Tire Pressure Sensor Question
Old Mar 31, 2012 | 07:29 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Default Tire Pressure Sensor Question
Okay, I'm the proud owner of some gently used 2003 Thin Spokes. But they're going on a 1998 Coupe.
It's my understanding that the tire pressure sensors are different on a 2003 vs. a 1998. If this is true, do I put 1998 sensors on the 2003 wheels (will they fit?) or do I buy 2003 sensors?
I've never replaced any of mine so I'm sure they're getting close to needing replacement, so that's not a huge concern (although of course I'd like to avoid it if possible), so what I'm really asking is which one do I need?
Old Mar 31, 2012 | 07:43 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
If your car is a 1998 you will need the first gen sensors. The 2nd gen won't work on your car and yes they will fit.
Old Mar 31, 2012 | 07:49 PM
carhodge's Avatar
carhodge
I have a 98 with 2000 thin spokes,no problem....
Old Mar 31, 2012 | 07:54 PM
Mr.Bill's Avatar
Mr.Bill
Now how does this answer his question?
Old Mar 31, 2012 | 08:03 PM
duramaxsky's Avatar
duramaxsky
http://forums.corvetteforum.com/c5-g...house-com.html
A better way to go iin the long run.
Old Mar 31, 2012 | 09:05 PM
Sonny71's Avatar
Sonny71
Oldtimer
You'll have to go for the more expensive 97 - 2000 sensors, Gene at GMPartshouse can set you up.
Old Apr 1, 2012 | 12:41 AM
You will need to put the '97-00 sensors in the new wheels and yes they will fit just fine. Or you can get the conversion kit from Gene at gmpartshouse.com and use the '01-04 sensors in your new wheels.
Old Apr 1, 2012 | 01:41 AM
DeeGee's Avatar
DeeGee
The sensors speak to the receiver in the car so you need the TPS appropriate for the year model. If the wheels are going onto a 98 you need the old 98 standard sensors.
97-2000 Sensors
10438853 - sensor
15234846 - nuts
Old Apr 1, 2012 | 07:13 AM
65GGvert's Avatar
65GGvert
One way to go:
Old Apr 1, 2012 | 08:00 AM
rws.1's Avatar
rws.1
It depends on how long your plan to own your '98.
Without changing the receivers you need to buy the Gen I older style sensors. But recently you can buy new receivers that allow you to convert to Gen II. Since the batteries last about 7 years the conversion is more expensive unless you plan to keep your '98 longer than the life of the Gen I batteries.
Old Apr 1, 2012 | 08:01 AM
JACKAL0PE's Avatar
JACKAL0PE
Well cool. Then I can just take the sensors from my old wheels and stick them on the new wheels. No expense there, right?
Great.
To Tire Pressure Sensor Question
