18s front and rear
Old Mar 4, 2012 | 03:05 AM
SuperDave02's Avatar
SuperDave02
Default 18s front and rear
I seen a local car with 18s front and rear and the guy said he does it so he can rotate. Any draw backs to this? I can get a new set of repo C5Z06s for around $900 and would run 265/35 front and back.
Old Mar 4, 2012 | 06:49 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I don't see how he can rotate the tires, First off you have to have different size tires front and rear not to upset the T/C, Most tires are directional so you can't go side by side.
I have 18 inch wheels on all 4 corners on my car, But the tires are different front to rear.
Mr.Bill
Old Mar 4, 2012 | 07:01 AM
foundvettelifeisgood's Avatar
Mr.Bill
Old Mar 4, 2012 | 07:48 AM
machz800ps's Avatar
machz800ps
Mr.Bill
, same here!!!
Steve
Old Mar 4, 2012 | 08:24 AM
azer666's Avatar
azer666
Mr.Bill
Old Mar 4, 2012 | 08:34 AM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Mr.Bill
I think the only way you could rotate them would be if you go with the same size tires on all four corners. Personally, I'd think you'd want wider tires on the rear for better traction.
Old Mar 4, 2012 | 08:48 AM
with Mr. Bill - unless you have an appropriate stagger in overall wheel/tire diameter front to rear, you will have some problems with T/C.
Old Mar 4, 2012 | 10:21 AM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
Not to mention that 265/35s on an 18x9.5" rim would look way too small in the rear wheel well. Even 295/35s are smaller in diameter than the stock 275/40s.
Old Mar 4, 2012 | 10:22 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
^^^^^^^^^^^^all the above
Old Mar 4, 2012 | 10:24 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You'll be fine --
The main thing is keeping the tire height within a 1/2" from the stock height tire
Thanks,Matt
Old Mar 4, 2012 | 11:44 AM
SuperDave02
ok thanks guys for the info. think im going to stay with the 17 18 package and just get new wheels and tires.
Old Mar 4, 2012 | 12:32 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
Default help your friend out
There's a very good chance your friend doesn't understand the front/rear stagger requirement, and won't until he tries to rotate his tires. You could save him some trouble down the road by explaining it to him or by pointing him toward the forum for an explanation.
Just explain to him that the TC system requires a tire height stagger from rear to front (rear slightly taller).
That said, you can have 18's front and rear (or 19's, or whatever) as long as the rear tires are taller. Tire height depends on TIRE size, not WHEEL size
Old Mar 4, 2012 | 12:36 PM
AU N EGL's Avatar
AU N EGL
or turn AH/ TC OFF
Old Mar 4, 2012 | 12:58 PM
SuperDave02
I don't know the guy, just saw him after leaving a doctor and was wondering why the fronts looked weird to me, so caught him at a light and asked him about it, and that's what he told me. That's why I asked the question before I went and did it.
Old Mar 4, 2012 | 01:10 PM
Mr.Bill's Avatar
Mr.Bill
If it looked weird why would you want to go out and do it?
Old Mar 4, 2012 | 01:50 PM
SuperDave02
I liked the idea of front to back rotation. So wanted to know if there was anything good about it, but I guess not. oh well as long as I can drive fast thats all that counts.
To 18s front and rear
