Any problem with top down A/C?
Old May 20, 2012 | 05:53 PM
tigtorch's Avatar
tigtorch
Default Any problem with top down A/C?
I have searched and haven't found a good answer to this. I fully understand the potential energy wasting aspects of of blowing tons of cold air on your body with the top down but are their any technical reasons for this being bad? Could the condensate quantity get too large and get the interior wet, could the compressor over work, etc.?
Old May 20, 2012 | 06:15 PM
sfc rick's Avatar
sfc rick
Your car doesn't care if the A/C is on with or without the top. Don't worry about it, but the fuel mileage aspect might or might not matter to you.
Old May 20, 2012 | 06:17 PM
jrose7004's Avatar
jrose7004
I can't imagine why it would cause any problem.
Old May 20, 2012 | 06:36 PM
65GGvert's Avatar
65GGvert
The temp won't regulate as well to get to the temp you set since the return (internal temp sensor) won't ever reach the correct temp, so it will blow cold continously. Not a problem, I do it all the time.
Old May 20, 2012 | 06:45 PM
Paul G's Avatar
Paul G
In Phoenix the A/C is only off 3 months a year.
Old May 20, 2012 | 06:50 PM
tigtorch's Avatar
tigtorch
Thanks, guys. I am an engineer (not automotive, but I am technically obsessive) so I am aware that the controls will call for more cool air than normal, the compressor will run more than normal, the condensate from condensing water in the air will be more than normal.... What I wanted to know is if there was any practical problem (other than maybe fuel mileage) with doing this.
So far it sounds GOOD, I am warm blooded and can't get enough cool air!!
Old May 20, 2012 | 09:00 PM
1SC's Avatar
1SC
94 here today, but not real humid, anyway I spent the afternoon riding with the top down and AC running. Al Gore may overheat and loose his condensate, but the car and passengers were fine.
I'm an engineer also and would bet that the automotive types actually tested this for yokels like us!
cu
Old May 20, 2012 | 09:13 PM
sfc rick's Avatar
sfc rick
cu
BINGO.....If it was a problem....There would have been a "BIG WARNING" in the Owners Manual stating Don't do this or the wheels will fall off and we will deny Warranty.
Old May 20, 2012 | 10:35 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
That being said I HAVE had times when the wife gets dripped on in very humid FLA weather. I usually just cut the air off for a few minutes to let things dry out. Its never been a big problem.
Old May 21, 2012 | 01:02 AM
yaknow's Avatar
yaknow
common practice, windows up, top down, air on
Old May 21, 2012 | 05:28 AM
Silverback51's Avatar
Silverback51
I think most engineers think the same.
I was wondering the same thing myself.
Old May 21, 2012 | 06:09 AM
I've drove with the windows down, A/C on many times - never had a problem with the HVAC - I think your car will be just fine.
Old May 21, 2012 | 09:12 AM
Corvette_Ed's Avatar
Corvette_Ed
I've been called nuts more than once, but I've been driving with the windows down, top off, or both while having the A/C going full blast for many years and in many different types of cars; my Vette is no exception. I've never had problems in any of them. In fact, just yesterday I explained to my 8 year-old the benefits of using the A/C while the top is off. Gotta get her trained right, ya know.
Old May 21, 2012 | 10:32 AM
DeeGee's Avatar
DeeGee
All I can say is that having done the extended road test in the extremes of climate in Las Vegas and in England, mine's still going strong after nearly 10 years. My record was 136 degrees at one end (Death Valley) and 30 degrees at this end both with the top down. And anoter one here who practises heresy by driving with the windows up and the seat heaters on.
I'd have thought the seals drying out through lack of use might be a bigger problem.
No problems at all. You'll get better cold air output on recirculation mode.
To Any problem with top down A/C?
