How mad should I be?
Old Mar 7, 2012 | 07:54 PM
  #41
92GA's Avatar
92GA
Oldtimer
Originally Posted by fendermender
Well, I can certainly understand being upset about this and wanting some sort of restification. But what??
Hack the rockers off and replace them? I don't think so. Only repair I could see viable is grinding out the cracks and rebuilding with SMC repair adhesive. Then sand, prime and attempt to blend the paint. Hopefully try to keep the color blend under the car. And hope they don't get overspray all over the undercarriage. You really want to get into that for something no one but a field mouse can see?
Yes, easy enough to say make them fix it. Personally I would ask them for a cash settlement and try to forget it. I have to wonder that if they have trouble simply putting it on a lift, what sort of repair job might you get. I could see this snowballing into a worse mess.
I wouldn't let their body shop touch it period. If you really want it repaired, get a shop close to you, that you trust. Then send them the bill.
Old Mar 7, 2012 | 08:01 PM
  #42
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
I simply can't believe the responders here demanding the rockers be replaced. That would be like amputating someones foot for an ingrown toenail. But what would I know.
I would leave it alone and forget about it. It is unfortunate that this happened, especially to such a beautiful low mileage car but you may get the car back with more problems plus you will have a repainted area much larger than the damaged area since the painter will need to match the paint properly. Who knows what else will get damaged in the process. Then there is the chance that there will overspray and dust in every possible crevice.
Chevy dealers are notorious for this kind of damage and continue to screw up customers C5's and C6's this way. Many dealers did this to new cars before delivery to the customer.
What are your plans? Are you going to drive the car?
Old Mar 7, 2012 | 08:11 PM
  #43
Grimlock's Avatar
Grimlock
This getting on your CarFax is a bigger issue in the long run. 1 hit on a CarFax=a BIG hit in value. I learned this the hard way on my last car.
Old Mar 7, 2012 | 08:25 PM
  #44
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
After seeing the "damage" in the supplied picture, it's probably not even worth bothering with. I was envisioning broken pieces requiring a replacement rocker panel. Hell, a speed bump taken the wrong way will do more damage than the couple of cracks in the paint/plastic. Get some sort of credit or cash out of the dealership and cruise on! As mentioned, it could end up worse if it's "fixed" incorrectly. Besides all of that, you'll be the only who knows that your 100 point car is really only a 99.9.
Drive it Drive it Drive it!
The worst is yet to come.
Old Mar 7, 2012 | 08:31 PM
  #45
TorchRedRocket's Avatar
TorchRedRocket
Ok, I guess I will be the first one to ask... Why were you getting a 2700 mile car inspected? Were you worried about problems from the car sitting? Honestly, it is not worth the hassle of dealing with the dealership and body shop to get this fixed. Way too many opportunities for other things to get eff'ed up along the way while they repair it. I agree with what a lot of the guys have said. Your best bet is to try to get some type of compensation or reimbursement and move on.
Old Mar 7, 2012 | 08:53 PM
  #46
Elvisf16's Avatar
Elvisf16
I'm going to drive the car--that was actually part of the rationale I used when I didn't make an issue of it at the dealership. I admire the service manager for owning the mistake. That, in and of itself, sort of militates toward just letting it go.
As far as the kid who failed to use the pucks: I have zero problem with him being held accountable. Maybe he will learn not to take shortcuts, and maybe the next guy's car won't get jacked up (figuratively) on account of it.
Old Mar 7, 2012 | 08:55 PM
  #47
chasboy's Avatar
chasboy
Oldtimer
Dealer has to fix it. Period.
Old Mar 7, 2012 | 08:57 PM
  #48
c5vetteguy's Avatar
c5vetteguy
Never thought I'd say something like this, but, we could use a few more lawyers who think like you.
Old Mar 7, 2012 | 08:58 PM
  #49
Elvisf16's Avatar
Elvisf16
Sage advice. I think I will take it. After so long out of the Corvette and Chevy world, I guess I forgot you cannot trust dealers and their service departments. I assumed a risk and the risk materialized. There was no reason whatsoever to take a 2700 mile car in for an inspection. What is it they say about hindsight?
Old Mar 7, 2012 | 09:05 PM
  #50
3sACROWD's Avatar
3sACROWD
I'll start by saying Thank-you for your service to this great nation. I'll continue by saying that I'd be pissed that the dealership did this. Now I give you my opinion as I see it and based on the facts from your original post.
Don't let your credentials get in the way. Just because you have credentials doesn't mean you're 100% right. If I were a good sleezy Defense attorney, I could easily create reasonable doubt with a judge or jury because it is a he said she said until the dealership fessed up. You removed the car from the rack and left the premises without notifying anyone but the previous owner.
I would argue that it is possible you didn't get on the ground in that particular area and see the damage as it is UNDER the car and the car is very low to the ground. Next I'd say the previous owner wasn't aware of the damage until you pointed it out or didn't fess up to it. Without the car being on the lift showing the interference or the dealership fessing up, your case is shakey at best. The marks aren't even distiguishible to that particular lift. Anything could have caused that damage.
