Estimate top speed
Old Feb 18, 2012 | 01:47 PM
knewblewkorvette's Avatar
knewblewkorvette
Default Estimate top speed
First off, I've done a search on "top speed C5" and there are allot of threads but none of them answers my question.
If I remember correctly, top speed for my stock 6-speed 02 is 174 mph. That's with 350 HP and in 5th gear.
Well, I'm looking at mods that will push me to over 900 HP. I'm guessing I'll be able to use 6th gear and get a much higher speed. I do not plan on driving it to that speed, I'm just curious. The car's rear is 3:42
Is there a formula to plug in numbers that will estimate top speed? If not, what do you think top speed will be?
Thanks in advance
Old Feb 18, 2012 | 02:18 PM
Jeffwilson34's Avatar
Jeffwilson34
i know for a fact my 98 coupe will do 190
Old Feb 18, 2012 | 02:38 PM
Bailout13500's Avatar
Bailout13500
Put the mods on Forza 4 and hit the test track!!! hahaha
Old Feb 18, 2012 | 06:14 PM
Silverback51's Avatar
Silverback51
Wallace Racing site has some calculators that may help you out.
http://www.wallaceracing.com/Calculators.htm
Old Feb 18, 2012 | 06:19 PM
bovi's Avatar
bovi
193 in 6th gear. 520whp
Old Feb 18, 2012 | 06:40 PM
Frank4202's Avatar
Frank4202
If I remember correctly, stock goes to 175mph
Old Feb 18, 2012 | 07:04 PM
f6john's Avatar
f6john
The math is fairly simple, the question is how many rpms can your car pull in 6th gear at a given up rating. The math is just theory until you actually go out and pull those rpms.
Old Feb 18, 2012 | 07:24 PM
HiltonFerg's Avatar
HiltonFerg
300mph!!!
Old Feb 18, 2012 | 07:32 PM
2003 electronblue's Avatar
2003 electronblue
Well make sure your 350ls1 doesnt have pistonslap before trying out top speed or it will blow!
Old Feb 18, 2012 | 08:00 PM
BarryBum's Avatar
BarryBum
St. Jude Donor '10
Old Feb 18, 2012 | 08:58 PM
Bakerking31's Avatar
Bakerking31
the math is only simple if you dismiss certain very important factors like drag, frontal cross section, downforce/lift, torque at certain rpm's, etc .... very few calculators will take this into account, otherwise you could theoretically do something like 400mph due to 6th gear being so long.
Old Feb 19, 2012 | 02:11 AM
skeet's Avatar
skeet
I assume it is not a convertible? Coupes have a cd of .29 and converts I think is .33?
You are running "Y" rated tires right?
Old Feb 19, 2012 | 10:55 AM
f6john's Avatar
f6john
Exactly my point, top speed can only be determined by driving the vehicle to it's limits.
Old Feb 19, 2012 | 12:08 PM
knewblewkorvette
Yes, coupe.
Yep, "Y" rated.
While still stock (except for K&N air filter, Magnaflow x-pipe, and BB Bullet exhaust) I've had her to 163 mph in 5th gear. She was still pulling strong but I chickened out due to the road inperfections (closed road). I can't remember what the revs were though.
I'm not willing to try that unless someday I go to the salt flats or something like that.
I'm guessing since the ZR1 can do 200 plus with 638 HP I should be able to do the same with 900 HP on tap. Not sure the CD of the ZR1 or gearing though. I'm off to research that
Old Feb 19, 2012 | 12:32 PM
mooney201's Avatar
mooney201
Almost any event that lets you go at full speed requires at a minimum five point seat belts, ala Mojave Mile. Most require a loop or full cage over 180 mph, along with all the other safety requirements. Since I do not plan on installing a cage or a five point harness, I probably will not find out. ZR1 has 638 flywheel hp and claims to do around 205 top speed. I would think that with around 600 flywheel hp in a coupe, you might see 200 mph. For an automatic figure about 20% loss from flywheel to rwhp. On a manual figure 15% loss.
In our case we have 515.76 rwhp plus 15% would equal 606 flywheel hp.
That might get me to 200 mph, but sadly I will probably never know. Others might have installed the required safety equipment and can tell us what they have done.
Old Feb 19, 2012 | 04:59 PM
knewblewkorvette
Originally Posted by mooney201
Almost any event that lets you go at full speed requires at a minimum five point seat belts Got them, ala Mojave Mile. Most require a loop got that too or full cage over 180 mph, along with all the other safety requirements..
Old Feb 19, 2012 | 05:27 PM
sfc rick's Avatar
sfc rick
Same here, have the safety stuff BUT too chicken$#@ to stay in it long enough to find out! My immortality card expired a few years back.
To Estimate top speed
Old Feb 19, 2012 | 07:40 PM
Turbopower87's Avatar
Turbopower87
Originally Posted by knewblewkorvette
Yes, coupe.
Yep, "Y" rated.
The C5 coupe with headlights down has a lower Cd than the C6, so with 900hp I'd say you're good for 200+
Old Feb 19, 2012 | 08:49 PM
hammerdwn's Avatar
hammerdwn
Just mash the gas and find out!
Old Feb 20, 2012 | 03:08 AM
BOUT X's Avatar
BOUT X
Corvette Cowboy
186 was passed by another C5 With a 427 @ 196
