Front splitter/lips clearances
Old Mar 16, 2012 | 10:35 AM
Hamlet's Avatar
Hamlet
Cruising
Default Front splitter/lips clearances
Hello,
Which of the available front splitters/lips provides the best ground clearance?
Anyone tried mounting corner splitters on a vette?
Dan
Old Mar 16, 2012 | 11:27 AM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
The shortest, full-width splitters come from Quik Z06. They have the C5R and Vortex. Mine's the Vortex. Lowered all the way on stock bolts, I have 4-1/2 inches of clearance in front.
Old Mar 16, 2012 | 11:30 AM
Robert 2000's Avatar
Robert 2000
I had a Vortex sold it before I put it on. I did not want to sacrifice the ground clearance.
Old Mar 16, 2012 | 11:47 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Another vote for vortex.
The Ground clearance on flat surfaces is the same as it would be with the factory, however the ground clearance forward of the center air dam is about 1-1.5" less than without. Just keep in mind approach angles and you'll be fine.
Old Mar 16, 2012 | 12:17 PM
AU N EGL's Avatar
AU N EGL
Originally Posted by Hamlet
Hello,
Dan
Canards ?
3" ground clearance to the bottom of the splitter.
Old Mar 16, 2012 | 01:22 PM
TXGS507's Avatar
TXGS507
ACI...
To Front splitter/lips clearances
