar
rtpassini
St. Jude Donor '11-'12
Default 6 point harness mounting
Where or how did you mount harnesses to the floor? any pics?
The bar I bought didnt come with the floor mounts.
Old Feb 7, 2012 | 10:25 PM
sfc rick's Avatar
sfc rick
I secured the harness to the floor seat studs in the rear and ran the harness up behind and over the roll bar crossbar then through the Sparco seatback. The lap belt was bolted through a 3/8" hole provided in the seat track frame for the lap belt hardware.
Old Feb 7, 2012 | 10:49 PM
rtpassini's Avatar
rtpassini
maybe i missed it...but wouldnt there be 6 mounting points? shoulders attached to the bar, then the lap would bolt to the rear and the 2 sub belts would attach to the front?
Also, If you used the seat mounting bolts for the rear, why not the same with the front?
Thanks!!
Old Feb 7, 2012 | 11:14 PM
m6 c5's Avatar
m6 c5
Old Feb 7, 2012 | 11:38 PM
rbrumm's Avatar
rbrumm
The floor mounting hardware as well as the side strap hardware should come with your harness. There are two types. Bolt down or clip on. If the harness did not come with the harness you will need to purchase them from a store the supplies racing safety products.
The bolt down do just that. Bolt down. Drill through the flood of your car. Use grade 8 bolts and a large flat fender washer on the outside For the clip on type. You will need to purchase a eyebolt mounting kit. From the same racing supply store and do the same floor drilling. Check the Internet racing supply stores. For harness and mounting. I like the clip on type. This allows me to Easley remove the harness if needed
Old Feb 7, 2012 | 11:39 PM
rtpassini's Avatar
rtpassini
Just straight through the floor? Nothing I need to worry about drilling through?
Old Feb 8, 2012 | 01:07 AM
rbrumm's Avatar
rbrumm
I drilled right through the floor on my porsche. All the wires. Brake lines etc. were in the center console and the base area by door. Just pull carpet back around the drill area to double check Clearance
Old Feb 8, 2012 | 02:19 AM
Last C5's Avatar
Last C5
The floor of your C5 is a sheet of balsa wood with a thin layer of aluminum covering both sides of the balsa wood. DO NOT drill through the floor and expect the seat belts to hold. Run a cross bar (angle iron or whatever) between the two rear seat mount bolts and hook the sub belts to that. You can also get brackets that mount to the rear seat bolts for hooking sub belts to.
Old Feb 8, 2012 | 07:48 AM
sfc rick's Avatar
sfc rick
DO NOT drill through the floor PLEASE! I removed the seat bracket and cut the carpet away from around the seat rear mounting stud to give me additional room to install the shoulder strap mounting hardware. That seat stud is secured to the metal frame of the car.
Old Feb 8, 2012 | 08:45 AM
AU N EGL's Avatar
AU N EGL
get some harness mounting hardware and a harness bar
Bra-Krause makes this hardware for vettes
Old Feb 8, 2012 | 09:35 AM
rtpassini's Avatar
rtpassini
I have a harness bar. but not the lap and sub belt mounting hardware
Old Feb 8, 2012 | 03:42 PM
rbrumm's Avatar
rbrumm
Im guessing that you may be tracking your car someday soon? with the added belts, roll bar, harness etc. most of the race tracks require roll over protection on your vehicle. mounting the harness to your seat mount may be allowed in parking lot style auto cross and some time trial applications. but is not allowed in racing. all harnesses must be mounted separtely from the seat. I have seen large plates mounted to the underside of the car to support the lap & front belts But if your just cruzing around the street with the harness then the mounting to the seat stud as said above by SFE Rick is the way to go.
Old Feb 8, 2012 | 04:04 PM
rtpassini's Avatar
rtpassini
do I need a special mount for a Crow Clip in harness with Sparco Evo 2's?
Someone who is selling the harnesses to me said she needed Brey Krause Lap Belt Mount Kit for her carvaggio seats. Do I need anything special?
Old Feb 8, 2012 | 04:18 PM
Scooter70's Avatar
Scooter70
Which harness bar do you have and which seat mount? I have Hardbar seat rails and have the harness bolted to the rail.
You either need to bolt the harness attachment points to the seat rail or use this with "clip-in" style attachments:
http://www.vetteworksonline.com/cata...roducts_id=147
Old Feb 8, 2012 | 04:48 PM
rtpassini's Avatar
rtpassini
I have Arizona speed and marine bar. I made my own rails and sliders. So ill probably need to either make my own rig or that piece you posted.
To 6 point harness mounting
