A4 Question???????
Old Mar 13, 2012 | 09:47 PM
Green_Devil's Avatar
Green_Devil
Default A4 Question???????
If you shift a A4 manually too much will it cause damage to the tranny?
Old Mar 13, 2012 | 09:49 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I would think it isn't the best thing for it.
Why shift an automatic?
Old Mar 13, 2012 | 10:04 PM
TOPCATHR's Avatar
TOPCATHR
mr bill makes an excellent point........im sure once in a while its ok
Old Mar 13, 2012 | 10:49 PM
Aerovette's Avatar
Aerovette
I'll give you an example. I am in traffic and waiting for an opening to move over. I don't want/don't like the wait for the kick down so I drop a gear and wait until I have a spot. Nail it and I am over and gone.
Old Mar 13, 2012 | 11:10 PM
Jeff in Den's Avatar
Jeff in Den
Too much for some is not enough for others. It's fine, the owner's manual doesn't discourage it either, no warnings or notices, and even gives recommendations:
"AUTOMATIC OVERDRIVE (B): This position is for normal driving. THIRD (3): This position is also used for normal driving, however, it offers more power and lower fuel economy than AUTOMATIC OVERDRIVE (B).
Here are some times you might choose THIRD (3) instead of AUTOMATIC OVERDRIVE (B):
SECOND (2): This position gives you more power but lower fuel economy. You can use SECOND (2) on hills. It can help control your speed as you go down steep mountain roads, but then you would also want to use your brakes off and on.
If you manually select SECOND (2) when you start the vehicle, the transmission will drive (and stay) in second gear. You may use this feature for reducing torque to the rear wheels when you are trying to start your vehicle from a stop on slippery road surfaces, or for preventing the transmission from downshifting into FIRST (1) in situations where a downshift would be undesirable.
FIRST (1): This position gives you even more power (but lower fuel economy) than SECOND (2). You can use it on very steep hills, or in deep snow or mud. If the selector lever is put in FIRST (1), the transmission won’t shift into first gear until the vehicle is going slowly enough.
When driving on hilly, winding roads.
When going down a steep hill. "
Old Mar 13, 2012 | 11:15 PM
Green_Devil
And great avatar PM it to me if you have the chance
Old Mar 13, 2012 | 11:16 PM
Green_Devil
try it Mr. bill it's fun lol
Old Mar 13, 2012 | 11:22 PM
Orig Ante M's Avatar
Orig Ante M
I hope a tune will help with this though.
Old Mar 13, 2012 | 11:25 PM
rtpassini's Avatar
rtpassini
St. Jude Donor '11-'12
interesting....so if you are going say.....120 and shift into 2nd, it wont actually drop down a gear until its "safe"?
Old Mar 13, 2012 | 11:29 PM
Not something that I have ever done - I guess if I wanted to downshift often, I would have got a manual tranny in the first place.
Old Mar 13, 2012 | 11:36 PM
Orig Ante M
Sometimes taking advantage of an opportunity to own a vette that isn't a manual is the best option available at the time. So an occasional downshift brings a little excitement to those without.
Old Mar 13, 2012 | 11:48 PM
jrose7004's Avatar
jrose7004
I can't imagine why you would.
Old Mar 13, 2012 | 11:52 PM
ZMX's Avatar
ZMX
Downshift it all you want.
And, to those that can't understand why: Shift delay! It's good for when passing in traffic, because you don't have to wait for the transmission to shift out of 4th into 3rd, then change its mind and shift into 2nd, etc. Automatic transmissions can't read minds, and the occasional manual select fixes that.
Old Mar 14, 2012 | 12:26 AM
Green_Devil
I had a chance to buy a M6 but im not a fan of manual tranny it's just me
Old Mar 14, 2012 | 03:40 AM
DeeGee's Avatar
DeeGee
My normal driving is around the narrow and windy roads in rural England. For regular driving it's just fine in D.
At the speed limit of 60mph as you brake into a tighter bend and then accelerate through it, the ratios mean that the A4 upshifts mid corner. That gives a lurch, just feels wrong as well as leaving you without any power in the corner. The delay in kickdown makes the situation worse. Dropping into 3rd or even 2nd gives better control through the bends.
The transmission is designed to run in the lower gears so I fail to see why there would be any damage. I normally keep an eye on the transmission oil temperature if I shift manually.
Old Mar 14, 2012 | 05:49 AM
SMaster's Avatar
SMaster
I like D for spirited driving and use OD for most everything else.
There are some transmission settings that can be changed to eliminate some of the delays in shifting, automatically or manually.
I will never understand why people think it's silly to shift an auto. it's got a lever on it doesn't it? It's because sometimes I wish I had a manual but like the convience of an auto. So, I like the feel of shifting sometime but have an auto! (trying to eat breakfast.. not even sure the above makes sense to me....
Old Mar 14, 2012 | 06:28 AM
BigTattooMan's Avatar
BigTattooMan
St. Jude Donor '10
As it's been pointed out there isn't anything in the manual why not to and their usually pretty good about covering all of the warnings.
There are times where it is helpful, I have a long sweeping on-ramp on my way home and it's easier to drop it down a gear to keep the car from up shifting so once at the end I don't have to floor it to get it to down shift.
Old Mar 14, 2012 | 10:31 AM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
The question is "will it cause damage?"
The answer is NO.
Everything else is supporting information for how YOU choose to drive and why.
To A4 Question???????
