Glove box latch
Old May 19, 2012 | 04:13 PM
C5RClone's Avatar
C5RClone
Default Glove box latch
My handle/latch is broken, has anyone had to replace theirs and if so where did you purchase the part and how easy is it to replace?
Old May 19, 2012 | 04:19 PM
DeeGee's Avatar
DeeGee
You'll get a good deal from one of the Forum parts vendors
Here's the procedure:
Lock Cylinder Replacement - Instrument Panel (I/P) Compartment Door
Removal Procedure
1. Open the I/P passenger compartment door.
2. Remove the screws retaining the passenger compartment door handle.
3. Remove the door handle.
4. Insert the key into the door handle lock cylinder.
5. Turn the key 1/4 turn clockwise (LOCK position).
6. Release the lock cylinder retainer.
Insert a small diameter tool into the slot on the RH side of the door handle and depress and hold the lock cylinder retainer.
7. Turn the key an additional 1/4 turn clockwise.
8. Pull to remove the lock cylinder.
Installation Procedure
1. Insert the key into the lock cylinder.
2. Insert the lock cylinder into the passenger compartment door handle.
Align the lock cylinder in the same position used for removal, then push to seat fully.
3. Turn the key 1/4 turn counterclockwise to secure the lock cylinder retainer.
4. Turn the key an additional 1/4 turn counterclockwise and remove.
5. Inspect the operation of the lock cylinder.
The lock cylinder should only allow a 1/4 turn and should be securely retained in the door handle.
6. Install the door handle to the passenger compartment.
7. Install the passenger compartment door handle retaining screws.
8. Close the passenger compartment door.
Old May 19, 2012 | 04:35 PM
C5RClone's Avatar
C5RClone
Thanks for the info.
Old May 19, 2012 | 09:45 PM
Good info DeeGee. Saved this for potential use some day.
Old May 20, 2012 | 05:08 AM
ksvette74's Avatar
ksvette74
I also have this problem, and would love to know where to get the part. major PITA having the door broken.
Old May 20, 2012 | 02:48 PM
C5RClone's Avatar
C5RClone
Ecklers have it on sale for $51.99 plus shipping.
Old May 21, 2012 | 02:48 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
gmpartshouse.com
much better pricing than ecklers
Old May 21, 2012 | 10:23 AM
ALLEGRO's Avatar
ALLEGRO
WOW !!!!
That's what I call instructions !!!
Old May 22, 2012 | 06:40 PM
C5RClone's Avatar
C5RClone
GMPartshouse $41.99 wow.
Old Jun 4, 2012 | 06:33 PM
C5RClone's Avatar
C5RClone
My thanks to DeeGee for the brilliant instructions and GM Partshouse who I will be using again.
Old Jul 23, 2012 | 06:52 PM
Gregory0729's Avatar
Gregory0729
Mine came in from Gene at GM Parts House today. With this forum, it was a breeze to complete.
Old Jul 24, 2012 | 12:29 AM
leebay's Avatar
leebay
Originally Posted by ALLEGRO
WOW !!!!
Old Nov 1, 2016 | 08:00 PM
Internetguru's Avatar
Internetguru
DeeGee... TY TY TY
Old Nov 2, 2016 | 12:14 AM
SG Lou's Avatar
SG Lou
Very easy to replace. I did mine in no time flat !
Old Nov 2, 2016 | 06:42 AM
ttiros's Avatar
ttiros
To Glove box latch
