99 Tire pressure sensor refurbish?
I had a long chat with a technical manager at Schrader-Bridgeport last evening re. Costco's recent decision to sell TPMS sensors as part of their tire operation. He confirmed that Costco will have sensors for the Corvette; for the 97-00 model years, the part number is 28006 [EDIT 00 sensor?]. Schrader-Bridgeport manufacturers the majority of OEM TPMS sensors; they make the GM sensors. He said only difference with the 28006 sensor and the OEM will be the color. The replacement will be a reddish-orange. It will come with mounting nut (important to tighten to 62 inch-lbs), and valve stem cap. I asked him how "fresh" the units would be, and he said they would be new/recently manufactured. He also said the batteries go into a "sleep" mode when not in use, e.g., while resting on a shelf, so they stay "fresh" for a long time. He was probably blowing a little smoke here, but I see no reason to doubt these sensors would achieve Schrader's advertised 7-10 yrs, or 100K-mile service life. Personally, I'll be buying these at Costco--$47 ea. vs $177 at the dealer is a no brainer.
||--Genuine GM C5 Tire Pressure Sensors/TPM--||
2001-2004 Sensors
25773946 – sensor – $40.60 each
15234846 – nuts – $3.95 each
Total setup of 4 is $178.20
Note: The sensor comes with the washer and valve stem cap.
Setup includes: 4 sensors, 4 washers/o-rings, 4 caps and 4 nuts.
1997-2000 Sensors
25981210 - sensor – $100.78 each
15234846 - nuts – $3.95 each
Total setup of 4 is $418.92
Has anyone actually verified with Costco that it is the Gen 1 Sensor that fits a 99 Corvette for $47 ?? and not the Gen 2 that is for the later model C5's ?
