TPMS Install Question
Old Feb 9, 2012 | 01:02 AM
fishmen222's Avatar
fishmen222
Default TPMS Install Question
Found a really nice set of basically new GY RFs on Z06 aftermarket rims for less than I could buy the tires for. They do not have sensors installed. I notice OEs cost about $75-100 a piece, yet places like TireRack sell all four for $158. Does anyone have experience with aftermarket sensors? Are the OEs worth twice the price?
Old Feb 9, 2012 | 01:34 AM
DeeGee's Avatar
DeeGee
I used OEM TPSs for my new rims and I've never had a problem. I've heard quite a few members who have said they fitted Costco TPSs and I've not heard any negative feedback. Maybe no news is good news?
The only negative I heard was from one member who fitted a single after market TPS with 3 other Delco sensors and he struggled to get it to work.
You could buy the sensors and see if they will program before you fit them. They dont have to be fitted to do that. If you do, either make sure they go in the correct wheel or reprogram them once ftted.
BTW, OEM sensors for an 02 should be less than $75 each.
Old Feb 9, 2012 | 01:37 AM
DeeGee's Avatar
DeeGee
Here you go. Check with Gene Culley at gmpartshouse.com:
||--Genuine GM C5 Tire Pressure Sensors/TPM--||
2001-2004 Sensors
25773946 – sensor – $40.60 each
15234846 – nuts – $3.95 each
Old Feb 9, 2012 | 02:15 AM
fishmen222's Avatar
fishmen222
2001-2004 Sensors
Thanks a bunch.
Old Feb 9, 2012 | 12:22 PM
Cirrus8's Avatar
Cirrus8
Why buy new nuts for the TPMS? I would think that the old nuts would work perfectly. Just as well save $16.
Old Feb 9, 2012 | 01:43 PM
DeeGee's Avatar
DeeGee
If you buy new rims you need new nuts
Old Feb 9, 2012 | 05:51 PM
fishmen222's Avatar
fishmen222
...and all this time I thought my nuts were fine...
Old Feb 9, 2012 | 06:31 PM
Jet-Jock's Avatar
Jet-Jock
Actually I think that cost is for a rebuild kit, which includes an o-ring, nut and cap. The o-ring is the most important part as removing the one already seated is non usable.
Old Feb 9, 2012 | 08:12 PM
Jet-Jock's Avatar
Jet-Jock
I called it an o-ring, perhaps the appropriate name is grommet.
The '01 sensor has a grommet shown in the picture, one of mine was replaced yesterday when they replaced the QF5 wheel with a brand new QF5 wheel (original cracked from hit/run). I watched them peel off the old one and install a new one.
Interesting...
Old Feb 9, 2012 | 08:31 PM
memmer's Avatar
memmer
I just purchased a new set of TPMS from OE Wheel Distibuters for a 2001 for $140.00 +$5.00 shipping.
To TPMS Install Question
