Ventelation
Old Mar 3, 2012 | 06:49 PM
vete girl's Avatar
vete girl
Default Ventelation
When I drive my 2003 AE Coupe with the windows up I get air noise from the top of the drivers side window. However, if te passenger side window is lowered just a bit, the noise goes away. Are there vents in the rear of the vehcle to alleviate the pressure that is apparently causing ths noise? I thought I read on the CF that they existed?
Old Mar 3, 2012 | 07:25 PM
killain's Avatar
killain
Oldtimer
Default Window glass alinement.
I don't think vents are your problem, back in the late sixties GM produced a lot of cars the offered "Flow-thru Ventilation" But that being aside, I think your car might of been in a slight accident or something of that sort to make your side glass not fit properly. Any good body shop should be more than able to remove the door card and readjust the glass so it seals tighter at the top. Do you get a water leak in the car when it's washed ?
Old Mar 3, 2012 | 07:50 PM
65GGvert's Avatar
65GGvert
You don't need to remove the door panel to adjust the tilt in of the window to make it tighter if that's the problem. There is a lock nut on the bottom of the door and an adjusting screw behind the reflector on the door. There is also a blowout clip at the top of the window that may need some adjusting. Try doing some searches for those two adjustments. And yes, there is a vent in the rear of the hatch compartment to relieve pressure when a door is closed with the windows up. I don't recall if there's one on the passenger side, but there is one on the driver's side about a foot forward of the taillights on the side. You can see the little flap if you take a look.
Old Mar 3, 2012 | 07:57 PM
65GGvert's Avatar
65GGvert
Here's one link with the instructions, but the pictures didn't show for me. There are others.
http://api.viglink.com/api/click?for...13308225777483
Old Mar 3, 2012 | 11:52 PM
ALLEGRO's Avatar
ALLEGRO
Saved the link.....thanks
Old Mar 4, 2012 | 08:44 AM
vete girl's Avatar
vete girl
No water leaks with the painted top only with the glass and on both sides, slightly at times. I do think the driver's side window needs to be adjusted. Thanks
To Ventelation