I don't intend to start an argument or insult you but I wouldn't side with you based on your credentials. Lawyers, like anyone else, don't deserve special privledges and in Court you need to be successful in proving beyond a reasonable doubt. I don't think you could do that without the dealership's confession. Be happy / grateful they are an upstanding dealership.
I'll finish with again thanking you for your service to this great nation. It is people, such as yourself, that allow my to voice my opinion freely.
Forget about the cracks and enjoy the heck out of the car. You no longer have to worry about the first scratch. It is no longer a virgin and the good news is the damage is out of sight.
Old Mar 7, 2012 | 09:08 PM
  #51
Mike98SilVert
Sounds like a great car. Enjoy it.
Post some pics.
Old Mar 7, 2012 | 10:06 PM
  #52
Ona mission's Avatar
Ona mission
St. Jude Donor '14
Proof of these facts would be rather straightforward: my testimony (Lt Col in the Air Force Reserve; combat vet Iraq and Afghanistan and Bronze Star recipient) + the testimony of the guy who sold it to me (unbiased witness) = proof by way more than a preponderance of the evidence.
Easier if they just admit it, which they have. But not all that hard to prove in small claims court if they had not.
Now that I've had a little cool off period , I'd still be upset but try not to take it out on somebody. I've seen the pics and read some of the response from other CF members, Maybe a cash adjustment somewhere in the transaction would be be a easier and more gracefull solution, if all parties could give a little.
and by the way.... thanks for your service
Old Mar 7, 2012 | 10:49 PM
  #53
Suthunman's Avatar
Suthunman
St. Jude Donor '14
The first scratch is always the most painful. While it's irritating as hell that it should not have happened, save yourself more grief and let it go. Be thankful it's not in the center of the hood.
I recently got my first scratch, it's very low on the car but can be seen. Oddly enough, I'm not so uptight about driving it now and actually enjoy it more. Drive it and enjoy it.
Old Mar 8, 2012 | 12:53 AM
  #54
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Ask for some free oil changes as compensation. You're gonna ding that panel anyway.
Old Mar 8, 2012 | 01:30 AM
  #55
Jewjenk's Avatar
Jewjenk
To all saying live with it and what about the kid..................To hell, this is a major problem with Vettes and cars with hydro formed frames. Dealers and others are famous for damaging the fenders and rocker panels on Solstices and Sky's. When I took my Solstice in for service, I would hand the manager the GM printout for the proper lifting procedure and inspect the area before and after. I would also watch who was lifting the car and leave a copy of the procedure on the dash. You pay good money for your car and have a right not to have some jerk jack it up and then say "sorry".
Too bad for the mechanic, get more training, be more observant.
Old Mar 8, 2012 | 02:24 AM
  #56
Jistari's Avatar
Jistari
I screwed up some things with this because I'm a nice guy. My biggest mistake was thinking it was not a big deal and leaving that dealership without complaining to the service rep or showing him the damage. But I was there with the seller, who I had just met a half hour earlier, and did not want to get into an awkward situation.
I would not have backed out of the sale on account of this. This dealership was suggested by the seller. But it is the only Chevy dealership in that town, so there really was no other choice. I am the one who wanted to have the inspection done. So if anything it was a joint decision.
Even though I did not show anyone at the dealership or complain at the time, I did call the seller over and show him the damage while the car was still up on the lift. So he witnessed it. Plus the car is perfect in every other way.
I called the service manager. He's supposed to be calling me back. I'll post a picture of the damage as soon as I find the cable for my camera. It sounds like a poll is unnecessary--so far it's 100 percent in favor of "I'd be mad."
On the bright side, I am an attorney. I know already that they are responsible for the damage, and I know how to go about holding them responsible if they decide to not do the right thing.
To be honest with you, I probably would not have that fixed. There is a steel rail directly under that composit there and if you are saying that the cut out now has a half inch cracked off each side and you have to stick your head under there to see it, I would leave it alone.
Im pretty sure those rockers are glued on, so its not like unbolting/rebolting a panel, and of course you would have to paint and blend it in. All of which is a series of events rife with opportunity for the screw up fairy to stop by.
If you do wind up selling it years down the road and I was looking at a the car I think Id like to see a small crack on the underside rather than hear its been taken apart and repainted. But thats just me.
What I would do is have them agree to fix it, get some estimates and ask for a check.
Where are you going to find another one with 2700 miles?
Good luck
Old Mar 8, 2012 | 10:10 AM
  #57
rebelheart's Avatar
rebelheart
The dealership is responsible for any damages THEY cause,period.
To How mad should I be?
Old Mar 8, 2012 | 10:27 AM
  #58
chasboy's Avatar
chasboy
Oldtimer
Old Mar 8, 2012 | 11:11 AM
  #59
chasboy's Avatar
chasboy
Oldtimer
it's just that simple.
Old Mar 8, 2012 | 11:48 AM
  #60
hotwheels57's Avatar
hotwheels57
I wonder if the original poster had started this thread with "If this was your car..." if there would be more of a consensus of opinion to get the damage fixed regardless.
If it was my car I'd want it fixed, maybe not by the offending dealership, but I'd want that 2,700 mile car repaired to what it was.
