Shell 89 octane
Old Mar 24, 2012 | 11:28 PM
VETJAZZ's Avatar
VETJAZZ
Originally Posted by blacksedan87
This is an age old question that has come up a many times.
Yesterday - we had occasion to dyno tune an '08 C6 (LS3) with an Edelbrock supercharger that had been installed and tuned in Indiana. The car was tuned for 93 octane....we have only 91 octane here in Arizona.
The car detonated with anything more than about 8-9 degrees of timing. We tried everything to figure out why. We pulled out a boroscope and took a look at the tops of the pistons. They were all cratered and looked very similar to the surface of the moon. The owner admitted that he had been running 87 octane from time to time. Also the installing shop had de-sensitized the knock sensors to the point of them not working at all.
This car should have been able to run 12-14 degrees of advance with no issue, and would not without a lot of detonation. Bottom line is we de-tuned the car, the owner is going to try a couple of cans of Sea-Foam to break up the carbon on top of the pistons. We'll re-check the car after he does the Sea-Foam, and runs a couple of tankfuls of 91 Chevron through it. I have my doubts, it looked like damage to me.....
So to answer the question - can the car run lower than recommended octane? Yes - if the timing is retarded. The knock sensors should be able to handle it - but the long term affect is not desireable. You will get less performance due to the retarded timing, and less fuel mileage as well. All in the interest of saving about twenty cents per gallon times maybe 15 gallons. That's three dollars for a 15 gallon tank. To me - not worth it.
I try to run the fuel that is recommended, and that is at least 91 octane. Your car - your choice.
Old Mar 25, 2012 | 02:02 AM
itzza427's Avatar
itzza427
A simple solution to the hit in the wallet,,,just top off by the time it hits 1/2 tank!! You still run the good stuff and don't take as big of a gouge to your pocket!!!
Old Mar 25, 2012 | 07:06 AM
99 vett babycar's Avatar
99 vett babycar
What's "old" got to do with it?
if you don't know or understand how your car's tuneing is setup with regaurd to fuel octane, assume that the guys that built you car know just a little more about the car than you do and then USE THE GAS THEY DESIGNED THE CAR TO RUN ON. But, then, it IS your car, so use anything that makes you happy.
Old Mar 25, 2012 | 02:50 PM
Vettmann17's Avatar
Vettmann17
These octane posts are just as argumentative as the oil posts. If you want to go on the cheap then go drive an economy car, but it's your car, put whatever you want in it.
Old Mar 25, 2012 | 05:16 PM
PETE O.'s Avatar
PETE O.
91 is right at $4.70 gal here in Eureka but Little Red isn't going to go without it's prefered stock, even if I'm broke.
