Blinker Issue
Old Feb 23, 2012 | 01:23 PM
phrankw's Avatar
phrankw
Default Blinker Issue
I'm starting to have an issue with my blinkers (indicators). Most of the time they work great but about 2 days a week, on my drive home from work, they won't work at all (left or right). Any ideas?
Old Feb 23, 2012 | 01:35 PM
RamAirTA's Avatar
RamAirTA
From: I'll Keep My Guns , Freedom And Money. You Keep The Change. FL
http://forums.corvetteforum.com/c5-t...in-here-3.html
Scroll down to number 48. Very easy fix. You can forgo the headlight connector and use insulated female spade connectors. $7.00 fix.
Old Feb 23, 2012 | 01:49 PM
phrankw's Avatar
phrankw
Thanks RamAirTA. You Da Man! I did a search but it didn't pull up anything. Thanks again.
DeeGee's Avatar
DeeGee
The hazard warning unit could be the problem. If not its probably the turn signal switch on the stalk.
Try pushing the hazard switch firmly a few times. Does it clear the problem? If so, the bypass is a good fix. If not, try some electronics cleaner squirted into the T/S switch on the stalk. If it improves, that may be the problem.
Both of the switches are unreliable and its a common problem here. Try to isolate the problem and we can offer advice on how to change the switch.
Old Feb 23, 2012 | 05:13 PM
zesstey1's Avatar
zesstey1
can you hear them clicking realy fast or just nothing at all?
Old Feb 23, 2012 | 05:32 PM
TorchRedRocket's Avatar
TorchRedRocket
Did you check your blinker fluid?
Old Feb 23, 2012 | 06:55 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
And only use GM spec'd fluid.
Old Feb 23, 2012 | 08:00 PM
zesstey1's Avatar
zesstey1
I only use royal purple in mine
Old Feb 23, 2012 | 08:19 PM
Binski's Avatar
Binski
I used a blinker bypass that installs under the drivers kickplate. Very easy install, the bypass is made for LED turn signals but fixes the problems of the bad blinker/hazard switch which is harder to get too. The hazard lights will still work and be unaffected by the bypass.
If the hazard switch is indeed the problem it will also be affecting your brake lights. Lots of places sell the bypass ($49) including CC and other vendors.
Old Feb 23, 2012 | 08:21 PM
Mr.C5's Avatar
Mr.C5
I totally bought this too! Great product!
Old Feb 24, 2012 | 09:07 AM
jhanson999's Avatar
jhanson999
I always get my blinker fluid here: http://kalecoauto.com/index.php?main...&products_id=6
I like their lowering kit too: http://kalecoauto.com/index.php?main...products_id=11
Haha!
Old Feb 24, 2012 | 09:12 AM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
can tell your age by using the word ...blinker.....hey...I do to !
Old Feb 24, 2012 | 09:37 AM
99 vett babycar's Avatar
99 vett babycar
works great
To Blinker Issue
