passenger side sun visor
Old Apr 16, 2012 | 02:21 PM
2525ken's Avatar
2525ken
Default passenger side sun visor
need some help please. the sun visor on my passenger side is fallling out due to the pastic piece on the visor is broke. can any one tell me where to purchase parts for the sun visors. thanks ken
Old Apr 16, 2012 | 02:36 PM
DeeGee's Avatar
DeeGee
Not sure of the exact problem but does this help?
Sun Visor Fix
I also had a problem with this and I tried a couple of things before I got one that worked. I also used zip ties:
Pull the mirror away from the housing gently. Stick a piece of 3M double sided tape along the inside edge of the top of the mirror between the two holes in the visor.
Thread a small zip tie through each hole from the back and outside of the hole, with the “head” of the tie located in the large rectangular recess. Pull the tail of the zip tie towards you and thread from inside to out through the hole in the locating pin. Push the tail through the head loosely at first.
Use needle nosed pliers (holding the tail) and a precision screwdriver (pushed against the head) to tighten the zip ties. Be very careful when pulling the ties tight not to pinch the lighting wires which run through the same hole. Once tight, snip the spare tail of the tie but carefully so as not to snip the electrical wires.
Push the mirror back into its housing and press firmly against the double sided tape.
Should be good as new.
Old Apr 16, 2012 | 02:39 PM
dougbfresh's Avatar
dougbfresh
Did this on my drivers side a few days ago-works GREAT.
Old Apr 16, 2012 | 03:19 PM
50in1st's Avatar
50in1st
I had the same thing happen to mine. I tried zip ties, but it rattled a little - and that noise was driving me nuts. I ended up using hot glue, which worked really well - so far.
Old Apr 16, 2012 | 10:40 PM
Might help if you posted up a pic of exactly where the visor is broke - if the mirror then DeeGee has given you a fix. If something else, then the need for a pic.
Old Apr 17, 2012 | 12:54 AM
2525ken's Avatar
2525ken
jack when i put the passenger side sun visor up in the hole the plastic fins that keep it from coming back out are broke. cant find a place to purchase these. can you help. thanks ken
Old Apr 17, 2012 | 08:19 AM
dndrsn's Avatar
dndrsn
If its not 009 then its probably 006 which is the the complete sunshade (visor)
009 10342476 BEZEL. Windshield Sunshade
BEZEL,S/S ROD(BLACK) - RH. Required: 01BEZEL,S/S ROD(BLACK)
Old Apr 17, 2012 | 09:03 AM
2525ken's Avatar
2525ken
Jack you are a keeper. the fins I am talking about is number 6. The plastic piece that holds up in the hole. Jack dont know where you get all this info but you are not an official consultant. thanks
To passenger side sun visor
