Chrome Wheel Woes
Old May 24, 2012 | 02:09 AM
SG Lou's Avatar
SG Lou
Default Chrome Wheel Woes
Purchased a set of C6 5 spoke Chromed wheels in a C5 Z06 size for my 04 from OE Wheels.
http://www.oewheelsllc.com/Wheels_3/...heels-Chrome_4
Little more than a year later and the barrels are starting to pit. One wheel is so bad that it looks horrible. I'd have to check my invoice but I do believe i'm over the Warranty , but then I checked their web site and found this : "We warranty all new rims against any manufacturer's defects for one full year. There is a lifetime warrantee on the structure and one year on the face finish providing the wheel has been properly maintained. Notice the print in bold ? "One year on the face finish" Nothing is mentioned about the barrels.
So, I can't return them even if i was within the time frame of the warranty.
My question is, besides having them repaired and clear powder coated, is there a paint I can use that will hold up?
I was thinking of wire wheeling the barrels, cleaning them,taping them off and shooting them with either an Argent Gray or Argent Silver paint and then clear coat. Has anyone had any experience with the wheel paints that are on the market?
Old May 24, 2012 | 07:37 AM
65GGvert's Avatar
65GGvert
I would be asking the seller, since they can do something about it if they wish.
Old May 24, 2012 | 08:42 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
They don't warranty the barrels.
Your paint plan sounds good. I've never tried it, but Duplicolor has some good rattle can wheel products.
Old May 24, 2012 | 08:54 AM
David Shiel's Avatar
David Shiel
Default I responded the other day
to a fellow with chrome wheels that I preferred the polished ones due to peel and rust problems with chrome. I would definitely call the vendor . Most reputable companies will go above and beyond to satisfy customers. This should not happen so quickly with a quality chrome application. Damn the Chinese quality issues.
Old May 24, 2012 | 09:03 AM
Worth a shot with the manufacturer of the wheels - heck, you've got nothing to lose at this point. If they decline, then your paint idea should work fine.
Old May 24, 2012 | 09:49 AM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
If your adamant on chrome you can get them powder coated in a chrome finish. Depending on your size you will be looking at anywhere from $80 to $120 a wheel.
Old May 24, 2012 | 10:18 AM
f6john's Avatar
f6john
I have yet to see any repop chrome wheels that don't have issues. I would be hesitant to put more money in wheels that are having issues. There are too many other better alternative choices IMHO.
Old May 24, 2012 | 12:49 PM
94centennial's Avatar
94centennial
no one makes a true chrome powder. i am a large powder coater. I think i've seen every brand of chrome powder. none are close to having the appearance of chrome.
Old May 24, 2012 | 01:31 PM
STALION's Avatar
STALION
Maybe not "true" but pretty damn close.
http://forums.corvetteforum.com/c5-g...me-wheels.html
Old May 24, 2012 | 02:17 PM
mikes1hog's Avatar
mikes1hog
Oldtimer
I was told by a vendor on this site that all of their aftermarket wheels (and they had many; and some were really sharp) including the "newer" Vette wheels to fit the C5 were all made in China. I've been playing with cars for a very long time and the "cheaper" wheels have always been imported. Back in the day the cheap wheels were 40-60 bucks apiece and today, they are 150-200 bucks apiece. The chrome ones have always been a disappointment unless you clean and polish them weekly (and that's clean the inside of the wheel and the chrome outside of the wheel). I learned the hard way like everyone else and it's aggravating.
I think your plan to paint the inside of your wheels is terrific; I spoke to American Racing Wheels years ago about rust and their center caps falling off on the road after 6 months of use...I can still hear the laughter and then the silence for what good it did to call them.
Old May 24, 2012 | 02:35 PM
bucwheat's Avatar
bucwheat
I had a set from WCC that were perfect after 7 years,I sold them when I bought a set of black C6ZO6 wheels from Jonathan at jwmotoring,his wheels are top knotch also.
Old May 25, 2012 | 11:09 AM
94centennial
Default Powder coat
I haven't seen one that is even close. i have sample color chips from most manufacturers of powder both domestic and European. They are all silvery with very little image reflecting quality. They tell me the technology of mixing metalic particles in a resin base that gives the reflection of chrome has not been developed yet. Stalion, if you know the name of the company makes a good looking chrome, please advise. I am quite interested.
Old May 25, 2012 | 12:39 PM
ALLEGRO's Avatar
ALLEGRO
Check with the manufacturer, but you are probably on your own.
I would suggest looking at painting the barrels. Should not be difficult, and you may find a contrasting color really works for your car. Otherwise, just live with it.
Old May 25, 2012 | 01:49 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
best of luck trying to sand off the chrome on the barrels. If they were nickel plated before the chrome, which is the normal process, you will not be able to remove the nickel. That is the sad thing about chrome plated wheels...the chrome layer is extremely thin...just a few microns, but the deeper layers are nickel...normally 3 layers, and extremely hard....just google triple chrome plating and see the multi step process. Not all suppliers adhere to the correct process, and that is what you get from China...absolute crap. When new, they look "ok"...but after one winter in your NJ environment they pit, peel, dull, etc. Buckwheat's set from WCC held up because WCC knows where to get them done right....and all the good platers are now in Californica....
Old May 28, 2012 | 05:32 AM
SG Lou's Avatar
SG Lou
Thanks for the comments Guys. I do believe I'm going to take the Paint Road on this issue. I'll try and give OE Wheels a call during the week and see what they have to say but as stated in another post I'm probably on my own. What pisses me off is I clean and polish the wheels on a regular basis both on the inside and out and the car never saw the road during the winter so I really can't contribute this to salt corrosion.
$$$frumnuttin' I don't have any plans on trying to remove the chrome as it's nearly impossible. What I do plan on doing is use a 120 grit flapper wheel to smooth out the pitted portions of the barrel. Then clean'em, wipe them down with a wax-grease remover and paint / clear coat.
I hoping this will curtail any more pitting.
If it continues I'll go with a set of OEM Polished C6 5 spoke wheels, which also means I'll have to get another set of tires
Old May 28, 2012 | 06:25 AM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I've had several things on my car powder coated "chrome" and they look more like a low luster polished aluminum. When I had the parts done, the man that does my powder coating made it very clear that they wouldn't shine like real chrome.
Old May 28, 2012 | 07:44 AM
sfc rick's Avatar
sfc rick
Sanding chrome off........good luck with that. The best advice "IF" you really want those wheels would be to send them to a chrome plating shop and let them remove the chrome plating "THE RIGHT WAY" and then have them RECHROME the wheels. There are a few shops in California that I've used for chroming wheels on Show bikes that do absolutely the most incredible chrome plating.
RECHROMING IS EXPENSIVE, It's cheaper to buy a new set, use them a couple of years then toss them out and buy a new set again.
To Chrome Wheel Woes
Old May 28, 2012 | 11:45 AM
$$$frumnuttin'
like I stated above...best of luck trying to get paint to adhere to chrome....
Old May 28, 2012 | 11:49 AM
STALION's Avatar
STALION
That's why I suggested powder coating. Bought my new chrome rims and sent them straight to powder coating to get them satin black. Much cheaper then re-doing chrome.
Old May 28, 2012 | 01:08 PM
Rexde1's Avatar
Rexde1
There is a paint called Steel it. It has stainless steel in it and is extremely good at covering rust and standing up to adverse elements. Its used in the pharmaceautical industry. Ive seen it used to spray a old rusty chain link fence and looked good years later. Im not sure where to buy it but its used all over the world and comes in arosol cans.
