2001 Engine Light Code 10-PCM
Old Mar 20, 2012 | 04:51 PM
VTDREAM's Avatar
VTDREAM
Cruising
Default 2001 Engine Light Code 10-PCM
Bought recently used 2001 and had a few issues. ABS and Traction Handling lights came on. First tried removing battery cable, didnt work. Replaced ABS control module, problem fixed. Now Engine light is on and DIC says, 10-PCM 2 codes. Pressed reset, lasts a couple of days then comes back on. Any thoughts that cld fix. Otherwise love the car.
Old Mar 20, 2012 | 09:55 PM
VETJAZZ's Avatar
VETJAZZ
bump
