clay bar cleaning
Old May 22, 2012 | 04:12 PM
jrose7004's Avatar
jrose7004
I'd say that the kit would be as good as any of them.
Old May 22, 2012 | 04:14 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
That's the kit I have. It is fine and works like a champ.
Old May 22, 2012 | 04:48 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
Originally Posted by my50thAE
Don't forget to do the glass too!
I was amazed at the amount of cr@p that came off my "clean" windows.
Old May 22, 2012 | 05:29 PM
chasboy's Avatar
chasboy
Oldtimer
I learned about clay to get overspray off my RV's windows. Used Claymagic medium. That grade is way too harsh for any of my cars however.
Old May 22, 2012 | 06:43 PM
6speedsteve's Avatar
6speedsteve
Also you do not need to use quick detailer for lubrication, Zaino recommends their car wash, I use a 32oz pump up type spayer and car wash goes farther that detailer does, work great.
Old May 22, 2012 | 07:13 PM
Marine One's Avatar
Marine One
For those who have used it on windows, what is the procedure? Do you just wet the glass with water?
Old May 22, 2012 | 07:49 PM
31coupe's Avatar
31coupe
I used it and it worked great. Use a good amount of their Quick Detailer with the clay bar
Old May 22, 2012 | 08:07 PM
RJB34's Avatar
RJB34
Default Meguires clay is very good!
Meguires clay works great and so easy with great results. I wash my vette with dawn, clay bar it, wash it again. I then buff it with porter cable using meguires #26, then wax with meguires #105. Got rid off all the swirl marks and small scatches. Left a finish like new. Check out amazon and auto geek for good prices. Autogeek has great prices and free shipping! My vette is black so I do it allot. If you run out of lube, I use the soapy dawn water in a pinch. Keep the spray bottle in one hand, the clay in the other, and as others have said-do small areas.
Old May 22, 2012 | 08:28 PM
chasboy's Avatar
chasboy
Oldtimer
I used the 'detailer' liquid that came from the body shop I got the clay from. Seems that soapy water is sufficient. Once I was done, that clay was done too.
Old May 22, 2012 | 10:32 PM
DSTURBD's Avatar
DSTURBD
Senior Member
Cruise-In V Veteran
One thing not mentioned in this thread that I was told before I did it the first time and it really helped is to wear a surgical rubber glove while claying! Drastically reduces the likelihood of dropping the clay as it sticks very readily to the rubber glove. You can't drop it as you have to peel it off of the glove!!! Saved me a bunch of "OOPSES" the first time.
Old May 22, 2012 | 11:02 PM
olbear1962's Avatar
olbear1962
Good idea "DSTURBD".
If you stick to the known brands, you will not have a problem, they all work well - personally have used Meguiars, Mothers, Clay Magic, 3M.
I like the Clay Magic and Mothers, more, that said they all worked well.
Old May 23, 2012 | 10:00 AM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
I've had good results with the various clay bars available. I've found that if I want to save any clay after using I put it in a baggie spraying the inside of the bag & clay & sealing the bag...
Old May 23, 2012 | 10:22 AM
  #33
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
After reading this thread, what is the secret to "Dawn" dish soap that makes it strip automotive wax? Do you wash with dawn, clay and then wash with Dawn again?
Old May 23, 2012 | 10:36 AM
  #34
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Dawn will strip off the old wax, and that is what I do, but I don't rewash the car afterwards. I may use my waterless wash, but I have not found the need to do a complete rewash.
Old May 23, 2012 | 10:40 AM
  #35
chasboy's Avatar
chasboy
Oldtimer
Dawn and Joy have no 'skin soothing' ingredients. I KNOW I'm not clear on this! Try again...the others have ingredients that are not harsh to one's skin, which translates to some type of 'greasy' residue that your skin likes but your paint doesn't.
I learned about Joy from my optician who uses a 'magic' solution to clean glasses. Just a drop of Joy and some water.
Old May 23, 2012 | 11:11 AM
  #36
waddisme's Avatar
waddisme
Back when I used to detail mine lovingly, I found the bar didn't seem to work as well with dawn as it did with the detailer liquid. The clay bar will remove all the old wax and polish, so car will have to be polished and waxed afterwards. After clay bar, it is a good time to remove some of the deeper scratches and swirls and there are plenty of diy threads in the Car Care Section. Nothing like removing that last coat of wax and admiring what 12 hours of hard work will do.
Old May 23, 2012 | 11:51 AM
  #37
chasboy's Avatar
chasboy
Oldtimer
I only use Dawn for THE WASH, which is hopefully once or twice/year. I ran out of detailing liquid and tried Windex which worked fine.
To clay bar cleaning
Old May 23, 2012 | 12:02 PM
  #38
MSG C5's Avatar
MSG C5
How can you tell that you have completely removed the wax?
I use mostly Adams products so my routine has been (1) wash, (2) clay with detail spray, (3) swirl and haze remover where needed, (4) machine polish, (5) machine wax, (6) buttery wax and (7) brilliant spray glaze.
Old May 23, 2012 | 12:56 PM
  #39
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I use Adams as well, except I use the Americana and not the machine wax. If you do a good wash with the Dawn that should remove the wax. Also the clay will remove any remaining wax.
Old May 23, 2012 | 01:22 PM
  #40
Corvette_Ed's Avatar
Corvette_Ed
Blue, orange, or clear Dawn?
