quick reverse light question
Old Mar 11, 2012 | 12:15 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Default quick reverse light question
On the reverse light socket, it's a 1157 or 2057 bulb. which has 2 contacts and I believe 2 filaments.
Does anyone know which of the contacts on the bottom are used, which is ground or is ground the barrel portion of the bulb on the bottom.
(I'd look on my car, but I've long since swapped those connections out for another type)
Old Mar 11, 2012 | 12:46 AM
ALLEGRO's Avatar
ALLEGRO
I believe it is a single contact bulb. The "contact" is the positive pole and the case serves as the negative.
Old Mar 11, 2012 | 01:07 AM
LoneStarFRC's Avatar
LoneStarFRC
The socket is designed to use a double contact bulb with offset locking-pins (1157, 2057 or 1034, etc) that would normally be used as a stop/tail/turn bulb in a tail light application. This particular socket only has one contact that makes contact with the pin on the bulb that is the larger (brighter) filament. The barrel is the ground.
Old Mar 11, 2012 | 01:17 AM
ALLEGRO's Avatar
ALLEGRO
I stand corrected !!
To quick reverse light question
